Showing content with the highest reputation on 01/14/22 u svim oblastima
  1. pronadjem malopre u riznici stiroflex Siemens Halske 120000 pF 630V, 5%. budze, ali nece mi biti zao da ugradim po 4 paralelno. ako ne nadjem neke druge munje nebeske.
  2. Mrzi me da tipkam, pa copy paste sa Big Diya: Well, I'm certainly not first one to ask Modushop Team is there solution for slim Monoblock case .......... Anyway , recently I did chat with our Italian friends ...... and thet are evidently willing to do something Basic idea is to have 4U/400 case, but narrower Entire package, (hoping they did understood my ZMEngrish) consisting of 3 iterations: 1. first logical iteration is one side having 4U/400 heatsink ( I don't care is it one piece or two) , while other side being blank plate ; you can orientate it by wish, so wth pair having one right and one left enclosure 2. second logical iteration is heatsinkless case, intended for separate PSU ( don't ask, I'm first one thinking of pair of cases per side, just as Demonstration of Force, if not necessity) ....... so penny-pinchers among Greedy Boyz can make one (pair) of mono PSUs and zillion of channel cases, then combine them Till End of Time 3.third logical iteration is both sides having heatsink, so you can squeeze nicely thought elegant Beauty of Amp inside ........ from whichever reason - easier to smuggle by Kerber, or esier to put more of them on shelf ..... or you just like them that way set of preliminary pictures enclosed, raw finish, not anodized ......... my Vote goes to front plate (as usual) covering entire width, including heatsinks What ya say ? Basic dimensions are sorta carved in stone ( zillion Greedy Boyz, zillion and one opinion) so don't bother to change that; what I'm asking now is - what you say for width of front plate ........... and do you have any (useful and beneficial!!) idea to add? Unification reasons (price for Greedy Boyz) - dimensions of "cage" itself must be the same for all 3 iterations; Now - I like idea of full width front for case with one and 2 sinks, I like the same for heatsinkless one - when looking them in pair, and I'm sorta ambivalent when thinking about empty space behind wide front plate without sinks; so...... as always - compromises......... I'm sure Gianluca will chime in, to give you details about width of case ...... I deliberately left that for him And yes, 'Talians - Danilo Petrucci is first man alive, after having 2 MotoGP victories, also claiming victory in Dakar stage for motorcycles Go figure; it must be something in the air or water, in Italy
  3. Meni se STK4162II i dalje najviše sviđa kako svira od čipova. Ubija.
  4. Mikorist
    preporuka za odvojni kond
    Evo Shindo šta stavlja. NOS SPRAGUE BLACK Beauty 400V 10%
  5. vladd
    Da da, MKP. Stirofleksima je imputiran kvalitet, iako se polistiren tretira kao nepolarizovani dielektrik, postoji blaga nesmetrija u jednom delu(fenilnom) koja uzrokuje odredjen dipolni moment. Stabilan za rc konstante i jednostavne oscilatore, pa mu je kvalitet preseljen na sve ostalo. Taj dipolni momenat je neperfektna osobina za ac upotrebu, implicira uvecane gubitke(vece nego kod ozbiljno nepolarisanih polimera, (MKP, teflon), pride se topi relativno nisko, pa nije za blizu vrelih lanpi.
  6. BANAT
    Ne znam kakve je kondenzatore Sax upotrebljabavao kao `orange drop` kondenzatore jer ih ima raznih , licno za mene je to uvek oznaka za vintage Philips MKT naradzaste kondenzatore na kojima to i jasno pise , ali koji su postali i izuzetno retki , isto kao sto su i Philips `mustard` kondenzatori , za ove MKP kondove iz serije 715P&716P ne sumnjam da su odlicni .
  7. NIXIE
    Polikarbonat je po kvalitetu nešto između poliestera i polipropilena. Nekad je i Wima to pravila ali ne viđam ih više.
