  1. Juče
  2. Zen Mod
    Trazi se NuC
    ima Srecko naslagano 10 komada
  3. Pchelac
    Trazi se NuC
    Ako neko ima nukčić, u dobrom stanju, a skuplja mu prasinu nek javi pa da pazarim...
  4. Pisao sam mu vec
  5. Sada imam .
  6. A da kupis ove i kanibalizujes za delove? Mozda bi mogao i da pregovaras oko cene. KupujemProdajem WWW.KUPUJEMPRODAJEM.COM Praktično sve... Kupi i prodaj u najvećoj online zajednici u Srbiji. Probaj na kp!
  7. Ako nisi nasao da imas. ES 80.pdf
  8. Znas kako je kada nesto cekas :))) A neka zamena ? Mislim da stavim neki visokotonac dok ne nebavim orginal . Ispod mrezice nece da sde vidi. Samo da je pribliznih karakterisika .
  9. Onda jedino strpljivo cekanje na KP, pa kada se pojave.
  10. To znam. Kada bi nasao neke rashodovane. Ili neispravme . Pa samo da se premotaju .
  11. To sam video i ja. Ali bez one plastike . Samo drajvei
  12. Pisi ljudima, verujem da ce pomoci koliko je moguce. Problem je sto su JBL rezervni delovi skupi + transport + carina + PDV...
  13. JBL 362830-001 Tweeter - The Speaker Exchange RECONINGSPEAKERS.COM Brand New Genuine JBL 362830-001 Tweeter This is the ultra high frequency driver (UHF) Used in models: LC1, L810 ,L830, L880, L890, ES20, ES30, ES80, ES90, ES100 4 ohms Also used to replace parts 353107-001 and 362760-001. JBL ES Series Tweeter 79DM19AX-DT01-E - The Speaker Exchange RECONINGSPEAKERS.COM Brand New Genuine JBL ES Series Tweeter. This includes the lower high-frequency unit and faceplate. Used in models:ES20, ES30, ES80, ES90, ES100 This unit is discontinued! You can purchase part 443574-001 as a direct replacement. This is the bottom tweeter in this assembly. The top tweeter unit (UHF) is 362830-001. JBL Control CRV Tweeter 443574-001 - The Speaker Exchange RECONINGSPEAKERS.COM Brand New Genuine JBL Control CRV Tweeter. 0.75″ titanium-laminate dome tweeter, shielded neodymium magnet, with ferrofluid for cooling. 4 ohms. Can be used to replace tweeter numbers: 362819-001, 338035-001, 905402-010, 335632-001 which are used in models NS28I, NS28II, Venue 80, ES30, ES80, P35E, P35ES, E100, Northridge E30, Northridge E50, Northridge...
  14. Zanimljiva tehnika iz prošlog veka, naravno Ruska Ovi uređaji, poznati kao TGK-3 (ili TK-3), predstavljaju fascinantan komad sovjetske tehnologije iz 1950-ih godina, dizajniran da omogući rad radio-prijemnika u ruralnim predelima bez električne mreže. Ključne karakteristike: - Namena: Primarna svrha bila je napajanje cevnih radio-prijemnika. S obzirom na to da su takvi uređaji zahtevali specifične napone, generator je često proizvodio dva ili tri različita izlaza (npr. 1,2V za grejanje katoda i 90V za anodni napon). - Princip rada: Koristi Zebekov efekat. Toplota plamena kerozinske lampe zagreva "topli kraj" termoparova, dok rebra za hlađenje (radijatori) na vrhu održavaju "hladni kraj", čime se stvara električni napon. - Dizajn: Izgleda kao standardna kerozinska lampa sa masivnim metalnim dodatkom na vrhu. Taj dodatak sadrži termoelektrične module i prepoznatljiva aluminijumska rebra za hlađenje koja podsećaju na "krila". - Tehničke specifikacije (model TGK-3) - Izlazna snaga: Veoma mala, obično oko 2-3 vata, što je bilo sasvim dovoljno za tadašnje efikasne radio-aparate. - Efikasnost: Termoelektrični generatori ovog tipa su generalno neefikasni (obično ispod 5%), ali su bili izuzetno pouzdani jer nemaju pokretnih delova. - Gorivo: Običan kerozin, koji je istovremeno služio za osvetljenje prostorije i proizvodnju struje. Ova tehnologija je bila preteča modernih rešenja poput BioLite kamperskih peći koje pune telefone putem vatre. Moderna verzija
  15. Ne zuri mi se . Na KP treba stvarno imati srece . Ali zato kada zapaprene cenu Mislio sam mozda neki strani sajt za poruciti ...
  16. verovatno samo KP, i nesto srece da docekas
  17. Zdravo , da li neko zna gde be se mogli nabaviti visokotonci sa plastikom za JBL es80 kutije . Treba mi za jednu kutiju . Hvala unapred
  18. Pre nedelju dana
  19. Razmišljam nešto čemu onaj balon što im je pao na pamet da ga postave na Ušću. Možda zato da bi mogao grad da se vidi grad koji je sada zaklonjen onim rugobama izgrađenim u onom "Posnom Beogradu".
  • Trenutno na sajtu   1 član, 0 Skrivenih, 83 Gosta (Pogledaj celu listu)
    449.5k
    markot
    markot
