  2. Onda jedino strpljivo cekanje na KP, pa kada se pojave.
  3. To znam. Kada bi nasao neke rashodovane. Ili neispravme . Pa samo da se premotaju .
  4. To sam video i ja. Ali bez one plastike . Samo drajvei
  5. Pisi ljudima, verujem da ce pomoci koliko je moguce. Problem je sto su JBL rezervni delovi skupi + transport + carina + PDV...
  6. JBL 362830-001 Tweeter - The Speaker Exchange RECONINGSPEAKERS.COM Brand New Genuine JBL 362830-001 Tweeter This is the ultra high frequency driver (UHF) Used in models: LC1, L810 ,L830, L880, L890, ES20, ES30, ES80, ES90, ES100 4 ohms Also used to replace parts 353107-001 and 362760-001. JBL ES Series Tweeter 79DM19AX-DT01-E - The Speaker Exchange RECONINGSPEAKERS.COM Brand New Genuine JBL ES Series Tweeter. This includes the lower high-frequency unit and faceplate. Used in models:ES20, ES30, ES80, ES90, ES100 This unit is discontinued! You can purchase part 443574-001 as a direct replacement. This is the bottom tweeter in this assembly. The top tweeter unit (UHF) is 362830-001. JBL Control CRV Tweeter 443574-001 - The Speaker Exchange RECONINGSPEAKERS.COM Brand New Genuine JBL Control CRV Tweeter. 0.75″ titanium-laminate dome tweeter, shielded neodymium magnet, with ferrofluid for cooling. 4 ohms. Can be used to replace tweeter numbers: 362819-001, 338035-001, 905402-010, 335632-001 which are used in models NS28I, NS28II, Venue 80, ES30, ES80, P35E, P35ES, E100, Northridge E30, Northridge E50, Northridge...
  7. Danas
  8. Zanimljiva tehnika iz prošlog veka, naravno Ruska Ovi uređaji, poznati kao TGK-3 (ili TK-3), predstavljaju fascinantan komad sovjetske tehnologije iz 1950-ih godina, dizajniran da omogući rad radio-prijemnika u ruralnim predelima bez električne mreže. Ključne karakteristike: - Namena: Primarna svrha bila je napajanje cevnih radio-prijemnika. S obzirom na to da su takvi uređaji zahtevali specifične napone, generator je često proizvodio dva ili tri različita izlaza (npr. 1,2V za grejanje katoda i 90V za anodni napon). - Princip rada: Koristi Zebekov efekat. Toplota plamena kerozinske lampe zagreva "topli kraj" termoparova, dok rebra za hlađenje (radijatori) na vrhu održavaju "hladni kraj", čime se stvara električni napon. - Dizajn: Izgleda kao standardna kerozinska lampa sa masivnim metalnim dodatkom na vrhu. Taj dodatak sadrži termoelektrične module i prepoznatljiva aluminijumska rebra za hlađenje koja podsećaju na "krila". - Tehničke specifikacije (model TGK-3) - Izlazna snaga: Veoma mala, obično oko 2-3 vata, što je bilo sasvim dovoljno za tadašnje efikasne radio-aparate. - Efikasnost: Termoelektrični generatori ovog tipa su generalno neefikasni (obično ispod 5%), ali su bili izuzetno pouzdani jer nemaju pokretnih delova. - Gorivo: Običan kerozin, koji je istovremeno služio za osvetljenje prostorije i proizvodnju struje. Ova tehnologija je bila preteča modernih rešenja poput BioLite kamperskih peći koje pune telefone putem vatre. Moderna verzija
  9. Ne zuri mi se . Na KP treba stvarno imati srece . Ali zato kada zapaprene cenu Mislio sam mozda neki strani sajt za poruciti ...
  10. verovatno samo KP, i nesto srece da docekas
  11. Zdravo , da li neko zna gde be se mogli nabaviti visokotonci sa plastikom za JBL es80 kutije . Treba mi za jednu kutiju . Hvala unapred
  12. Juče
  13. Razmišljam nešto čemu onaj balon što im je pao na pamet da ga postave na Ušću. Možda zato da bi mogao grad da se vidi grad koji je sada zaklonjen onim rugobama izgrađenim u onom "Posnom Beogradu".
  14. Diletanti. Ne umeju ni da lažu, ni da kradu a de ih ne uhvate. Oni nisu u stanju da stvore neke smislene nove simbole.
  15. Zeznuto ovo prekrajanje istorije i zamena starih simbola grada, novim
  16. Pre nedelju dana
  17. paja959
    Gramofonska tema
    vec vidim da ce se neki da se krste,trcat ce po beli luk...moram priznati frlo interesantna kombinacija..Linn Adikt na 1300G..mozda nema tu trasparenciju ko moj MoFi Mastertracker,mozda ne slaze tako dobro 3D,i skida zvuk sa zvucnika kao MoFi,al ima jedan puniji gornji bas,i donji srednjotonski spektar,pa je nekako "ritmicki" jako dobar,gornji spektar nije tako dobro razradjen kao kod Mofi,al nista sto bi smetalo...teoretski je to prepakovani Goldring 1022x,samo ima FG2 profil igle...
  18. A nije ti ostao još koji u nekom ćošku? 😁😀 Neću te hvaliti.....ne mogu od ljubomore! 🤩🍻
  19. Svaka čast za istrajnost, ozbiljan rad i završetak ovako monumentalnog projekta.
    449.5k
    markot
    markot
