AQUATONE -
Unazad 15+ godina posedujem CD origigi ovog Soundtrack-a. Nekako se sve fino sklopilo, te pre kojih par meseci pazarih i ovaj LP sto je upravo bio na VPI "tanjiru". Siesta - namerno pisem kako treba : Marcus Miller & Miles Davis. Zasto ? Pa ovde je predobri Markus odradio 90% posla. Razvalio ( a i "potpisao" album sa svojim prepoznatljivim solazama, tonom i karakterom bas gitare ) sa svojim osnovnim instrumentom, ali otisao i dalje ( pogledati sliku no. 3 gde se vidi ko je jos ucestovao na albumu ) - aranzmani, klavijature, ko zna sta vec ? A da, u programiranju mu je zdusno pomogao Jason Miles. Elem, namerno slikao deo omota gde su "gosti". Uglavnom na naslovnoj numeri Siesta. US izdanje ( vrv neko Re ? ), mint kondicija, me happy. Preporuka za imati u bilo kojem formatu ( atm "skidam" film po ne znam koji put da pogledam. Ellen Barkin & Gabriel Byrne ) . Evo i jedna trivija : Just a moment... WWW.THELASTMILES.COM Siesta: Engineer Steven Strassman recalling an incident in the studio with Miles “Miles suggested we take a walk. We would occasionally hear sounds from other studios coming through the wall and he’d ask who it was. I remember us walking into a Metallica session and we were standing in the back of the control room and the music is super-loud. Miles leaned over to me and screamed in my ear ‘these guys really suck!” I couldn’t hear him and so he repeated what he said – just as the music stopped!”
Nedoumice u vezi mehanizma kasete
diyAudio.rs Linux OS
Sve hakeri nikom ponikoše..... -
Uh, posle crnih hakera, belih hakera, samo nam je falio AI Master Haker ili još gore armija AI hakera.
Ajde sad nešto ozbiljno. (kao do sad nije bilo) AI Disassembles 1986 6502 Code, Reveals Logic Errors | Mark Russinovich posted on the topic | LinkedIn WWW.LINKEDIN.COM AI’s ability to find vulnerabilities is amazing, and its ability to reverse engineer machine language is shocking. For fun, I tested them with a binary listing from a 1986 COMPUTE! magazine article I wrote: "Better Branching in Applesoft." To my surprise, the AI didn't just disassemble the 6502 machine language; it reconstructed the logic with accurate labels and comments... Zanimljiv post....... U postu je Mark Russinovich dao AI modelu da analizira njegov Apple II program iz 1986. napisan u 6502 assembleru. AI je: dekompajlirao mašinski kod..... razumeo logiku programa.... pronašao nekoliko bugova i potencijalnih ranjivosti...... Poenta posta nije Apple II nostalgija, nego nešto mnogo gore............. Postoje milijarde legacy mikro-kontrolera koji rade firmware koji niko nikad nije auditovao. industrijski PLC........medicinski uređaji........automobilski ECU........IoT firmware........stari routeri..........BIOS / UEFI...............stari kernel moduli............... Šta je problem ovde legacy code + nema source + nema maintainer + nema patch pipeline AI sada može: da decompile firmware pronađe memory corruption analizira control flow pronađe logic bugove HAKER može skalirati research pomoću AI. AI analiza call graph - taint flow - predlog exploit path AI može da bude automatski vulnerability researcher = PAKAO ZAKLJUČAK najveći talas exploita/virusa u istoriji softvera i sveta.
Kome je postavljeno pitanje meni ili @Aleks ? JA sam napisao iznad a i pre. Sve što je starije od 7 godina ide u kantu za smeće kod mene..... PONAVLJAM - Može da se natera da radi takav PC, ali to postaje stalna borba i posebne verzije sistema, stari browseri, podešavanja… i opet često neće raditi stabilno. U jednom trenutku više vremena ode na krpljenje nego što vredi sama mašina.
Sta bi uradio sa tim ,,Mac mini 2012,,? Pitam zato sto imam Mac mini late 2014.
Ma ja nekad pretjeram sa pitanjima, tebi hvala sto odgovoris i pomognes To jeste ima onih koje ne valjaju, jos ako je snimak truba onda dzabe. Najdraze mi je sto sam od tifa benda presnimio. Ta ima najbolji zvuk i jako malo osciluje brzina na deku. Nije to ne znam kolko oscilovalo dok nisam stavio zamajac i lezaj sa donora al opet bolje je sada.Jebes ga, time sam ga utegao jer je stari zamajac izgleda busen po 3 4mm u pokusaju da se balansira al dzabe su krecili
e brate, nije im neka vutra cim se tol'ko pate
a ne moras se izvinjavati .......... no je jednostavno - ako je kaseta dobra, dobra je ako ne valja, spasavaj samo retke snimke gde je tape jos u korektnom stanju ako nije redak snimak i korektan tape, nema racuna za trud a dek, ako je mnogo izbirljiv za kasetu ....... nije dek nego drek dobar dek je kao traktor - sve radi kako treba i ne bira
a jbga ne bih da dizem frku, kod nekih kaseta ka svakom kasetofonu malo osciluje brzina, kad je prepakujem onda radi bolje. Ne volim da otvaram temu zbog svake sitnice al nisam pametan kako bi islo pa reko aj da pitam mora neko znati Izvinjavam se
ajd ne drami ....... kaseta kako je sastavljena, tako i treba; kod nekih je ovako kod nekih onako a dek ako zbog toga ne radi ......... ili popravi ili u kontejner ako ne moze da se popravi
Kad prebacim da ide i preko tog dilcika, unutarnja strana bi strugala od njega Obe slike su kad je traka u nategnutom polozaju kao da svira
tako kao na slici, da ne drlja magnetni layer po plastici
Dobro vece, kao sto naslov govori imam par nejasnoca u vezi mehanizma u kaseti. Otvorih novu temu, jer nisam nasao neku slicnu ovoj. Muci me putanja same trake, da li treba da ide samo preko tockica unutra u plastici ili je staviti tako da ide i preko onog fiksiranog stubica. Imam jednu pgp-ovu providnu pertlovanu i na njoj ide preko toga, na nekima ne. Od ovih konkretnijih kaseta, ili su pertlovane ili su vec rastavljane da se popravi uvodna traka pa ne mogu biti siguran kako je bilo dok neko nije rastavljao. Neke kasete kojima traka ne ide preko tog dilcika kao da pomalo zavijaju (malko me i dek jebucka oko toga ali se da cuti i na drugim skupljim dekovima) Ne ide mi u glavu ima li to kakve veze sa duzinom same kasete pa da zato neke kupovne to nemaju tako provuceno, ili je to mozda zbog ubrzanja proizvodnje
Ludilo mozga
Trenutno na sajtu 5 članova, 1 Skrivenih, 112 Gosta (Pogledaj celu listu)
Ukupan broj tema450k
