  2. @Zen Mod Ne dajete nam pauzu da prestanemo na čas da se divimo vašoj: energiji, znanju, umeću, sposobnosti da to prenesete i posebno karakteru i vaspitanju da to SVE podelite sa drugima-NAMA! B R A V O !
  4. Bogdan08
    Eto jos nesto naucih
  5. Zen Mod
    maltene uvek
  6. Bogdan08
  7. Juče
  8. Zen Mod
  9. Bogdan08
  10. Zen Mod
  11. Bogdan08
  12. Zen Mod
  13. Bogdan08
  14. a dobro svira eo, starci rekli : https://www.diyaudio.com/community/threads/tatanka-se-and-balanced-preamps-presentation.430799/post-8093424 https://www.diyaudio.com/community/threads/tatanka-se-and-balanced-preamps-presentation.430799/post-8096104
  15. Nista nisi reko kako svira, ili samo pravis da prodas
  16. djeluje živahno za njihove godine 😁 a i moje 😂 ... preslušah ga na Spotify korektno ... ništa novo ali vraćanje korjenima 👍
  17. Džaba toliki trud i znanje kad svira isto...
  18. A-joj! Ovo mi izgleda sad kao i pravljenje vrhunske akusticne gitare - kolicina vremena, znanja, alata, i talenta potrebna za to je ogromna...🙄 Sama osnova posla je dovoljno teska, a djavo cuci u svakom detalju...
  19. Pre nedelju dana
  20. copy-paste sa bigdiya https://www.diyaudio.com/community/threads/tatanka-se-and-balanced-preamps-presentation.430799/post-8333010 finally got time to put my own in case ..... as usual - industrial design - workshop/demo specimen through years, amassed number of Dodo gadgets, and using those cases for traveling prototypes and demo units two boxes ticked - nobody will buy those and there is no harm when denting elevator doors this one put in case of some weird PA duty double cassette deck and yes, this one is Bal, so serving as simple SE and Bal demo unit ......... even found use for slightly damaged/bad TFT - having dead vertical line; good enough for ZM's own at least nothing is rattling in remote ...... as is case with someone I know ....... he said - "they are always giving me leftovers "
  21. Taman da malo skreneš misli sa kutija.
  22. Jašta je...al' k'o što jedan mudar čovjek reče: Dobro je, da je imalo bolje odma' bi sve đavo odnio.
  23. Ne mere se izvaditi, mora rupa nova. Maltretiracu lea 😁 Nego uzeh veceras malo da se igram sa x4 ad1865 daci sa custom nutube i/v resenjem, da se videti po slici od kako ga skockah, da je hvatao prasinu. Zbog prirode nutuba, distorzija preko 1Vrms na izlazu skace drasticno, pa sam se malo pozabavio setovanjem, i dosao so lepoh cifri 1.99% H2, 0.5% H3, 0.16% H4, 0.25% H5. Na uho, jako zadovoljan. Malo vecernje razbibrige
  • Trenutno na sajtu   3 članova, 0 Skrivenih, 124 Gosta (Pogledaj celu listu)
    452.2k
    Sanjalica
    Sanjalica
