ZELMAN -
Bon za osnovne namernice.1994 godina.Tačno 32 godine unazad.Imam jedan uramnjen kao uspomenu, stoji na vr' televizora, da se ne zanesem ovako povodljiv -
SKYNET...tzv AI. Sto se terminatora tice, ima neki lik koji se zove T.... -
jbmti sreca tek kuvam kavu -
Joe Henry "Scar" Joe Henry – vocals, keyboards, guitars, percussion Brad Mehldau – acoustic piano Marc Ribot – guitars Meshell Ndegeocello – bass David Piltch (as David Pilch) – bass Brian Blade – drums, percussion Abe Laboriel Jr. – drums Bobby Malach – reeds Ornette Coleman – alto saxophone solo
ovo je još luđe...da snime dokumentarac o ovome i niko ne dobije kintu
