  2. Tko je onaj ceski turist? Onaj sa slapama i carapama?
  3. a dobro svira
  4. Danas
  5. @Zen Mod Ne dajete nam pauzu da prestanemo na čas da se divimo vašoj: energiji, znanju, umeću, sposobnosti da to prenesete i posebno karakteru i vaspitanju da to SVE podelite sa drugima-NAMA! B R A V O !
  6. Bogdan08
    Eto jos nesto naucih
  7. Zen Mod
    maltene uvek
  8. Bogdan08
  9. Juče
  10. Zen Mod
  11. Bogdan08
  12. Zen Mod
  13. Bogdan08
  14. Zen Mod
  15. Bogdan08
  16. a dobro svira eo, starci rekli : https://www.diyaudio.com/community/threads/tatanka-se-and-balanced-preamps-presentation.430799/post-8093424 https://www.diyaudio.com/community/threads/tatanka-se-and-balanced-preamps-presentation.430799/post-8096104
  17. Nista nisi reko kako svira, ili samo pravis da prodas
  18. djeluje živahno za njihove godine 😁 a i moje 😂 ... preslušah ga na Spotify korektno ... ništa novo ali vraćanje korjenima 👍
  19. Džaba toliki trud i znanje kad svira isto...
  20. A-joj! Ovo mi izgleda sad kao i pravljenje vrhunske akusticne gitare - kolicina vremena, znanja, alata, i talenta potrebna za to je ogromna...🙄 Sama osnova posla je dovoljno teska, a djavo cuci u svakom detalju...
  21. Pre nedelju dana
  22. copy-paste sa bigdiya https://www.diyaudio.com/community/threads/tatanka-se-and-balanced-preamps-presentation.430799/post-8333010 finally got time to put my own in case ..... as usual - industrial design - workshop/demo specimen through years, amassed number of Dodo gadgets, and using those cases for traveling prototypes and demo units two boxes ticked - nobody will buy those and there is no harm when denting elevator doors this one put in case of some weird PA duty double cassette deck and yes, this one is Bal, so serving as simple SE and Bal demo unit ......... even found use for slightly damaged/bad TFT - having dead vertical line; good enough for ZM's own at least nothing is rattling in remote ...... as is case with someone I know ....... he said - "they are always giving me leftovers "
  23. Taman da malo skreneš misli sa kutija.
  • Trenutno na sajtu   3 članova, 2 Skrivenih, 152 Gosta (Pogledaj celu listu)
    452.2k
    Sanjalica
    Sanjalica
