Vince - Danas
For installing Linux on a Mac mini, specifically models with T2 security chips (2018-2020) or Apple Silicon (M1, 2020), specialized tools are required for hardware compatibility. Key solutions include Asahi Linux for M1 Macs, custom T2-optimized Linux ISOs (like T2 Mint), and rEFInd for dual-booting, which handle Apple's unique hardware drivers. WordPress.com +2 Key Patching/Installation Methods: Asahi Linux (Apple Silicon M1): The primary project for making Linux run on M1 Mac minis. T2 Mint / Custom ISOs (2018-2020 Intel): These customized Linux ISOs are required to enable keyboard, trackpad, and Wi-Fi on T2-secured Mac Minis. BalenaEtcher: Used to flash Linux ISOs to a USB drive for installation. rEFInd: A boot manager that makes it easier to select between Linux and macOS.
A sad je jasno. Pa vidi na Apple uredjajima ništa osim njihovog OS-a ne možeš da istaliraš direkno. Da bi bilo šta instalirao koristi se za Windows BootCamp a za sve ostalo moraš da skineš adekvatan Pečer. Čak i ako istaliraš noviji Os na stariji apple uređaj mora takođe pečer da se koristi.
diyAudio.rs Linux OS
Evo šta kaže chtgpt: " 🔴 Šta Apple zapravo “radi” Apple ne blokira Linux, ali: 1. EFI boot pravila su stroža nego na PC-u Mac firmware: preferira interni disk (SSD) traži tačno: /EFI/BOOT/BOOTX64.EFI Ako to nema: 👉 ignoriše OS 2. Boot entry (NVRAM) se često ne upisuje Linux installer: pokuša upisati EFI entry Mac to često: ignoriše ili ne pamti 👉 rezultat: Linux postoji, ali se ne vidi 3. Disk prioritet Mac mini: prvo gleda interni SSD (sdb) tek onda ostale diskove 👉 zato tvoj Linux na sda nije ni uzet u obzir 4. APFS + Apple layout macOS koristi: APFS container svoj EFI setup 👉 Linux installer često: ne dira to (da ne “pokvari” macOS) pa završi na drugom disku 5. Tastatura / boot meni (sporedno ali iritantno) ALT (Option) zavisi od firmware-a Bluetooth tastature često ne rade na bootu 🧠 Važno: šta NIJE problem Na ovom modelu NEMA: ❌ T2 security chip (on blokira na novijim Macovima) ❌ Secure Boot zabrane ❌ hardverskog lock-a 👉 znači: Linux radi normalno kad se pravilno postavi 🔧 Realni problemi (ono što te zeza) U praksi 90% problema su: pogrešan disk (kod tebe ✔) EFI bootloader nije na pravom mjestu Mac ne vidi GRUB nema fallback BOOTX64.EFI ✅ Kako se to rješava (industrijska praksa) Tri standardna pristupa: 🟢 1. “Apple-compatible” metoda instaliraš Linux kopiraš: grubx64.efi → BOOTX64.EFI 👉 Mac ga tada uvijek vidi 🟢 2. Boot manager (najbolje) Instaliraš: 👉 rEFInd zaobilazi Apple ograničenja automatski pronalazi Linux najstabilnije rješenje 🟢 3. Instalacija na interni SSD Mac to preferira sve radi “prirodno” 🎯 Zaključak (inženjerski) Nema zabrane ❌ Ima Apple-specifičnih EFI pravila ✔ Ako ih ne ispoštuješ → djeluje kao da “ne može” 💬 U tvom slučaju (direktno) Ti si uradio sve dobro OS-level, ali: 👉 promašio si: lokaciju instalacije (sda umjesto sdb) i EFI integraciju" E ova EFI integracija mi nije jasna. Da li može malo pojašnjenje
Asim, da bi instalirao OS (mada nisi rekao koji operativni pokušavaš da istaliraš), generalno za Apple OS bilo koji da bi istalirao moraš da formatiraš odnosno obrišeš sve na particiji na kojoj želiš da instaliraš. Moj ti je savet da radiš pararelno na dva računara, na jednom da pratiš instrukcije sa YouTube a na mac mini to primenjuješ (najbezbolnija metoda). I kao što ti reče Miko pri butovanju drži taster Alt pre nego što čuješ Chaim, pojave se ikonice HDD -a i odaberš na koji ide instalacija. Ako istaliraš Linux jedino nek ti je Miko na pomoći tu neznam ništa. Pozdrav i srećno.
Miko, ne želim ja tebe maltretirati vezano za specifičnost Maca mini. On ima EFI varijantu starta (ne postoji druga!) , sa Tab-om odabiram ko če prvi startovati i to je to. Mene interesuje, da li ti kao autor možeš skontati zašto podiže gruber? Koju komandu bi trebalo upisati kada se radi o standardnom PC??? O tome da li Mac ima neku zapreku, to je moj problem da istražim.
Šta je pored njega ovo, Canton? Eee, a gde su Beyme, Sonido, pa Beyme coax... Prodao si veru za večeru Eeeeeee
Ja nikad nisam imao MAC. Fizički mislim. Imao sam samo MacOS instalirane na PC. Tako da samo znam teoretski ovo... Kapiram da treba sve da se prebriše pa iznova. Probaj da skineš MX LINUX i njega instaliraj https://sourceforge.net/projects/mx-linux/files/Final/Xfce/MX-25.1_Xfce_ahs_x64.iso/download AKo neće ni on onda moraš nazad na MacOS
Kutije odlično sviraju u prostorijama do 20tak kvadrata. Jedan drajver ima oštećenu membranu, dok je drugi OK. Vidi se na slikama. Zvučno ima razlike, ali se treba malo napeti da se čuje. Cena - kolko date... Lično preuzimanje. KupujemProdajem WWW.KUPUJEMPRODAJEM.COM Praktično sve... Kupi i prodaj u najvećoj online zajednici u Srbiji. Probaj na kp!
Brijac je odgovorio/la Mikorist's temus u Muzika , Film i Fotografija
Kid Fonque -
Hvala jos jednom!
rakija brte, kako drugo
Trenutno na sajtu 8 članova, 2 Skrivenih, 179 Gosta (Pogledaj celu listu)
Ukupan broj tema450.6k
