Je, samo što elektro inžinjer će sa 10 dana obuke da zameni električara, a suprotno teško da će da može -
Svi ti podaci su uneti sem tacnog off-load napona posto jos to nisam premerio. Ostavio sam da je regulacija Off-Load napona oko 5% iako je obicno do sada bila oko 5-10-11,5% za mrezne trafoe koje imam i radjene po meri ( privremeno dok ne izmerim koliki je off-load napon ). PSUD2 je meni do sada bio relativno precizan kad se jednom ubace svi ti podaci. Sem toga kad god mogu ja uradim i merenje napona na predvidjenom opterecenju sa otporima od 20W. Izvinjavam se za off.
asimze je odgovorio/la Mikorist's temus u Muzika , Film i Fotografija
Malo ti se čini! Nije puno ofulao! Samo što bi kuča zarasla u šiblje visine 2 metra i nebi mogao priči kuči. Ne zaboravi Aleks korov stigne .... Balašević! -
Khaya -
Ma, hteo sam da napisem, ne propada krov bas ovako za 6 godina Definitivno AI -
U prozorcicu Edit za vrednosti kondenzatora treba postaviti i odgovarajuci series resistance za primenjeni kondenzator. Evo ga i proracun impedanse trafoa iz PSUD2 help-a : Edit Transformer Properties Enter the voltage for the secondary of the transformer. Note that this must be the off-load voltage, which is generally higher than the rated voltage of the transformer. For full wave rectifiers, use the voltage for one side only. For example, if the transformer off load voltage is 350-0-350V (700V end to end), the correct value to enter is 350. Enter the source impedance of the transformer. If you don't know this, you can click on the [...] buttons to invoke the off load voltage calculator, or source impedance calculator respectively. Source Impedance Calculator The source impedance of the transformer is required in order to simulate the transformer "sagging" under load. Supply voltage: (VP) The voltage primary supply into the transformer, normally 110/115/220/230/240 volts. Winding resistance: (RP) The measured resistance of the primary winding. Off-load voltage: (VS) The measured voltage on the secondary of the transformer before any load is applied. Winding resistance: (RS) The measured resistance of the secondary winding. Resistance for simulation: R.equiv = ((VS/VP) x RP) + RS
To je izvesnost života. Svaki dan neko negde odlazi. I mi ćemo kada nas pozove. C' est la vie. Ne klonjavajte duhom -
Mozda, ali je bas to surova realnost mnogih koji su otisli, neki na drugo mesto, a neki na drugi svet... -
AI kreirana fotografija. Manipulacija emocijama. Put u prvom planu i vrh krošnje drveta u drugom planu 15 godina nepromenjeni. -
ST se vratio ! Trijumfalno !
Naravno da se drogira, najverovatnije Elsold tamjanom -
Kod mene je negde oko 35-37 Ohm-a mada sam ja trazio ako je moguce da bude nesto vise.
Na ovim mreznjacima RDC-HV sekundara je oko 45-Ohma mereno sa kraja na kraj.
Koliko znam uzima u obzir pogotovo kad se ima trafo sa izmerenim DCR primara i sekundara. Ono sto ne uzima u obzir je indukcija trafoa koja je kod mene 0,91T - generalno trafo je projektovan tako da se ne greje puno i ne bi trebao biti drasticno opterecen ( takodje pored HV sekundara postoje sekundari grejanja sto PSUD2 u ovom slucaju ne uzima u obzir ). Hvala !
Trenutno na sajtu 7 članova, 1 Skrivenih, 83 Gosta (Pogledaj celu listu)
Ukupan broj tema450.5k
