Showing content with the highest reputation on 12/14/23 u svim oblastima
  1. Definiši "kršten" uređaj. Ako je kvašen prilkom krštenja, to je sumnjivo već.
  2. Teško da francuzi bacaju to
  3. BROB! Bass Reflex Open Baffle.
  4. Brass Construction - Kec. Uvek zabavi - soul/funk.
  5. Nije poceo vikend, ali se krenulo posle RBgd 2/3 ipak sa par vinila. Dzuli Driskol & Brajan Ozer & Triniti . . . . klasik danas.
  6. ... poklopac od tegle ajvara ....
  7. Samo cekam kad ce neko to da iskopira pa predstavi na nekom hi-fi show-u, za nekih 8000 eura . A marketing ce biti nesto tipa: "The port has a very special function. It linealizes the quantum pressure between two opposing planes, but it does so only in the range of selected frequencies, while supressing the unwanted ones. As a result, you get a very life like wide sound stereo image. As XY commented, it sounds better than any 10k speaker heard so far" Ko mi kriv kad ne znam prodavati maglu
  8. 2 poena
  9. grone
    Danley THSPUD
    Napravio sam ranije prije 2-3 god Danley DTS-10 "clone" origigi je ovaj: DTS10 | Danley Sound Labs WWW.DANLEYSOUNDLABS.COM The DTS10 theater subwoofer is the ideal subwoofer for home theatre and cinema use with a powerful low end sound. Pratio sam temu u AVS forumu ima i na drugim forumima: https://www.avsforum.com/threads/danley-dts-10-super-spud-diy-kit.1189404/ Ispostavilo da Alpine R2-W12D4 drivers 2 komada rade bolje nego ono sto Danley koristio custom Eminence koje ne moze se kupiti. Sve to lepo i jeftino uradio jos ga koristim zavisi sta slusam gledam. Posto imam dosta PWR amps na njega je povezano 2500w crown xls2501 na bridge modu. Kao taped horn ima oko 7m lavirint unutra, znam da sam stavio negde ovde u forumu... ide veoma nisko oko 15 Hz sa dosta Spl, rezano je na 60Hz, podesen je aktivno sa time delay i PEQ dosta sam se bavio stime. Vise se to primecuje u filmovima na dobar source i ne smeta uopte u muzici. U toku svega toga sam primetio da Danley ima manji model THSPUD koji isto moze se klonirati sa isto tako Alpine SWR-843D Origigi je ovaj: THSPUD | Danley Sound Labs WWW.DANLEYSOUNDLABS.COM The THSPUD subwoofer is ideal for a home theater and is a great way to bring Danley Sound Labs products into your home. Ima dosta oko Clone toga: DIY THSPUD clone - Subwoofers - The Klipsch Audio Community COMMUNITY.KLIPSCH.COM So I decided to start a actual build thread on the THSPUD clones I will be building, instead of hijacking the thread I have on plywood. Now I am going to be lazy and copy what I wrote on another thread. First if this isnt allowed then I apologize in advance, and please delete it. If not, then enj... Danas su stigli i nisam hteo temu da stavim u "novo pristigle skalamerije" da bude tema ovde. Nastavak sledi ubrzo...
  10. jororaitchev
    Few my DIY projects
    Imam novu ideju za projekt - Sphere, što će biti s ostalima - čekaju, pa neka bude..! Ovo je projekt koji je moj san, novogradnja - 450m2, ali uz ideju akustike, zvučne izolacije / toplinska izolacija je obavezan uvjet /. Trebalo bi izgledati ovako;
  11. I da se izbaci elektromotor i ubaci 1.6TD Gore isto, krovni nosač
  12. Treba pozadi da ima isti priključak ko traktor, da može da se kači oprema
  13. Misliš novi sajberdrek.....
  14. NIXIE
    Taj šum je mizeran kad je sve kako treba. (piše: 30 uV A-weighted output noise). Oni jeftini Kineski moduli D klase sa Alija, napajani isto tako jeftinim SMPS napajanjima, tu sigurno može svašta da se desi. Najveća sumnja pada na jeftine izlazne LC filtere Iizlazne prigušnice sa feritima i kondenzatori sumnjivog kvaliteta koji treba da sve harmonike i šumove pretvore u toplotu). Lično ne verujem da taj Ice Power može da pravi probleme. Ipak je to kvalitenije puno. Osim toga snaga tog pojačala je jako velika, sumnjam da ga možeš toliko opteretiti u kućnim uslovima da dođe do nekih neželjenih efekata. Ako ga pustiš sa lanca, nisu samo visokotonci ugroženi.
  15. Vix
    Da se ja pitam, D klasa samo za bass... Mada, ako ode u clipping, moze bilo koje pojacalo da spali visokotonac. A sto se oscilacija tice, pre 10 tak godina sam imao slucaj pretpojacala (Rod Eliott sa IC) koji je oscilovao kad se spoji duzi interkonekt. Naravno, nista se nije culo. Kako sam primetio? Iz zabave, imao sam analogni ampermetar u seriji sa napajanjem IC pojacala, da gledam kako igla skakuce s'bassom. U jednom momentu sam primetio da "vuce" vise stuje "u leru". Sa kracim interconectom izmedju pojacala i pretpojacala nije bilo toga. Reseno tako sto sam povecao "stopper" otpornik na izlazu iz pretpojacala...
