Showing content with the highest reputation on 06/15/21 u svim oblastima
  1. Svašta nešto došlo: Douk arm lifter. Diže ručicu kad dođe do kraja ploče Haufe SUT. Ne trebam ga sad, ali tko zna... "Rated by Haufe, who also built most input transformers for Klangilm and Neumann, with a ratio of 1:14,3 it gives 1:10 (or 20dB) when used with phono inputs. With 36 Ohms input resistance it perfectly matches lower impedance moving coil cartridges like Ortofon SPU or EMT Tondose TSD15." Kavitacijsko pranje ploča. Dolazi mi u zadnje vrijeme podosta rabljenih ploča, pa da ih sredim prije upotrebe. audiorevita.pl "Der Reiniger ist eine unabhängige Konstruktion, die auf einem medizinischen Ultraschallreiniger basiert und auf jahrelanger Erfahrung in der Reinigung und Revitalisierung alter, beschädigter Schallplatten basiert. Es ist perfekt für den Bastler geeignet, kann aber auch von Profis verwendet werden. Der Reiniger verfügt über einen automatischen Antrieb, einstellbare Leistung, Heizung, variable Frequenz und erweiterte Reinigungsfunktionen" Ortofon SPU GT-E iz 1994. Navodno limitirana serija na 1000 komada. Kad mi se sprdne nabavit ću i jednu GT iz 60-ih i jednu vintage običnu SPU. (zato onaj SUT iako Phono pre kojeg ciljam već ima svoj SUT u sebi - Softone) "This MC cartridge was released around 1994. A rare cartridge produced in a limited run of 1000 units. It is a built-in transformer type and the matching between cartridge and transformer is very good. It gives us a rich sound."
    8 poena
  2. 3 poena
  3. Zen Mod
    JC-80, UGS
    svak radi ono sto zna evidentno logicari oce da imaju dobar preamp onda uzmu sto ne znaju, a preinzenjerisu sto znaju al neka, bitno da su srecni - sebi prave kako im se pravi ja, sto mi ni stap ne treba kao daljinac, nisam merodavan
  4. Conclusion ! My preferences: -Babelfish XA252 (that being All Mos): rails between 30 and 35Vdc - depending how much power is needed, Iq everything between 1A and 2A, depending how much aluminum is on disposal, BFR-22R -Babelfish XA252 SIT: rails 30Vdc, Iq 2A, BFR-22R Hasta La Vista, Baby........ I'll be back!
  5. Zen Mod
    LuDEF
    to sto si dobio su po svoj prilici refurbished, naknadno punktovane duze nozice nije cudo ako je koji skiknuo, a braca Kinezi ne proveravadu testiranje - samo Nelsonov jig iz F3 Article
  6. shonne
    Sav Taj Jazz !
  7. paja959
    Deja Vu,Chapter III,sa zadnjim Van Morrisonom......Chapter I Deja Vu je da je prvi primerak sto sam dobio,LP bio jedva vidljivo,ali B strana sa sitnim "talasanjima" pa sam vrnuo....reklamaciju prihvatili,vrnuli pare....pitam ih,kako sad dalje,posto hocu svakako primerak,lepo kulturno odgovaraju,narucite ponovo,ali trazite uz narudzbu,kvalitativnu proveru....Chapter II,narucim ponovo,platim,u roku 30 minuta dobijam SMS,da mi je narudzba odbijena,zove me telefonom vlasnik radnje,provravali sa izdavackom kucom,sve sto imaju na lageru,da provere,sto ne valja,da im vrate natrag...u momentu odbijanja druge narudzbe,su bili u preslusavanju svih primeraka u radnji,dotle nisu nasli nijedan ispravan primerak ...kad su konacno od 8 izdanja u radnji,nasli 2 ispravna,zvao me vlasnik ponovo,da sad mogu da pustim narudzbu ponovo....herbo vise ove moderne tehnologije presovanja,jako je to los prosek da od 8 komada,2 budu ispravna,a stampano svega 3500 primeraka (Rhino izdavacka kuca)...sad ko kupuje recimo ovo negde kao "turista" u nekom velegradu,vrne se kuci,i ustanovi istu gresku,sta moze da uradi ?...da svira qcu...
  8. Aleks
    JC-80, UGS
    Koja ovo grafička, Ati Radeon PRO? Aej majko ala se iskomplikovao diyaudio....
  9. Ovo je prvobitno bilo namjenjeno za nasu hinternu upotebu za nas u Berhmudskom trohkutu Motadzija-Zvule- ja , ali...
  10. Jel bilo? Deep Inspiration Show "TV" by Jazzman (31.05.2021)
  11. paja959
    King Crimson...klasika "Islands"...nadjoh juce na berzi,reizdanje,200gr,replika inzerta isto pride....sviri do 00,jedan od vrh vrhova progresive,jos i dan danas
  12. paja959
    C,S,N&Y "Deja Vu" 50th Anniversary....msm,sta da kazem,kod mene jos uvek u top 5 albuma all time,mozda i u 3....slusano do besvesti u dzuniorskim danima kuci,diskoteci na JBL L200...odlicno uradjen LP remaster sa originalnih analognih traka...iako imam 2 primerka oba UK/Ex/Ex primerci,ovo nisam hteo propustici...CD materijal originalnog snimka,isto uradjen remaster,a na 3 CD-a neobjavljeni materijali,demo snimci itd....alternativne verzije "Woodstock",ili "Almost cut my hear" atomske bombe,same za sebe...
  13. have some workshop unrelated things today and tomorrow, so second visit to SSE, with Babelfish XA252 SIT is postponed for Thursday as I said, due to too much happenings (both in reality and in my head), I'm far from being capable of both critical and objective listening, thus need for visiting SSE however, as I completed both SIT channels on T-Bed 2 yesterday, couldn't resist today afternoon and I did some listening in my workshop Spoooooky and so much ball$$! dunno (as said) how's in comparison with anything (I need probably just time to re-set, peaceful time without making new ones) but it's as microscope size of Palomar ......... Rocking! sense of foundation and authority, as I remember, even greater than with 100W Babelfish Aleph XJ go figure ZM, Mad Hatter
  14. shonne
    JC-80, UGS
    Neki STM kao u mobilni telefoni 😁
  15. može lock
  • Trenutno na sajtu   2 članova, 0 Skrivenih, 107 Gosta (Pogledaj celu listu)
    452.2k
    Sanjalica
    Sanjalica
