Showing content with the highest reputation on 05/17/24 u svim oblastima
  1. Zen Mod
    ZM, random zanimacije
    Big DiyA Store web reorganizovan The diyAudio Store - DIY amplifier kits, chassis, and parts DIYAUDIOSTORE.COM DIY amplifier kits, amplifier chassis, hard to find transistors and circuit boards i onda, dva draguljcica (ZM nema materijalnog interesa u Store, to bese/behu/su pokloni u korist Greedy Boyz) Iron Pre DIYAUDIOSTORE.COM There are two versions of the Iron Pre: Balanced / Differential and Single-Ended. Builders of the balanced version can select balanced or single-ended for each input. The boards include not only the “iron-based” gain stage, but also a shunt-regulated PSU section, and a relay-based input switching section. A total Project Aleph JZM DIYAUDIOSTORE.COM New Product Information - 100 kits are available for immediate purchase. In addition, we are taking a set number of pre-orders for the next batch, which is expected to ship no later than July 2024. Learn how pre-orders work. The Nelson Pass designed First Watt Aleph J is a classic. Various versions of the Aleph J have
    8 poena
  2. Trebali mi neki kondovi od 500Vdc sto nema u nasim radnjama pa sam nabavio MBGO 20uF/500Vdc a i da probam kako rade napajanja sa takvim tipom... znao sam da su poveci gabariti ali kad je stiglo... uuu jexxte.
  3. U mnogim branšama se radi marketinga napravi nešto što je komercijalno neodrživo samo kao pokazna vježba. U smislu: "Vidi što mi možemo! Mi smo awesome! Naši jeftiniji proizvodi imaju ovu tehnologiju prilagođenu potrebama potrošača. Nemojte kupovati od onih papaka što ne mogu napraviti ovako nešto!".
  4. Nakon provere ovi zeleni stari tip Iskra blokci idu napolje jer su daleko van svake tolerancije , umesto njih ubaceni su novi tip braon boje Iskra blokci odgovarajuce vrednosti , umesto dva 2200pF blokca u kolu RC mreze boje tona ubaceni su stirofleks kondovi kao sto fabricki u jednom od pojacala ima ,..
  5. Doktor
    Juce stiglo . . . danas posle posla se otvorilo . . . . paket pod nazivom : popunjavanje "rupa" + neocekivano iznenadjenje. Tony Williams - The Joy of Flying. Paklena jazz fuzija sa dosta funk/rock/blues-a, a bogmi ima i tu progresive. US izdanje - crveno/zuta nalepnica Columbia, tvrd karton spoljasnji omot. Ekipa da se smrznes ( ima na slikama ). Ubedljivo najjaca numera ( IMO ) A4 - Open Fire ( Ronnie Montrose koji je razvalio el. gitaru, te Brian Auger za klavijaturama i mladji brat Cipolina, Mario. Starijeg ko pa ne zna - Dzon Cipolina ), jedini live snimak ( Tokyo ) na albumu. Brutalna svirka - preporuka. Doslo se u posed i prvog ( zuti ) albuma B52. Nemac. Neslusan vinil, omot intaktan. Jugoton-ovo izdanje ide na klupu za rezervne igrace. U ovom lot-u se naslo i 2 albuma od Third World. Najs.
  6. Ma jok. Novčanike posetioca audio sajma. Samo je izdresirana njih da guta
  7. grone
    Totalno ispravna za smesnu cenu, nisam mogo ostaviti radi do 00.
  8. Licno sam za malo krupniju varijantu , stari tip , jer mesta u kutiji ima za njih dovoljno .
  9. oce piski,nece piski....oce piski...i dalje mi je omot odvratan,al ce lepo tamo da pravi drustvo ostalim Tull LPima,iz rane faze...
  10. Vix
    Ovaj je malo manji
  11. krca44
    Realno pitanje je da li je stvarno imao "u ponudi" ili je napravljeno 5 ili 10-tak komada koji su otisli a jedan se vrteo medju influenserima / review-erima. Mislim da je to period od pre jedno 20-25 godina i da sam citao review u tadasnjem online "Soundstage-u"....
  12. Zen Mod
    JT is JT is JT
  13. On nije težak. On je moj brat. Tužna priča.
  14. Sa domacih oglasa There I fixed it, sto bi se reklo
  15. Krajnje dobra i korisna knjiga, koju bi mnogo koji muž-muškarac trebao pročitati.
  16. Ovde su bitno jeftiniji, a ima i popust na kolicinu. http://shop.vremeplov.co.rs/Shop/Product?name=Elko-47uF_450V-105C-16x31.5mm-Samwha&accountingCode=26455
  17. Edit originalne seme , gde je greskom upisana ; - vrednost katodnog otpornika ulazne ECC83 lampe nije 22K nego je 2K2 (2,2K) - u kolu RC mreze boje tona jedan blok kondenzator nije vrednosti 22nF nego je 2n2 (2200pF) .
  18. krca44
    Tim de Paravaccini je imao u ponudi power amp sa 1,000 fet-ova takodje, verovatno vrlo kratko, napravljeno kao egzibicija da moze.
  19. Ista procedura Remonta je ponovljena i na drugom pojacalu , zamenjeni su i svi `entbrumer` trim-potovi sa novima Piher (250R) jer su svi originalni znacajno promenili vrednost ,
  20. zerowaf
    I sam sam se to zapitao!
  21. mutayu
    I gde da nadje 1000 Iskrinih trafoa? 😁
  22. shonne
    IT razno.
    Prezadovoljan zvukom...sklopio napokon novu config i ovaj se chip tako dobro cuje cak i na obicni mini liniju. Videcemo na velikom sistemu kako bude, kao strimer.
  23. zerowaf
    E taj! Nisam se više sjećao detalja, pa sam samo rekao da mislim da je N.P. uradio nepto takvo. Mislim, a tko bi drugi? Jedini koji bi mu mogao staviti soli na rep možda razmišlja kako napraviti amp sa 1000 Iskrinih trafoa. Samo, tko bi to mogao biti?
  24. Mikorist
    Evrovizija
  25. Mislim da im je anakonda progutala antilopu....a možda i gazdu!
  26. Zamenjeno je dosta van tolerancije otpornika i cak jedan bez ikakvog otpora sa kvalitetnima , zamenjeni su i neki sumnjivi blokci sa kvalitetnima Iskra , umesto standardnih bakelitnih postolja kod lampi koje se dosta greju (EZ81 , EL84x2 ) postavljena su Philips keramicka sve sa pripadajucim teflonskim podmetacima ,...
  27. grone
    Pustili na rad Krell KSA-100 Mk2 ono u dasku, nakon dosta vreme, muke i truda... Zvuk je neverovatno dobar za pocetak.
  • Trenutno na sajtu   0 članova, 0 Skrivenih, 1649 Gosta (Pogledaj celu listu)