  16. zerowaf
    Očito je da su tvoje marketinške supermoći na visokom nivou, ali ti integritet ne dozvoljava zloupotrebu istih. Kudos! No, ako se odlučiš popustiti iskušenjima mogao bi stvoriti veliki Ultra-Hi-End-Apsolute-Fidelity brand! Ili to, ili se uhvatiti pulitike i uspostaviti svjetsku dominaciju kroz najnoviji svjetski poredak.
  17. Jutro Zero! BROB is new Black
  18. ... a cefka za bas-refleks služi za bolju promaju ...
  19. Pa bio povezan na Hypex NC502, imao samo 11R i 3.9uF znaci oko 5Khz tako je bilo preporuceno od Ace, Ali nismo pricali da ce biti korisceno u D klasi... i da ja ono ponekad nagazim kao na Jbl... 140-15D ide 500Hz~100KHz i verovatno Hypex negde na infra freq imao cliping! Polako je poceo da se pojavi rupa kao sa iglom u sredini ribona i pucao posle neko vreme. Pricao sam sa Acom objasnio mi da treba i 0.1Mh da stavim zbog toga. I poslao mi nove ribone bez ikakvih troskova tip je car. To je bilo prije 2 god ali veceras dosao red da promenim jer previse toga je doso&desilo i nisu mi bili potrebni. Inace radi do 00 ustvari ubija kako radi I tako.
  20. zerowaf
    Bauhaus: Bela Lugosi's dead iz 1980-te. Bela Lugosi's Dead - Wikipedia EN.WIKIPEDIA.ORG NM- pošteno ocijenjeno stanje. Nakupovao sam se "mintova" koji nisu bolji. Nisam odolio. Od srednje škole volim tu stvar, a imao sam tada samo snimljeno na kazeti. Nije bilo love za ploču, a ni ploče nije bilo za kupiti i da sam imao lovu. Bar ne u mojoj vukojebinici. Idemo sad opet..... "Oooo Belaaaaaaaa.............."
  21. Dejane, kao što je već rečeno, stvarno si rijetka kombinacija znanja, iskustva i pripovjedačkog dara. Poznajem tvoje tekstove sa audiofila i sa TNT-a (nadam se da ne griješim u vezi stranice?).Imam jedan sebičan prijedlog!Ako te ikada zatekne neko dosadno poslijepodne ili neizdrživa želja da napišeš pokoju misao o audio tehnici nemoj se ustručavati to napraviti u vidu bloga na našem malom diya. :)Ne možemo (bar ja ne mogu) ti nićim konkretnim uzvratiti, ali eto, da bar predložim.
  22. dvv
    Velicina kondenzatora u napajanju
    Milovane, tehnika je tehnika, ona je prilično egzaktna, ili možeš da dokažeš svoje tvrdnje, ili ne možeš. Nema sredine. Prema tome, čim neko počne da mistifkuje stvari, odmah znaš da prekrviva svoje nedovoljno znanje. Istina, ne može se sve dokazati formulama, ali može ličnim primerom. Ako ti je neko sumnjiv, samo ga pitaj da ti pokaže šta je on lično napravio i odmah ćeš znati sve što treba.Onda tu ime i subjektivnosti. Neko smisli neku caku, i onda se stisne kao seoska mlada pred udaju, da ne daj bože neko drugi ne sazna. VRLO tipično svuda, a posebno u Srbiji. Pošto sam imao i imam podosta Internet poznanika, od kojih su neki žive legende (na žalost, James Bongiorno još jedva, dva puta je prevario rak, ali izgleda da ovaj treći put neće), imao sam prilike da se i lično uverim da su to ljudi koji na jasno pitanje odgovaraju što jasnije mogu, zbog čega ih i poštujem. Logika je jednostavna - ako ja, kao neki šatro poznavalac, spadam na to da krijem ovo ili ono, onda sam ja slaba veličina. Obrnuto, ako jesam neko ko nešto eto malo razbira, moja logika treba da bude: reci sve, jer dok tvoj učenik stigne do tvog nivoa znanja, pretpostavlja se da ćeš i ti u međuvremenu napredovati.Dobro, dosta filosofije. Da, zapremina igra određenu ulogu, i ne samo to, nego čak i oblik. Uveri se sam u to, pogledaj kataloge proizvođača, koji mahim nude istu vrednost u bar dve verzije, širi a niži, i uži a viši, i videćeš da najbolje prolaze oni uži a viši. Nisu to neke velike razlike, da se razumemo, ali de fakto postoje.Kada ti neku vrednost postigneš sa manju alu folije unutar elektrolita, onda znači da si nešto ozbiljno radio sa hemijom. Kada posle uporediš takav elektrolit sa nekim od onih masivnih, po definiciji će nominalne osobine onog većeg biti bolje. E sada, da li ta razlika opravdava razliku u ceni, a onaj veći će po definiciji biti skuplji, to je sada stvar lične procene. Po sistemu, ako umesto neke serijale staviš nešto što košta dva ili tri puta više, nećeš dobiti toliko bolji zvuk kolika je tazlika u ceni jer su elektroliti samo jedan deo sistema. Ako ti sada neko ponudi još skuplji i objektivno bolji elektrolit za 40% skuplji, imaj na umu da on više ne može da ti popravi zvuk više od 1 ili 2%. Za više, treba to celo novo i bolje kolo, odnosno proizvod.Nemaj iluzije, i projektanti ovo razmatrju jako ozbiljno. Nije svejedno, ali opet, nije ni tako kritična razlika. I nikada ne zaboravi da i tu, kao i svugde drugde, ima 99% marketinga i 1% istine, veoma nalik kablovima. Mitovi, magija i voodoo. Samo zato što je Elna zapakovana u sexy pakovanje je ne čini izuzetnom, pa čak i posebno dobrom. A samo čekam da Japanci strpaju kiseli kupus unutra i dožive audio nirvanu, već su trpali svilu (Elna - ???), bambus (Panasonic - ???), itd.
