Video sam kod Aksjan... EC8010 za 22 Eu komad, znam da to nije isto sto i EC8020 ali mozda vredi razmotriti.... Ja bih rado kupio par komada samo za neku drugu aplikaciju.
Ma užas !
Ma užas !
nije za boraniju da razmislja o tome ene, vise volim to videti od kojekakvih naglancanih ko mudo pasije, stotine iljada kostaju kutije a driveri sve zajedno 2000
Ma zezanje sa 20volti napajanja za grejanje cevi, mala struja, a zvuci lošije od D3a.
Mozak sigurno mora biti uništen prije nego što se odluči dati 285000€ za driver prije shipinga, carine i poreza i prije nego što znaš kakvu hornu možeš sabi izgraditi.
"destroys the brain" Da li je to moguce!!
Ma užas !
100 kg Bass Compression driver The ALE Acoustic P160 is a high-end, low-frequency (LF) compression driver known for its massive size, weight, and use of premium materials like titanium and powerful permendule magnets. It is handmade in Japan by ALE Acoustic, a company that specializes in horn-loaded speaker drivers. The ALE Acoustic 160 D (P160) is a high-end, heavy-duty low-frequency compression driver specifically designed for use with very large, custom-built bass horns. It is not a conventional cone woofer and requires specialized horn designs to function optimally. Japan has the most developed horn speakers in the world. With agile and powerful bass that cannot be produced by cone-type speakers. A sound on a different level from that produced by cone-shaped woofers. The ALE ACOUSTIC 160D is said to produce indescribable bass that destroys the brain. The horn driver that produces ultra-low frequencies is a Japanese special product that is the only one of its kind in the world, and it is truly awe-inspiring. This is a valuable driver that allows you to delve into the depths of Japanese Horn technology. The price of the Er Acoustic Horn System is for all top-of-the-line drivers, excluding the cost of manufacturing the Horn. This is a system that can be completed by paying a total of 50,399,000 yen (KRW 544,178,162). If you add up the cost of production settings for each position’s horn, the system costs around 700 million won. This is the most expensive horn speaker system in the world. It is more expensive than the American-made western electric horn system. Specifications Bandwidth: 15 to 1KHz, Recommended Crossover: depend on suitable horn, Impedance: 8/16 Ohm, Maxmum Input: 70W, Output Sound Pressure Level: 110dB, Throat Diameter : 130mm, Diaphragm: Titanium, Edge is FRP, Magnetic Density: 23,000 gauss, Dimension: 250mm diameter x 420mm hight, Suitable Horn: must be design to fit the listening room, Weight: 100kg, Note: using alnico and permendule magnet, Made in Japan
C3M je jos uvek u cenovnom rangu D3a, koliko vidim mnogu su pravili 300B SE sa njom u pentodnom rezimu.
Starzin - Juče
Queens of the Stone Age
Thapelo K -
Probajte ovo.
Jezdim iz Alemanje u brzom vlaku i klimam glavom kao ludjak, susprezem se da ne kriknem zajedno sa Milanom, malo manje uspjesno susprezem prste da ne sviraju zajedno s Magi i stopala dok pomazem Bojanu i Ivanu da drze ritam. Cak i da sam bio dovoljno star, a tada sam bio trinaest, da budem u Kulusicu tesko da bih shvatio cemu svjedocim. To ne znaci da ih vec tada nisam volio. Opcinjen sam bio njima jos dok sam prvi put na televiziji u emisiji "Hit meseca" vidio "Decaka iz vode" iako nista nisam shvacao, shvacao sam da je to nesto potpuno drugacije od Prljavog kazalista ili Bijelog dugmeta, tadasnjeg mainstreama. Evo idu vec drugi put zaredom. Ostali putnici su prestali gledati u mene. Shvatili su da imam slusalice u usima i da se ne borim vec sat i pol sa serijom epileptickih napada. Link na cijeli popis sa Live in Kulusic 1986.
Ne. I ja ga vidim Nego, sto se tice ovoga sto rece Carl Sagan; politicari se trenutno ponasaju ovako: -
Quattor je odgovorio/la Mikorist's temus u Muzika , Film i Fotografija
Jel' samo ja vidim iscerenog klovna u ovim pečurkama? ;-) -
Mogao sam postaviti i u sportsku temu, ali mislim da ce ovdje vise ljudi imati priliku vidjeti interview u kojem sam uzivao od prve do zadnje minute toliko da sam zamalo postao navijac Partizana u kosarci! -
Blacksuga -
To je superlativ superlativa. 😂 -
Don Thiza -
Hvala.Banat probacemo ovo
Trenutno na sajtu 6 članova, 1 Skrivenih, 124 Gosta (Pogledaj celu listu)
Ukupan broj tema446.9k
