Samo snimci po youtubetu i jedan lik sa big diyaudio, kaze da je super...i akobogda i ja uskoro😀
Nije Slow horses ali početak obećava https://m.imdb.com/title/tt37024136/?ref_=ext_shr_lnk
Filmovi koje volite
Malo bunarenje pomoć AI o Panavision System 65 baš me zaintrigiralo koji line up ga čini. Napisah iz zezanja o Canon Fd kad ono stvarno izmedju ostalih i oni. Nije ni čudo kad kad ceo svet polude za njima a asferikal modeli F1,2 dostižu cenu od 5000 dolara. Dakle sledće marke čine Vintage Line Up: Canon: Most of the System 65 telephoto lenses (such as the 300mm, 400mm, and 500mm) are converted Canon telephoto optics. Leitz (Leica): The System 65 primes are considered medium-format variants of the Panavision Primo line, which historically utilized Leitz (Leica) glass for their optical elements. Mamiya: While not a standard part of the System 65 prime set, Mamiya 645 lenses are frequently adapted by Panavision and other rental houses to the PV 65 mount because their large image circles easily cover the 65mm film frame. Nikon: Historically, Panavision has adapted Nikon glass for various high-speed and specialty large-format applications, though these are more common in their 35mm-based anamorphic sets.
Vokali sigurno zvuče staklasto Valjalo bi čuti - ima li kakvih iskustava do sada?
Alpair-5G Glass Full-Range Woofer WWW.SOUNDIMPORTS.EU Explore SoundImports for the best DIY audio and speakerbuilding components. Excellent advice and fast shipping! Uskoro u Soundimports...107€ par + 25€ postarina . UPS express ili FedEx pitanje je sad?
Znam da nema veze sa grejanjem - napisao sam jer je pomenuto. Mogu da uradim sa diodom samo me je zanimalo da saznam za upotrebu neonke.
dioda je zastita od pozitivnog napona resetke, nema nikakve veze sa grejanjem ja ti rekoh, ti radi kako znas i hoces
Filmovi koje volite
Grejanje 6SN7 je na elevaciji od oko 85 Vdc vezano na negativnu granu DC grejanja. Vh-k je cini mi se 200 Vdc za heater negative wrt cathode i 100 Vdc wrt positive. Diodu bih izbegao jer nema SS elemenata ( sem DC regulatora grejanja.... heh ipak ima nekih SS elemenata ). Meni se cini posto je zastita resetke u pitanju samo dok cev pocne provoditi - da bih mogao staviti i jednu NE-02 ali nisam 100% siguran.
Jasno, obzirom na izbor formata mora I objektivi koji mogu da pokriju toliku povrsinu. Sudeci po trejleru postigli slicne ako ne I bolje efekte. BDW: Bas juce pogledao video o Greg Fraser-ovoj knjizi behind the scenes fotografija sa Dune seta. Masterpiece. Greig Fra ser
Kasno je Takeru... -
Slctvtones -
Sto se mene tice uzmi one ruske 6J9P-E - dzabe su ako dodjes, mozes i da biras od par proizvodjaca a vala meni su svakako bolje od E180F. Kad naletim na njihove dobre cevi onda te razbijaju zapadne ( desilo se par puta ali ne uvek ). Msm ja vise ne marim za te E180F sto imam bez obzira sto su kvalitetno pravljene.
Thabang Tbang -
javi se, pa se sve dogovaramo
koliko vidim to je na 5V? imam ja neko linearno napajanje sto smo radili za Sqeezebox onomad samo treba videti koji konektor je potreban za Wiim
Jel je pokusavao neko da napravi linearno napajanje od ovih ili Teddy Pardo Audio....cene naravno za debile, za WIIM ULTRA strimer. Jebada je sto nije wallwart nego kabl mora da se lemi na pcb a i itreba to dizajnirati , dovesti do onog najskupljeg...kad je bal ,,, sto se igrati sa sirocicima. Aj jbachite pogled, mozda je to vec uradjeno....kad se setim kolko saam LPS pogubio sad me sramota, ako treba enkommmmmmmmmmmm uredjaj da vidi problematiku tu sam. Bespoke Linear Low Noise PSUs
Aj dAA SMISLIM NESTO, VREME NIJE FAKTOR JER SUTRA MOZE DA ME ZGAZI TRAKTOR
Pa gde da se setim, davno to beshe ali prihvatam. Kazi dragicka, menjamo Pot i zice ulaza, izlaza i dc neku deblju, stigla neka exotica pa sto da se ne proba erotica Takodje mi treba neko da sprcka neki bolji LPS umesto SMPS u Wiil Ultra po uzoru na nove Fikuse pre nego li doda koju nulu....u oglasima
Trenutno na sajtu 7 članova, 0 Skrivenih, 113 Gosta (Pogledaj celu listu)
Ukupan broj tema450.1k