  23. To Dejane, pricas pravim i razumljivim jezikom i za nas koji smo poluobrazovani o audiotehnickim pitanjima, mogao bi ladno da predajes na FTN.Nego samo jedno banalno pitanjce...Da li zapremina elektrolita u napajanju uz isti cap. igra ikakvu ulogu, npr. na 22000uF Siemens je 105 x 64 mm, a F&T 80 x 50 mm. Ili je to potpuno nevazno...
  24. dvv
    Uzgred, veličina kondenzatora u napajanju je prilično stabilan zahvat koji odlično radi i retrospektivno.Na primer, imate neki integralac star recimo 20 godina. Recimo da on ima u sebi elektrolite od 8.200 uF. Ako ih naprosto zamenite, pa još stavite nešto pošteno (tipa Fischer+Tausche, Siemens, BC Components, itd), trenutno ćete imati bolji zvuk. Ali, ako pored zamene nečim poštenim usput i stavite veće elektrolite, dobićete još bolji zvuk - garantovano!Objašnjenje je i očigledno i očekivano. Veći elektroliti će naprosto dozvoliti i veću raspoloživu energiju, i bolje filtriranje.Sada ostaje jedino pitanje koliko veći. Naime, i tu je moguće preterati, pa staviti neki mamutski elektrolit koji će brzo da spali ispravljač, koji je bio korektno dimenzioniran za 8.200 uF, ali ne i za recimo 22.000 uF, gotovo tri puta više.Kao neko opšte pravilo, do 50% veća vrednost elektrolita ne bi smela da bude problem. Ako ispravljač ipak crkne, onda znajte da je već bio načet i samo čekao priliku. Može i do 100% više, ali uz razumevanje da je tada lakše moguće da dođe do problema. Ako je preko 100%, pametno biste uradili da zamenite i ispravljač, odnosno idpravljačke diode ako je diskretan.Sa druge strane, ako 8.200 uF zamenite sa 22.000 uF, prebacićete sva preostala ograničenja pojačavača, a pre svega njegovog izlaznog dela, na samo pojačavačko kolo - što je UVEK dobar postupak. Dobićete i čujno povećan stepen kontrolisanosti basa, koji će biti jasniji, čistiji i pod većom kontrolom. Najzad, pošto u vrednosti Damping faktora učestvuje i ispravljač, i pošto veći elektroliti imaju prirodno manju izlaznu otpornost, dobićete i bolji damping faktor. Ovo čisto za sujetu, jer sve preko 20 dB, odnosno 10:1, više nije bitno, sve što pojačavač ima da uradi sa kontrolom Q faktora zvučnika on obavi do 20 dB, posle toga sve je samom zvučniku. Upravo zato i dobro projektovani cevni pojačavači sa nominalno 10W/8 Oma umeju da poseduju i vrlo lepo kontrolisan bas, čiji kvalitet iznenađuje.
