  2. asimze
    diyAudio.rs Linux OS
  3. Juče
  4. Bogdan08
  5. Zen Mod
  6. Bogdan08
  7. Bogdan08
  8. Zen Mod
  9. Bogdan08
  10. Pre nedelju dana
  11. Bon za osnovne namernice.1994 godina.Tačno 32 godine unazad.Imam jedan uramnjen kao uspomenu, stoji na vr' televizora, da se ne zanesem ovako povodljiv
  12. SKYNET...tzv AI. Sto se terminatora tice, ima neki lik koji se zove T....
  13. Propo Konor od rakije, nema ko da nas brani od AI
  14. Joe Henry "Scar" Joe Henry – vocals, keyboards, guitars, percussion Brad Mehldau – acoustic piano Marc Ribot – guitars Meshell Ndegeocello – bass David Piltch (as David Pilch) – bass Brian Blade – drums, percussion Abe Laboriel Jr. – drums Bobby Malach – reeds Ornette Coleman – alto saxophone solo
  15. ovo je još luđe...da snime dokumentarac o ovome i niko ne dobije kintu
