asimze je odgovorio/la Mikorist's temus u Muzika , Film i Fotografija
Malo ti se čini! Nije puno ofulao! Samo što bi kuča zarasla u šiblje visine 2 metra i nebi mogao priči kuči. Ne zaboravi Aleks korov stigne .... Balašević! - Danas
Khaya -
Ma, hteo sam da napisem, ne propada krov bas ovako za 6 godina Definitivno AI -
U prozorcicu Edit za vrednosti kondenzatora treba postaviti i odgovarajuci series resistance za primenjeni kondenzator. Evo ga i proracun impedanse trafoa iz PSUD2 help-a : Edit Transformer Properties Enter the voltage for the secondary of the transformer. Note that this must be the off-load voltage, which is generally higher than the rated voltage of the transformer. For full wave rectifiers, use the voltage for one side only. For example, if the transformer off load voltage is 350-0-350V (700V end to end), the correct value to enter is 350. Enter the source impedance of the transformer. If you don't know this, you can click on the [...] buttons to invoke the off load voltage calculator, or source impedance calculator respectively. Source Impedance Calculator The source impedance of the transformer is required in order to simulate the transformer "sagging" under load. Supply voltage: (VP) The voltage primary supply into the transformer, normally 110/115/220/230/240 volts. Winding resistance: (RP) The measured resistance of the primary winding. Off-load voltage: (VS) The measured voltage on the secondary of the transformer before any load is applied. Winding resistance: (RS) The measured resistance of the secondary winding. Resistance for simulation: R.equiv = ((VS/VP) x RP) + RS
To je izvesnost života. Svaki dan neko negde odlazi. I mi ćemo kada nas pozove. C' est la vie. Ne klonjavajte duhom -
Mozda, ali je bas to surova realnost mnogih koji su otisli, neki na drugo mesto, a neki na drugi svet... -
AI kreirana fotografija. Manipulacija emocijama. Put u prvom planu i vrh krošnje drveta u drugom planu 15 godina nepromenjeni. -
ST se vratio ! Trijumfalno !
Naravno da se drogira, najverovatnije Elsold tamjanom -
Kod mene je negde oko 35-37 Ohm-a mada sam ja trazio ako je moguce da bude nesto vise.
Na ovim mreznjacima RDC-HV sekundara je oko 45-Ohma mereno sa kraja na kraj.
Koliko znam uzima u obzir pogotovo kad se ima trafo sa izmerenim DCR primara i sekundara. Ono sto ne uzima u obzir je indukcija trafoa koja je kod mene 0,91T - generalno trafo je projektovan tako da se ne greje puno i ne bi trebao biti drasticno opterecen ( takodje pored HV sekundara postoje sekundari grejanja sto PSUD2 u ovom slucaju ne uzima u obzir ). Hvala !
Krco ne znam da li taj PSU simulator uzima u obzir unutrasnju impedansu HV sekundara mreznog trafoa ? , jer ona nikada nije Z=0 , sa druge strane znam sigurno da pri ukljucenju hladnog pojacala udar na grec znacajno smanjuje i odvlaci velika startna struja grejanja svih lampi , ali isto tako i oni 10R/7W-10W redni otpornici imaju znacajnu ulogu na zastiti greca od strujnog pika , licno cu tu da koristim kvalitetne 4x1N5408 diode , na kraju moram ti reci da licno nikada nisam imao problema sa ovakvom konfiguracijom ispravljaca a napravio sam ih podosta . ps,veliku ulogu u ``cistoci`` HV-DC linija ima to sto je srednji kraj HV sekundara vezan izmedju dva redno vezana 220uF konda .
krca44 je počeo da prati člana Iskra KOO-041 (1952 & 1957) kino pojacala prepravka za kucni HI-FI
Hvala ! Pitam mahom zato sto sa grec-om i rednim otporom od 10R u pozitivnoj DC grani i prvim kondom od 100 uF - simulacija kaze da cu u prvih 5 mS imati skoro 7A peak ( opterecenje od 0,15A ). Grec diode ( 1N4007x2 konfigurisan grec, dakle ukupno 8x 1N4007 ) moze to izdrzati a mogu i diode / grec koji cu nabavljati samo me muci to teorijsko simulirano ponasanje i dejstvo na kondenzator ( ako stavim 47 uF onda je taj inicijalni udar 3A ). Generalno simulacija prolazi bez problema u zadatim vremenskim uslovima ( PSUD2 ) samo ne znam kako bi se ponasali kondovi u praksi - za napone od cca. 460 Vdc / 0,15 A mogu koristiti elko redno vezane + otpore kao sto si ti uradio ili vrlo skupe MKP od 800 Vdc ....
Trenutno na sajtu 3 članova, 2 Skrivenih, 85 Gosta (Pogledaj celu listu)
Ukupan broj tema450.5k