  25. dvv
    Nema frke, reći ću ti šta mislim.Moja poenta je bila da ilustrujem da je potrebna ENERGIJA proizvod dve stvari. Iako zaista ne radim sa lampama, ipak bih sebi dozvolio dva komentara, od kojih se jedan neposredno odnosi na tvoje pitanje. Većina nas je imala prilike da se susretne sa cevnim pojačavačima, obično sa gotovo smešnim specifikacijama snage, ali, samo naizgled suprotno logici, i sa tako malom snagom oni ponekada umeju da zvuče stvarno božanstveno. Tvoje pitanje je i te kako na mestu, ono što impliciraš njime sasvim stoji. Viđao si i veće vrednosti - i te kako jesi, 100 uF je sasvim očekivana vrednost. Evo, ja ću sada u cevnu verziju pojačavača za slušalice, koju je projektovao moj kolega Oli sa kojim radim, da stavim Nichicon kondenzatore od 100 uF/400V. Ako se dobro sećam, napon je 270V, pa bi, upotrebom prethodno navedenih formula, time dobio vrednost od oko 7.3 Džula. Kada se uzme u obzir da je realna snaga disipacije mala, recimo 1W, vrednost koju ugrađujem je bar 3 puta veća od najveće moguće potrebne. Pošto je pojačavač za slušalice mala snaga, i pošto u propisnim pojačavačima snage imaš i one kondenzatore od 330 uF, nije teško zaključiti prostim poređenjem da cevni uređaji po definiciji žive lakši život od trazistorskih, i to zato što se od trazistorskih očekuju daleko veće snage. Drugi elemenat jeste činjenica da ogromna većina cevnih uređaja ima ne samo to, nego i potpuno stabilisane linije napajanja. To je tek melem na ranu za audio, jer kada se to uradi, i kada se radna tačka uređaja dobro podesi, onda on tu ostaje kao ekserima/čavlima zakucan, ne mrda. Vreme odziva na tranzijente i vreme smirivanja nakon njih se - biram reči - DRASTIČNO popravljaju. To su dva konstrukciona elementa koji jasno i glasno daju prednost cevnim uređajima, a njihove mane, te vrline i mane tranzistorskih i dalje ostaju. Odatle, sasvim logično sledi pitanje - šta bi bilo ako bismo sada iste te metode primenili na tranizstorske uređaje? Iz iskustva od preko 25 godina mogu da kažem - njihov zvuk bi se radikalno popravio, a razlika između tranzistorskih i cevnih uređaja bi se radikalno smanjila u kontekstu kvaliteta zvuka. Na primer, od mene nije izašao niti jedan pojačavač snage koji nije imao razdvojena napajanja za naponski i strujni deo. Ono za naponski je po definiciji elektronski stabilisano i nekih 5V je iznad onoga za strujni deo. Time izlaz može da bude na 5V manjem napajanju i stoga ima više struje, a ma šta on radio, naponski deo nema pojma o tome jer živi svoj život. Stabilnost je uveliko poboljšana, a zvučna pozornica je nešto sasvim drugo no inače, ima i širinu, i dubinu, i visinu. Ako je cena bitna, onda strujni deo ide pod elektrolite, recimo paralelno dva od po 10.000uF i jedan od 4.700uF. Ako cena nije bitna, onda i strujni deo ide pod punu elektronsku stabilizaciju. I dešava se očekivano. Nominalno 70/140W u 8/4 oma počne da zvuči kao komercijala od 150W/8 Oma. Nije on ništa glasniji, ali je čvrst, definisan i subjektivno deluje kao da ima neizmerne rezerve snage (naravno, to je samo iluzija, nema toga pojačavača koji se ne može preopteretiti). Iako možda ne dostiže najbolje cevne uređaje, svakako im prilazi blizu, ali zadržava sve prednosti tranzistora - veća snaga, manja izobličenja, mogućnost ultra male povratne sprege, enormne brzine uspona i smirivanja, veliki propusni opsezi, itd. I sve to sa standardnim, off-the-shelf, tranzistorima, dakle ništa specijalno, ništa skupo. Zato ih se i držim.
  26. dvv
    Iako ovo nije direktno povezano sa temom, ima veze - mala digresija.Pametan projektant pravi pojačavač snage tako što počinje sa odnosom izlaznog stepena i napajanja. Osnovna misao-vodilja je ste ona definicija idealnog pojačavača snage - prava žica sa pojačanjem (Straight wire with a gain). Zaboravite vate i ampere, gledajte napon. Idealan pojačavač je izvor konstanog napona, bez obzira na radno opterećenje, što i jeste vaš cilj. Vi želite da imate recimo 20Vrms u 8, ali i u 4, u mom slučaju i u 2 Oma. Omov zakon kaže da svaki put kada se uz isti napon vrednost radnog opterećenja prepolovi, potrebna struja se udvostruči. Na žalost, naše radno opterećenje je zvučna kutija a ne laboratorijski otpornik, što znači da ta kutija nema impedansu, nego ima modulus impedanse, koji će varirati od 16 do 3 Oma bez problema. Njegov PROSEK je 8 oma, ako i toliko. Umesto posmatranja niza izolovanih vrednosti, potsetimo se da nas ne zanima struja odvojeno od napona, nego i jedno i drugo. Dakle, nas zanima potrebna i raspoloživa ENERGIJA, iskazana u Džulima (Joule). Ako vam se sada ovo čini kao neka teška komplikacija, odmah ću vam demosntrirati da ne samo što nije komplikacija, nego je naprotiv veliko olakšanje. Recimo da želite da napravite pojačabač snage sa nominalno 100W/8 Oma. To je i više nego dovoljno za bilo kakvo kućno slušanje, ali pod uslovom da zadovoljava neke kriterijume. Uzmimo i da ste već veteran DIY osoba i da vam je dosta lutanja, nego da