  3. SHAVIJA
    GM70 / II (end of game)
    Ma preskup je svima ;) zasto sam rekao bas taj je zato sto je Duelund valjda pazario Jantzen ....e vidis tu se zahebah,al iz dobre namere, sad videh da je pazario Jensen,a ne ove...moja greska, zato sam mislio da bi ti legao. Uglavnom moze se isprobati ,promeniti vrlo lako, ne znam kako ste vi tada s transformatorima al vec vidim kako bi to bila mission impossible sada...kao ono, aj stavimo manji trafo kao bajpas na veci ... Ajde ne bde li te mrzelo, kad bude neko okupljanje (nisam u toku duze vreme,ne znam jel ima toga vise) i ta tvoja masina svirala ,pozovi da cujem na par minuta,miran sam gost, donosim poklone itd. Duze vreme razmisljam o nekom lampaskom ampu i za sad me golicaju 2A3 45 4P1L 300B tim redom... problem je sto su zvucnici 91dB na nekih konst. 4oma ...jes da soba nije velika al ne znam sta bi dalo najvecu glasnocu. The Duelund JDM capacitors are new off the production line at the newly revamped Duelund Factory. Now fully equipped with the Jensen winding and impregnation machines. JDM stands for Jensen Domestic Market, a nod to the recently closed Jensen capacitor manufacturing company that Duelund worked so closely with. They are constructed with wax paper in oil dielectricum, previously reserved for their top of the line CAST series. The paper separating the foils are vacuum impregnated in a deep vacuum 100 times lower, than what was possible at the old factory. Following this, the windings are also wax impregnated to help seal the winding completely. This formula makes an incredibly robust high performing capacitor at an amazing price considering they are constructed from copper or tinnedc cpoper foil. The outer material is made from paper. The capacitors , are potted inside using the same material as the CAST models.
  4. Juče
  5. Jbt koji vokal. Ko Svetlana Stević +Divna zajedno
  6. Lemić
  7. Bogdan08
  8. Bez secera-ko gvozdje bez bafera...
  9. Kako se pokazala ova zica zaa lampaske preampe recimo? Imam si sjajan DHT preamp ozicen ovom zicom, takdje imam i 2 problema...od ranije sam se istripovao da ne volim posrebren bakar i da volim punu bakar. zicu. Drugo, imam nestoNeoTech UP-OCC pun presek bakra u teflonu s kojim bi ilecio svoj trip ali davno je to bilo ,mozda gresim. Svi vidim hvale ovu Duvan&Co-vu zicu pa deder napishajte koju rec kakva je za signal...preamp/DAC itd. Ako ko ima koji intimni komentar nek sibne na PP. Uzvrvacam s ljubavlju, potreban info sto pre. Hvalal
  10. SHAVIJA
  11. SHAVIJA
    ChatGPT
  12. Pre nedelju dana
  13. Da imam iole pameti pa boca Jacka za sto i droge sta se nadje i pravo rokerski, ko u onom vicu bilo bi jeftinije Al posto nisam onda samo JD
  14. a da se ti sinko lepo drogiras, ko sva normalna omladina ?
  15. E bice da je to, nabavili mi manzetnu poluosovine a od homo zgloba nisu,mozda im zapeo vremeplov Al sto je najveci vic i jeste tako, juce danju prepravljaj unitrin space shuttle pa cim padne mrak rasarafljuj sto-jadina i onda danas crkne od homozgloba...siguran put da popizdis i bankrotiras Al da to nije kolko tolko zabavno dok je mladosti nema sanse da bi zoru ceko pod bagrzijom
  16. bice da su te blokirali, trazio si od njih previse sitnih delova za stojadina ....
  17. Ima na mg nekih pa ce preberem. Nzm sto mi ne radi sajat vremeplov zadnjih dana
  18. improvise http://shop.vremeplov.co.rs/Shop/Product?name=Trimer-višeobrtni-1K-vertikalni-2%2C54mm&accountingCode=14140
  19. To obavezno ako nadjem dimenziju, ovi pipni ga ode za 5mv. Ovaj je klasican ko i original, samo viseobrtni necu moci multiturn zbog oblika
  20. stavi multiturn
  21. E da se malo i sa ovim cudom bakcem. Ocistih trimmere za mirnu struju i podesio, al kako djavo nikad ne spava bolje da stavim nove da ne razjebem komplet izlaz. Ima li neko neku preporuku oko toga, opet nije bilo sta. Na mg elektroniku samo ovaj ima CA9MV10-1KA2020, 1K je na mom ampu
  22. Baš nas briga sve dok je zabavno .
  23. E upravo to, uzmem tako cackam nesto i sitnica ti promakne i moze sve da pokvari.
  • Trenutno na sajtu   3 članova, 0 Skrivenih, 668 Gosta (Pogledaj celu listu)
    452.5k
    vygosovy
    vygosovy
