  2. Bogdan08
  3. Zen Mod
  4. Bogdan08
  5. Zen Mod
  6. Bogdan08
  7. Juče
  8. Da napisao sam sličan tekst. Dao mi ovaj ideju
  9. Večernje Novosti
  10. Bogdan08
  11. Pre nedelju dana
  12. Natasha Agrama Jazz singer from Hollywood, CA. Comes from a deep musical heritage: her grandfather was Antonio Prieto, one of the most renowned and popular singers in Latin America. Her stepfather is the legendary four-time Grammy award winning jazz bassist and composer, Stanley Clarke.
  13. Bogdan08
  14. Zen Mod
  15. Bogdan08
  16. Zen Mod
  17. Bogdan08
  18. Kej 95 - Stari Slankamen. Somovina, šaran, smuđ - roštilj ili prženje po izboru. Cene izuzetno prijateljske obzirom na okolinu ( NS i Bgd ). Početna | Restoran KEJ RESTORANKEJ.RS
  19. Belo brdo riblji restoran, najbolji fileti soma koje sam jeo!
  20. č kao "bašča sljezove boje"
  21. Ko onaj vic: Zemlja je okrugla, a j*bu se na svakom cosku!
  • Trenutno na sajtu   4 članova, 1 Skrivenih, 118 Gosta (Pogledaj celu listu)
    453.4k
    milos68
    milos68