hoćete pošten uređaj sa kojim ćete staviti tačku na tu temu (bar dok vas ne uhvate pundravci da opet neto lemite). Razmotrićemo tri mogućnosti. Zajedničke postavke za sve tri mogućnosti su da imate simetrično napajanje koje hranite adekvatno velikim toruson, koji ima male padove napona u rasponu od 3% (tačan podatak za one od 500 pa naviše VA). Uzmimo da radite sa 20% rezerve, što će reći da vam treba 40V napona u 8 Oma za željenu snagu, odnosno, sa rezervom, 51V (što znači da trafo treba da daje 36-0-36V pri maksimalnom opterećenju, odnosno 37-037V u "leru"). Pošto ćete na predriver-ima, driver-ima i izlaznim tranzistorima imati (0,65+0,65+0,65, ili 2V prirodnog pada napona, TAMAN ste na 20% razlike kako i treba). Praksa je pokazala da nam za svakih disipiranih 10W snage treba između 1 i 2 Džula energije, sada nam ostaje da izračunamo kakvi su nam elektroliti potrebni da bismo to i postigli. Umesto da kao komercijala posmatramo zvučnik kao otpornik, mi ćemo ga posmatrati kao realno opterećenje koje nije linearno, nego je naprotiv veoma kompleksno, ne zaboravite da zavrtanje faze od -60% zatheva tačno DUPLO veću struju!!!). Praksa je pokazala da sledeća formula funkcioniše savršeno: Džul = (V+)2 x Farad. Ništa nam više ne treba. Slučaj 1 - štedim, zanima me samo čistih 100W/8 Oma Dakle, ovo je optimistički pogled na svet, koga zanima samo 8 Oma (koji ne postoje) i to kao šisto opterećenje, dakle 1 Džul za svakih 10W disipirane snage. 100W/8 Oma = 10 Džula 10 = (50 x 50) x Farada 10 = 2.500x0,004, odnosno 4.000 uF, odnosno 4.700 uF kao najbliža standardna vrednost. Ovo je Bob Carver uživo. Odavde lako i golim okom možemo videti da nam za čistih 40V/8 Oma treba duplo više kapaciteta, odnosno 8.200 uF. Slučaj 2 - isto kao i pod 1, ali ne samo na 8, nego i na 4 Oma 40V na 4 Oma daje 200W/4 Oma. Dakle: 200W = 20...40 Džula, pa koliko smo optimisti. Da budemo realni, recimo 1,5 Džula/10W, odnosno 30 Džula ukupno. 30 = (50x50)xFarada 30 = (2.500) 0,012 odnosno 12.000 uF po grani, po kanalu. Slučaj 3 - Put The Pedal To The Metal! Gas do daske! Ja hoću idealan naponski izvor, znam koja su g***a zvučne kutije, idemo na 2 Džula/10W sve do 2 Oma. Dakle, 400W sa po 2 Džula/10W daje 80 Džula. Alal vera na majstori! 80 = 2.500 x 0,032, odnosno 32.000 uF po grani po kanalu, ili 64.000 uF po kanalu, odnosno 128.000 uF za stereo pojačavač. Čista Krell klasa! Eto kako Krell i slični izvlače takve snage, da i ne spominjem koliko tranzistora snage naguraju na izlaz. Neki Levinsoni imaju po 32 tranzistora snage, svaki od po 250W, PO KANALU! Nadam se da je jasno da gornje vrednosti treba RACIONALNO modifikovati prema snazi izlaznog stepena. Veoma je poželjno da imate punu elektronsku zaštitu, jer ovde sada pričamo o desetinama ampera, koji veoma lako mogu spaliti ceo pojačavač u deliću sekunde. I veoma je jasno da ako imate dobro projektovanu zaštitu, možete se provući sa ispunjenom funkcijom i sa manje tranzistora zahvaljujući očiglednoj činjenici da nikada nećete sedeti i sluašti sinusoide pri punom gasu. To znači da morate ostaviti bar plovinu snage kao minimalnu rezervu za slučaj nekog tranzijenta, a i to je baš onako bedno malo. Poenta - daleko više od napona, napajanje određuje i kvantitet, i kvalitet zvuka koji čujemo.
  27. Iskreno - kada je TV mehanika u pitanju nemam neka posebna iskustva sa ugradnjom Sikoirel klase Elka u TV set - ove , mislim da su takvi elkovi tu nepotrebni u vecini slucajeva , opet za neku Audio primenu ih licno nisam koristio . SAMWHA Elkovi mi jesu dostupni i nisu uopste preterano skupi ali jesu srednjeg kvaliteta izrade i za ozbiljne pozicije bilo u TV - setovima ili Audio uredjajima ih licno izbegavam zato sto su mi po istoj ceni dostupni mnogo bolji Elkovi tipa Rubycon , Panasonic , Floryt , Iskra itd , ali ih ponekada ugradjujem u neke manje kriticne pozicije i tu odradjuju posao 100 % OK . Ono sto bih voleo da istaknem jeste ipak sledece : Dobar kvalitet Elka kao i njegova ocekivana dugotrajnost se lako prepoznaje ipak na vrednostima ispod 10uF , recimo jedna izuzetna kriticna vrednost kod mog posla jeste Elko 1uF / 50 V ili 2u2 /50 V ili 4u7/50V ....(SMPS / Chopper - primarna strana kola ) , tu ne boze bas svaki Elko da polozi moj strogi test Unimerom Iskra 3 ali ga Rubycon prolazi ladno , Iskra jos lakse - bez mane , Frolyt takodje a i poneki Panasonic se provuce nekako ,`` Kinezi`` nemaju nikakve sanse na tim manjim vrednostima , i tu ne pravim Nikada Nikakav kompromis jer ako TV- SMPS `` podivlja``musteriji nakon godinu dana rada zbog loseg( rasusenog i razgacenog ) malog Elka ..... `` ode zacas mas` u propas`` i eto nepotrebnog posla i nepotrebne glavobolje .Ovo su moja licna iskustva sa tim Elektrolitskim kondenzatorskim elementima u zadnjih 30 god rada i drzeci se ovih pravila koje su me naucili stari majstori ovog posla nemam nikakvih problema , cenim da za Audio primenu vaze ista pravila , mozda za neke pozicije u Audio Hi - End uredjajima jos i stroza .
