  1. Juče
  2. copy-paste sa bigdiya https://www.diyaudio.com/community/threads/tatanka-se-and-balanced-preamps-presentation.430799/post-8333010 finally got time to put my own in case ..... as usual - industrial design - workshop/demo specimen through years, amassed number of Dodo gadgets, and using those cases for traveling prototypes and demo units two boxes ticked - nobody will buy those and there is no harm when denting elevator doors this one put in case of some weird PA duty double cassette deck and yes, this one is Bal, so serving as simple SE and Bal demo unit ......... even found use for slightly damaged/bad TFT - having dead vertical line; good enough for ZM's own at least nothing is rattling in remote ...... as is case with someone I know ....... he said - "they are always giving me leftovers "
  3. Taman da malo skreneš misli sa kutija.
  4. Jašta je...al' k'o što jedan mudar čovjek reče: Dobro je, da je imalo bolje odma' bi sve đavo odnio.
  5. Ne mere se izvaditi, mora rupa nova. Maltretiracu lea 😁 Nego uzeh veceras malo da se igram sa x4 ad1865 daci sa custom nutube i/v resenjem, da se videti po slici od kako ga skockah, da je hvatao prasinu. Zbog prirode nutuba, distorzija preko 1Vrms na izlazu skace drasticno, pa sam se malo pozabavio setovanjem, i dosao so lepoh cifri 1.99% H2, 0.5% H3, 0.16% H4, 0.25% H5. Na uho, jako zadovoljan. Malo vecernje razbibrige
  6. Ako nista, u istom smo sosu 😁 bar je zabavnije tako u drustvu 😅
  7. Ima nas takvih i previše ako te to imalo tješi.
  8. Ki u njegosa. Jos sam ja baksuz, u dzaku p*cki uvatim se za k*rac... No dobro, vnutri je cini mi se uradjeno kako treba. Tako da funkcionalna su kucista, samo estetski ce trebati dorade. Sam cu, i toeto. Danas sam uzeo sa obrtnom turpijom da probam ivice unutra da obaram, i ide, drasticno brze nego rucno da turpijam, ali mora i rucno da se doradi za bolji finish. Bice do kraja meseca zavrseno, jos da se skanim skretnicu da skockam.
  9. Ovde majstora da tražiš sa fenjerom. I opet je pitanje da li ćeš ga naći. Svi koji stvarno znaju posao rezervisani su po tri meseca unapred. Ako ti klima sad rikne, gotovo, sjebao si se. Voda? Struja? Sve neki priučeni likovi, došli juče sa aku-bušilicom i već danas imaju firmu, logo i cenovnik kao neurohirurg. Masa dobrih majstora otišla je u UAE. Ovde su ostali ili prebukirani, ili nedostupni, ili čovek koji kaže: „Ma znam ja to”, a onda tri dana kasnije traži na Jutjubu gde ide nula i faza.
  10. Ni meni nije jasno, tj. sasvim mi je jasno... Ali kasno. Lekcija naucena.
  11. novi Stones...
  12. Pre nedelju dana
  13. Au, Radosave....ne znam, ništa mi više nije jasno. Nadam se da će izdobriti, odnosno da ćeš uspjeti to sanirati.
  14. Skinuh foliju, i imadeh sta da vidim. Otaljanus maximus. Zovem coveka, kazem da bas nije ok, dao sam toliko vremena mimo dogovorenog, nit se cenkao za novac, nista, maksimum tolerancija, i ni da izgituje. Kaze gitovano je, reko covece nije evo slika. Kako je bilo samo kutija (sto mi je slao prethodno) tako i sa farbom, prelazi, neravnine, nije ni podloga samo predjeno valjkom. Veli dobro dobro resicemo, i izdumam u sebi necemo, ja cu. Ovako cu da skockam za sad, pa kad smognem vremena ogulicu farbu, izgitovati i neki furnir nabaciti. Nekako sam bas bas skenjan, toliko vremena za ovakav epilog....
  15. Ama znam, ja sam mislio nešto učinkovitije, kao oduzeti ama baš svu imovinu rodbine dotičnog, pa nek' se oni obračunavaju sa njim....Ne zamjerite, ja sam dokazao nebrojeno puta da sam "na svoju ruku", morbidnog razmišljanja, škorpion, itd.
  16. probali ljudi sa Talmudom, Kuranom i Biblijom, pa ne ide
  17. Ja već dugo mozgam (???) o tome može li se iznaći neki "protokol" protiv prevaranata ali sa globalnim posljedicama, ne samo po dotično g**no nego i po njegovu familiju do 9 koljena? Izvini Zerowaf što trujem temu ali prevršilo je sve zakone (prirodne, Božije, civilizacijske), nije mi jasno ako već ne poštuju ostale ljude, poštuju li svoje najbliže i sebe.....
  18. Ukratko, pederlazov. Samo sto si naleteo tamo gde ne ocekujes... Tako da moze nazvati uredjaj: Mutiaqua opto no-logic
  19. Točno to što Zen kaže. Mislio sam da je jasno da DAC radi, kako bih inače znao kako radi, zar ne? Ali radi zato što sam morao otići u BIOS i isključiti nekakav sigurnosni protokol. Ako ga uključim, on će opet pročešljati drivere i blokirati mi driver za La Scalu. Nikako ne mogu reći, iako meni ne smeta, da je gašenje sigurnosnog sustava u BIOS-u nešto što korisnik treba raditi da koristi komercijalni uređaj. A ako i je, to se treba staviti npr u user manual. Teorija da je uređaj danas absolete je glupa zato što je ista situacija bila i 2025. kada se još uvijek mogao kupiti novi uređaj. Problem je, ponavljam opet, u tome što mi je u prvom mailu rekao da je driver potpisan. Pola sata kasnije da nije potpisan, ali da sve radi na USB protokolu. Naravno da ne radi. Onda je, još uvijek u istom mailu, rekao da sam kupio nemalo vintage uređaj ne spominjući da ga je prodavao novog još prije manje od godinu i pol dana. Zatim je u istom mailu rekao da kupim mkIII ako hoću driver, pa je nastavio s optužbom da nisam voljan uložiti novac, pa me optužio da žicam od njega nešto besplatno (sve u istom mailu!!!) i blokirao mi mail adresu. To je kao kad dođeš kod cigana kupit konja kojem je zadnji zub ispao prije 15 godina i kad to primjetiš on počne vikati da si sirotinja i da nemaš novaca za njegovog konja i da bi htio da ti ga pokloni, pa te još otjera s vašara. Nije više do konja. Konj ti s ei dalje sviđa, ali za takvo ponašanje se inače obere šamarelica.
  20. ene, cela situacija oko samih drivera nije problematicna (vise) - reseno je kako razumeh, gorak ukus ostavlja prvenstveno odnos proizvodjaca ....... take money and run
  21. ama radi, kad iskljuci signature sta je, tu je za Softone phono mu ne treba signature, tako da duplo golo idemo dalje
  22. Dobri nas Zero, ne razumem se bas ali moram da pitam, zar nije jednostavnije i jeftinije zameniti komp, windows i drajvere masinom i softverom koji ce podrzati novi DAC? Kad je vec talijan takav kakav je i kad se ponasa tako kako se ponasa.
  23. Ako neko slucajno ima od recimo ovakvog nekog neispravnog unimera kupujem originalno kuciste za moj stari Madjarski analogni unimer -UNIGOR 1- .
  • Trenutno na sajtu   0 članova, 1 Skrivenih, 166 Gosta (Pogledaj celu listu)
    452.1k
    Sanjalica
    Sanjalica