  8. vladd
    Trenutno RTS2, novogodisnji koncert pod vodjstvom Sudjica
  9. NIXIE
    Uher VG820
    Ubaci nove, tolerancija elektrolitskih kondenzatora je velika, možda nije ni formiran još kako treba, možda je dugo stajao na lageru. Jel to izlazni kondenzatora ili onaj u napajanju? Ako je izlazni trebalo je zbog reprodukcije basa uzeti veći, 4700uF recimo, da bude tih dimenzija kao stari. Nije loše premostiti ga ako ima mesta sa barem 2,2uF poliester ili PP 100V. PS Kad se kupuju kondenzatori (oni za napajanje naročito) treba pogledati u datashhet max. ripple current, pa tražiti one koji imaju veću vrednost. To znači istovremeno da im je manji ESR odnosno da su kvalitetniji.
  10. Zen Mod
    Duplex 2SK369 Phono preamp
    dobro mu ime
  11. Sync
    Svi delovi poruceni. Izbor za linearno napajanje je pao na derivat Studer 900 sto zbog utisaka po big diya sto zbog smesne cene kod francuza: Audiophonics - Linear Power Supply board MJE15034G Low noise 4.8V à 24V 2A WWW.AUDIOPHONICS.FR Here is a very high quality regulated power supply with a very low "ripple", high precision semi discrete with a double layer circuit. Probace se naravno jos koje.. Riaa kondice (1.8u i 0.75u) sam uspeo naci wime mkp10. Vezni kond ruski teflon. Izlazni zeleni K75-10. Caki birao.. 😁 Jos samo da se dogovorimo sta za trafo.. ja nesto vucem na EI jer se na KP mogu naci povoljno fabricki sa 24v sekundarom.. Nece se ici na dual mono zbog smesne potrosnje i uredno resenog rasprezanja napajanja na samim pcb.
  12. to sto je tebi Accuphase dobar ..... je samo tvoj problem ako nemas vizury DIY-era, ne troluj drugima temu
  13. Ako je vakcinisan ne treba
  14. Doktor
    Odgovor je jednostavan :
  15. Doktor
    Ne slusam vise ploce . . . Na zalost. Pokusam na svaka 2-3 dana . . . . pokrenem . . . pustim . . . odslusam max. jednu stranu LP i ..... zatvaram/spustam poklopac. Nedostatak koncentracije, volje, cega li vec . . . nemam pojma ? Sa druge strane, LP-i su otisli sa cenama " u nebesa". Srecom, skupljala se kolekcija vinila decenijama, pa nema frke. Posle par meseci konacno nadjoh pristojne cene za ova dva vinila. Kupih. Sulcov Timewind bih platio i 4 x vise, ali stari/dobri/provereni dealer tacno zna kako i kada ce da popusti/ponudi i na tome mu hvala. Za Prelude sam od ranije znao, da je to bilo solo LP za kupiti, sigurno ne bih kupio, ali taman fino dobro doslo da se metne sa Klausovim remek delom da ce ne polomi ( imam veoma neprijatno iskustvo sa Postama Srb kada sam svojevremeno kupio veoma redak LP sa prostora ex-Yu, papreno ga platio, a dosao vinil napuknut na pola ). Samo da napomenem da ovog Shultze-a nisam imao na vinilu i da je konacno popunio "rupu" u mojoj polici gde ponosno stoji Klausova diskografija. Btw, jedan od njegovih kultnih albuma uz Moondawn, Cyborg i ostale njegove albume.
  16. dejanco32
    Koncerti
    Ceremonija otvaranja godine titule Evropske prestonice kulture-ekskluzivno na RTS-u WWW.RTS.RS Novi Sad će u 2022. godini poneti prestižnu titulu Evropske prestonice kulture, zajedno sa Kaunasom (Litvanija) i Ešom (Luksemburg). Srpska Atina je ujedno prvi od tri grada u kojem će biti održana ceremonija svečanog otvaranja godine titule, koje će obeležiti jedinstvena umetnička proslava u Evropi, "Doček", na više od 40 lokacija u Novom Sadu.
  17. Sad ne ali za jedno 5 godina smeo bi da sednem opušteno pozadi i da me vozi robot.
  18. Dabre, muskarac ne zna da krene pod rucnom, a zena moze tako da vozi ceo dan
  19. Doktor
    Hrana za dušu . . .
  20. djuma89
    Uher VG820
    NIje nesto lepo al je zato cvrsto😊 Taman ce da se hladi sa ove strane🤣 Čelik 1mm
  • Trenutno na sajtu   4 članova, 1 Skrivenih, 1924 Gosta (Pogledaj celu listu)