  28. Naravno da se ununtrasnji raspad nekoriscenog Elektrolita (deteoracija , dekompozicija ) ne dogadja brzo tj preko noci ! za to treba ipak odredjeno duze vreme . Isto se slazem sa tobom da dugostojece nekoriscene Elko -ve treba ``oziveti `` na neki nacin , taj tvoj opisani metod nije los . Isto bih i napomenuo da direktno na zivotni vek Elka ima uticaja naglo strujno punjenje i naglo praznjenje istog , tako da kada su u pitanju SS Amp - vi sa Elko filterima ogromnog kapaciteta spregnuti sa strujno izuzetno jakim Mreznim Trafoima / SS ispravljacima treba Obavezno primeniti neki `` Soft Start `` sklop . Isto puno uticaja na radni vek ima i izbor nominalnog radnog napona Elka u odnosu na vrsni napon linije u koji je ukljucen , i taj radni napon Elka treba da bude bar za 1/3 veci od napona specificne `` linije`` u koju je ukljucen , i nikada ne na samoj granici ! Jamico(n) elektroliti jesu prosecnog kvaliteta i obicno dolaze iz Kine . isto vazi i za Elna elkove - nista posebno . Eto par tipova vezano za proveru i ocenu kvaliteta Elektrolitskih kondezatora iz moje dugododisnje TV Mehanicarske prakse gde otkaz elektrolitskih Kondo-va cini preko 80 % izazvanih kvarova u TV setovima: 1) - Proba sa omanjim stalnim magnetom : Kod manjih Elka sa radijalnim izvodima prineti stalan magnet pinovima (izvodima ) pa ako se ti pinovi zalepe za magnet znaci da su izvodi napravljeni od kalajisane gvozdene zice radi pojeftinjenja procesa proizvodnje i kao takve ih ne treba ugradivati Nigde jer su loseg kvaliteta bez obzira na napisani brend proizvodjaca . Jedan od pokazatelja dobrog Elka jeste i da su izvodi napravljeni od nemagnetske bakarne kalajisane ili posrebene zice ! (Bakar jeste plemenit i skup metal - gvozdje to nije )2 ) - Proba instrumentom - Za ozbiljnu probu Elka Ne upotrebljavam nikada digitalni istrument nego uvek Analogni instrument ! U tu svrhu uvek koristim stari Iskra unimer 3 mereci na odredjenom ohmskom podrucju ` curenje` Elka polarisuci isti u oba smera , pogotovu gledam sta se desava pri Inverzoj polarizaciji Elka - Dobri Elkovi imaju nemerljivo malo `` curenje `` cak i kada su Instrumentom inverzno polarisani ! 3 ) Neka moja iskustva vezana za ponudu kvalitetnih i dugotrajnih Elka na nasem realnom domacem trzistu : Ako bih pravio neku rang listu ponude i kvaliteta i postojanosti Elka to bi bilo ovako kada je dobar kvalitet u pitanju : Rubycon (Japan ) , Iskra (Kranj ) , Frolyt (Poland ), Panasonic (Japan ) , Siemens ( Germany ), Nichicon (Japan ) Samsung ( Korea ). Svi navedeni brendovi jesu vrlo dobrog do odlicnog kvaliteta - pogotovu `` Photoflash `` varijante istih kada su u pitanju Elkovi veceg kapaciteta namenjeni za filtreska kola linearnih ispravljaca za SS ili Tube Ampo - ve . Posebno bih hteo da istaknem neprevazidjen visok kvalitet Iskra Elektroliskih kondenzatora iza kojej stoji fabricka tajna u procesu proizvodnje istih koju je otkrila i primenila nekada davno u proizvodnji jedna njihova dugogodisnja zaposlena zena ( Inzinjer ) . Isto tako je nekada davno proizvodila vrhunske Elkove i nasa domaca EI - Nis fabrika . 4 ) Losi elektroliti - Mahom skoro svi koji dolaze iz Kine - Rec , Elyte , RubyOOn , Sham- Wa , itd , sa ovim elkovima nema pravljenja ozbilnog uredjaja pa ni Audio Hi - End -a ! 5 ) Vrh trenutne svetske ponude vrhunskog kvaliteta jeste Cornell Dubilier - USA - Avionics grade Capacitors , Nekada rezervisani samo za USAF Army elektronske Aplikacije a od skoro dostupni svima preko Mauzer kataloga , sa 50 god Garantovanog rada Elka ali i izuzetno visokih cena za iste : Cornell Dubilier - Ultra long life Capacitors
  29. dvv
