Showing content with the highest reputation on 05/07/21 u svim oblastima
  1. Nije smjesno, ali je zanimljivo: Shavarsh Karapetyan, https://en.wikipedia.org/wiki/Shavarsh_Karapetyan https://www.rbth.com/history/333426-shavarsh-karapetyan-yereven-incident In 1976, Shavarsh Karapetyan, an Armenian Olympic swimmer, had just completed a 12-mile run with his brother when they saw a trolley bus crash into a dam reservoir. The trolley bus sank 80 feet offshore at a depth of 33 feet. Shavarsh immediately dove in and swam to the bus and despite zero visibility, managed to kick in the back window, injuring himself in the process. He proceeded to save twenty people trapped in the bus, one at a time, for hours. The combined effect of the cold water and his inquiries from breaking the glass window led to his hospitalization for 45 days after the incident, during which time he developed pneumonia, sepsis, and lung damage which ended his athletic career. For years, his story wasn't known, until an article about the event identified him by name in 1982. In 1985, he happened to pass by a burning building and rushed inside, again saving people trapped inside one at a time until he collapsed. He was again hospitalized with severe burns and lung damage. He's still kicking it at 66. Just an awesome person I learned about today and thought I'd share.
  2. Nesic
    All-in-one (streamer)
    Sredi to, nahvalimo, napraviš site i eto ti kinte... Beš electro valute Mika izdominira pridevima i kraj priče!
  3. Pravim UI, trebace vremena da se napravi nesto koristno volumio tipa. Za sada jos uvek u domenu zabave i ucenja novih tehnologija.
  4. Nesic
    Nesiceve zanimacije...
    Još dan dva oko sitnica, pa da se puni... Prednja zahteva obradu, i to sam rešio sam da odradim. Videćemo ishod...
  5. Pa ne mora da bude Doubler - ako bi se trafo pravio po narudzbi u lokalu, moze da se predvidi drugacije napajanje za cevi ( grec ili sta god ).
  6. NIXIE
    NIXIE NOS DAC
    I na kraju ulete unutra ISKRA, tako sam odlučio nakon ponovljenih merenja i slušnih testova. Dao sam ipak blagu prednost merenju. Ožičenje identično kao kod Wolanda, CS na 230V, SCS na DC, a za signale u mraku parice izvađene iz belog kabla. Probao sam SCS za signal, vratio beli kabal. Čisto subjektivna odluka.
  7. 1 poen
  8. 1 poen
  9. Neće da može jer nema izlazni trafo, a to je duša SE izlaznog stepena, i daje konačnu boju zvuku (frekventni opseg, harmonici, mali damping faktor, to je SE zvuk).
  10. grone
    Stigo Jbl 18" 2269H Bice uskoro ovako:
  11. kasno im je sad, vratio sam se na rutracker: moja muzika moja odluka
  12. Nesic
    XMOS USB Kartica
    Simultaneous data protocol was used by Philips back in the days of the TDA1540 as the only mode it could be operated in. The TDA1541 then 1541A came later when the I²S protocol was standardized. Thus the TDA1541/A are I²S compatible. But since they were made to be compatible also with previous Philips CD hardware originally intended/designed to work with the TDA1540, they can work in simultaneous data mode... The primary reason I moved to this mode on the 1541 was its convenience when working with up to 192kHz sampling frequencies. Simultaneous mode utilizes two separate data lines, one per channel because the TDA1540 was a single DAC where each channel necessitated its own data signal. Since in this case stereo data are not multiplexed in one line as with I²S but run simultaneously, the frequencies for both master clock and bit clock can be twice as low at any given sampling frequency. Once I ran this chip in simultaneous mode and took regular audio performance measurements, I was very surprised to see its jitter performance better than I’ve ever seen it before.
  13. Nesic
  14. Nesic
    Prednja 440 x 115 Lim 3mm 425 x 404 mm Visina hladnjaka 100 mm Biće Rogababa
  15. silentbob
    Gotovo (sa privremenom prednjom plocom).
  16. silentbob
    Evo ga whammy u akciji: tesla 4oma i sonido 8 oma... https://photos.app.goo.gl/1MLayZotknvNrRt96 https://photos.app.goo.gl/YExdWDhpNmkkotG88 https://photos.app.goo.gl/ZCGzKuMiCStaxBBJ8 Puna soba muzike sa golim drajverom. Ovo ima potencijal da zameni ostale skalamerije od 30+ kila.
