  2. a dobro svira eo, starci rekli : https://www.diyaudio.com/community/threads/tatanka-se-and-balanced-preamps-presentation.430799/post-8093424 https://www.diyaudio.com/community/threads/tatanka-se-and-balanced-preamps-presentation.430799/post-8096104
  4. Nista nisi reko kako svira, ili samo pravis da prodas
  5. djeluje živahno za njihove godine 😁 a i moje 😂 ... preslušah ga na Spotify korektno ... ništa novo ali vraćanje korjenima 👍
  6. Džaba toliki trud i znanje kad svira isto...
  7. A-joj! Ovo mi izgleda sad kao i pravljenje vrhunske akusticne gitare - kolicina vremena, znanja, alata, i talenta potrebna za to je ogromna...🙄 Sama osnova posla je dovoljno teska, a djavo cuci u svakom detalju...
  8. Juče
  9. copy-paste sa bigdiya https://www.diyaudio.com/community/threads/tatanka-se-and-balanced-preamps-presentation.430799/post-8333010 finally got time to put my own in case ..... as usual - industrial design - workshop/demo specimen through years, amassed number of Dodo gadgets, and using those cases for traveling prototypes and demo units two boxes ticked - nobody will buy those and there is no harm when denting elevator doors this one put in case of some weird PA duty double cassette deck and yes, this one is Bal, so serving as simple SE and Bal demo unit ......... even found use for slightly damaged/bad TFT - having dead vertical line; good enough for ZM's own at least nothing is rattling in remote ...... as is case with someone I know ....... he said - "they are always giving me leftovers "
  10. Taman da malo skreneš misli sa kutija.
  11. Jašta je...al' k'o što jedan mudar čovjek reče: Dobro je, da je imalo bolje odma' bi sve đavo odnio.
  12. Ne mere se izvaditi, mora rupa nova. Maltretiracu lea 😁 Nego uzeh veceras malo da se igram sa x4 ad1865 daci sa custom nutube i/v resenjem, da se videti po slici od kako ga skockah, da je hvatao prasinu. Zbog prirode nutuba, distorzija preko 1Vrms na izlazu skace drasticno, pa sam se malo pozabavio setovanjem, i dosao so lepoh cifri 1.99% H2, 0.5% H3, 0.16% H4, 0.25% H5. Na uho, jako zadovoljan. Malo vecernje razbibrige
  13. Ako nista, u istom smo sosu 😁 bar je zabavnije tako u drustvu 😅
  14. Ima nas takvih i previše ako te to imalo tješi.
  15. Ki u njegosa. Jos sam ja baksuz, u dzaku p*cki uvatim se za k*rac... No dobro, vnutri je cini mi se uradjeno kako treba. Tako da funkcionalna su kucista, samo estetski ce trebati dorade. Sam cu, i toeto. Danas sam uzeo sa obrtnom turpijom da probam ivice unutra da obaram, i ide, drasticno brze nego rucno da turpijam, ali mora i rucno da se doradi za bolji finish. Bice do kraja meseca zavrseno, jos da se skanim skretnicu da skockam.
  16. Ovde majstora da tražiš sa fenjerom. I opet je pitanje da li ćeš ga naći. Svi koji stvarno znaju posao rezervisani su po tri meseca unapred. Ako ti klima sad rikne, gotovo, sjebao si se. Voda? Struja? Sve neki priučeni likovi, došli juče sa aku-bušilicom i već danas imaju firmu, logo i cenovnik kao neurohirurg. Masa dobrih majstora otišla je u UAE. Ovde su ostali ili prebukirani, ili nedostupni, ili čovek koji kaže: „Ma znam ja to”, a onda tri dana kasnije traži na Jutjubu gde ide nula i faza.
  17. Ni meni nije jasno, tj. sasvim mi je jasno... Ali kasno. Lekcija naucena.
  18. novi Stones...
  19. Pre nedelju dana
  20. Au, Radosave....ne znam, ništa mi više nije jasno. Nadam se da će izdobriti, odnosno da ćeš uspjeti to sanirati.
  21. Skinuh foliju, i imadeh sta da vidim. Otaljanus maximus. Zovem coveka, kazem da bas nije ok, dao sam toliko vremena mimo dogovorenog, nit se cenkao za novac, nista, maksimum tolerancija, i ni da izgituje. Kaze gitovano je, reko covece nije evo slika. Kako je bilo samo kutija (sto mi je slao prethodno) tako i sa farbom, prelazi, neravnine, nije ni podloga samo predjeno valjkom. Veli dobro dobro resicemo, i izdumam u sebi necemo, ja cu. Ovako cu da skockam za sad, pa kad smognem vremena ogulicu farbu, izgitovati i neki furnir nabaciti. Nekako sam bas bas skenjan, toliko vremena za ovakav epilog....
  22. Ama znam, ja sam mislio nešto učinkovitije, kao oduzeti ama baš svu imovinu rodbine dotičnog, pa nek' se oni obračunavaju sa njim....Ne zamjerite, ja sam dokazao nebrojeno puta da sam "na svoju ruku", morbidnog razmišljanja, škorpion, itd.
  • Trenutno na sajtu   2 članova, 1 Skrivenih, 119 Gosta (Pogledaj celu listu)
    452.2k
    Sanjalica
    Sanjalica