    *van ReitzJa ne znam šta si ti video, ali znam da velike fabrike to u principu ne rade. Dozvoljavam da će uvek biti serija nekih posebnih elektrolita kod kojih će i to biti urađeno, iako ja ne znam ni za jednu. To je jednostavno preskupo za velikoserijske proizvode. To što si ti video na slici lako može biti poligon za kontrolu kvaliteta, kada po principu slučajnog uzorka izvade xx komada iz tekuće serije i bace ih na inkviziciju.Nikada ne zaboravi onu staru izreku - pretpostavka je majka svi z*j*ba! Oko toga da i nominalno jeftini elektroliti iz popularnih klasa umeju da iznenade, potpuno se slažem. Kao i sa time da proizvodi veoma poznatih i cenjenih firmi umeju lepo da podbace, čak toliko da se kupac oseti prevarenim.Ne slažem se sa tobom da DIY osoba prebacuje kupovinom dobrih elektrolita. To je problem ekonomije i ničega više. Isti ti čuveni Elna, Nichicon, itd elektroliti nisu ništa posebno skupi recimo u SAD. Sa druge strane, Evropa je ta koja nabija cene, i to ludački. Japanski elektroliti su u Evropi dosta retki, i samim tim, dosta skupi. Ali, potpuno isto važi i za američke proizvode - na primer, AD 826 AN u Evropi ume da košta i 20 eura komad, a na sajtu AD-a ih plaćaš US$ 2,79, što sa poštarinom, carinom i PDV-om izađe oko 3 eura. Pa ti vidi šta se isplati.Istina, to pretpostavlja da znaš za dobre izvore delova po dobrim cenama, ali tu je Internet da te podrži. I pitaj, neko će već znati.
  30. dvv
    Dobro, nije sve baš tako dramatično, ne ide preko noći. Imajmo u vidu da je današnji Low ESR elektrolit neuporedivo bolji od svoga dedice od pre 30 godina. Ako sednete da merite današnje elektrolite, recimo Jamico (koga većina smatra "shit" elektrolitom i firmom), verujem da ćete se jako iznenaditi koliko su dobri i apsolutno, a kamo li u odnosu na one od ranije. Koliko su trajni ne znam, ali onako odoka, verujem da su trajniji od starijih predaka.Lek za mnogo toga jeste formiranje elektrolita. Za one koji ne znaju šta je to, odmah da kažem, ništa posebno komplikovano. Jeste malo zametno na ličnom nivou, ali verujte, vredi truda, bar dugoročno.Treba vam jedan mali sklop, koji ima dva regulatora, 7805 i 7815, svaki sa jednim malo jačim trazistorom koji je dobro hlađen, recimo BD 139. Elektrolit se prvo POLAKO (tj. recimo 1...2 minuta) napuni na +5V i ostavi na tom naponu desetak minuta. Potom se uz pomoć otpornika veće snage (bar 5W) isprazni, pa se cela procedura ponovi na +15V. I to je to. Ali, posle tog tretmana, pismeno ću garantovati da će taj elektrolit da traje bar 33% duže od drugog istog tipa koji nije bio formiran.
  31. dvv
    Prvo, nisam imao prilike da čujem tako nešto, sem u nekoliko predpojačavača. Moja impresija je bila da to ne nudi ništa novo u odnosu na stvarno dobro napravljeno napajanje, ali ovde je kljušna reč "impresija". Slušanje od čak i nekoliko sati ne može da obezbedi bilo šta više od impresije, da bih stvarno znao, moram to nešto da slušam bar 10 dana, i to kod mene, gde poznajem akustiku i imam sa čime da to uporedim.Drugo, sve što si rekao za baterije je tačno, ali si zaboravio ključni podatak da su one 3-4 puta SPORIJE od elektrolita. To ih čini nepoželjnim za velike potrošače, kao što su pojačavači snage, iako i dalje ostaju realno moguće rešenje za manje potrošače, recimo predpojačavače. A tu si i problemi sa nužno malim naponima, masom, problemom punjenja, itd. Doduše, mogu se koristiti i DC-AC konvertori, ali po meni, to upropašćava celu ideju jer prlja napon sa svim problemima konvertora. Kao i sve drugo, i oni mogu biti ovakvi ili onakvi, ali dok se složi neki stvarno dobar, odoše jako velike pare i mnogo prostora.Nagra koristi baterijsko napajanje, i nema sumnje da to jako dobro radi, ali pogledaj cenu.Moj lični stav je da ništa nije bolje od dobro spakovanog Shunt napajanja. Shunt mu dođe otprilike kao neko napajanje u čistoj klasi A, i sa njime nema šale. Ja ga koristim u dva moja modela pojačavača za slušalice/predpojačavača, i prezadovoljan sam. Onako lepo, zdravo se greje, jeste da traži propisne hladnjake (malo zezanja sa bušenjem rupa i montažom, ali ništa posebno strašno), ali brate, to radi samo tako, milina. Njegova mana je samo u tome što nije pogodno za velike potrošače, realtivno brzo postane kabasto. Njegova prednost je u brzini odziva - vreme reakcije je tačno nula. Bržeg nema.Ko ne veruje, neka sklopi onaj Shuntyy - ne verujem da ćete igde naći bolje, ono je toliko blizu savršenstvu da ja nemam reči. Autori su ovdašnji Admin Choky i moj kolega, saradnik i prijatelj Oliver Isailović, a ja im i ovom prilikom skidam kapu na tome što su ga bacili u javno vlasništvo i time ga učinili lako dostupnim svima. Svaka čast!Dobra alternativa Shunt napajanju je tzv. virtuelna baterija. Vrlo jednostavan i kompaktan sklop koji sjajno radi ako se sve dobro ugodi. Sve se vrti oko zenerke na gate-u nekog MOSFET-a, iza koga se opet nalazi jedan poveći elektrolit, plus eventualno još neke varijacije. Obzirom na veoma razumnu cenu IRF MOSFET-ova, čak i ekonomski gledano, to je odlično rešenje. Dodatna varijacija u sistemu može da bude ono što Admin Choky obožava, a to je predregulacija celog sistema na recimo +/- 24V, a onda lokalna regulacija na svakoj pločici na recimo +/- 15V, itd. Lično ne verujem da to doprinosi zvuku, ali to ostaje otvoreno pitanje. Sa druge strane, ideja da se koristi lokalna regulacija je, po meni, ispravna i dobra; sistem se pasivno isfiltrira velikodušnim elektrolitima, pa se onda lokalno stabiliše po pločicama. Time se preslušavanje svodi na gotovo nulu, ide u akademske brojke.Da ne gušim više, po meni, nikada ništa pametnije nećete uraditi za svoj audio nego da pojačavač snage stabilišete. Jeste skupo, nije lako za napraviti jer je to praktično drugi pojačavač snage, ali efekti mogu biti zaprepašćujući. Kao kada odjednom, ničim izazvan, neki tranzistorski pojačavač uleti u stado cevnih pojačavača sa čekićem. :-)))))))) Međutim, ovo je skroz van ove teme. Imam jedan zanimljiv rad izložen na jednom od AES konvencija na ovu temu. Ako nekoga zanima, neka mi se javi, nema problema da mu pošaljem tah PDF fajl. Ili, ako Admin tako želi, mogu ga poslati Admin-u, a on neka ga postavi ovde u neku Download sekciju, to je javni dokument, ako i niz drugih, recimo Hawksford-ovi radovi, riznica znanja iz koje bi mnogi od vas naučili štošta i koješta.
  32. dvv
    Sreća možda jedino utoliko što si ih ipak zamenio. Inače je to zdrava logika.Kapacitet elektrolita je samo jedan od čitavog spiska podataka o njima. Za dobar deo ni nema početnih podataka - na primer, koliki je gradijent promene napona (Voltage Slew Rate, ? V/uS), koliki je gradijent promene struje (Current Slew Rate, ? A/uS), unutrašnja otpornost, itd. Sve te osobine će se vremenom menjati i tu nema boga, zub vremena ne zaobilazi bilo koga ili bilo šta, samo je pitanje koliko. Prvo što u elektrolitima strada je upravo njihova brzina, koja polako degradira vremenom.Ko ima opremu i ne mrzi ga, neka proveri vrednosti elektrolita starog 10 godina u odnosu na specifikaciju koju mora da zadovolji pre nego što izađe iz fabrike. U većini podataka će biti promena nagore, a tačno koliko opet zavisi od niza elemenata. Ali, nema tog elektrolita, od bilo koga, za bilo koje pare, koji posle 10 godina rada ne degradira dovoljno da se zamenom odmah čuje razlika. Negde je to od kritičnog značaja, a negde nije, nisu svi jednako odgovorni za zvuk koji čujemo, ali ako ih imate na ulazu i u povratnoj sprezi, menjajte ih ne kasnije od 10 godina. Prvo što strada je brzina, drugo počinje da mu raste unutrašnja otpornost, i treće, počne da raste rezidualni induktivitet.Najzad, ne stare svi oni isto. Najbrže i najviše stare klasični elektroliti, folijski daleko sporije, a tantal i srebreni liskun gotovo da i ne stare. Najzad, višeslojni keramički praktično ni ne stare, degeneracija je ispod 0,1% godišnje, što i jeste razlog ozbiljnim cenama i teškoćama oko nabavke, jer nema boljih.
  33. Izgleda da ne vole bas D-klasu reko mi Aca da stavim i L osim konda u skretnici Poceo kao rupa u sredini dok pucao skroz...
  34. dvv
    Nema na čemu, stvarno, pa ovde i jesmo da bi smo se pomagali. Sem toga, lako je odgovoriti na jasno postavljeno pitanje, problemi nastaju kada onaj koji pita ne ume to jasno da izrazi.
  • Trenutno na sajtu   2 članova, 0 Skrivenih, 1673 Gosta (Pogledaj celu listu)
