Showing content with the highest reputation on 01/13/22 u svim oblastima
  1. Evo rešenja ako često gubite naočare
    6 poena
  2. to sto je tebi Accuphase dobar ..... je samo tvoj problem ako nemas vizury DIY-era, ne troluj drugima temu
  3. Mikorist
    Da nije neki virus ? Pu daleko bilo... Ako jeste Sparkos ti ne gine
  4. Dabre, muskarac ne zna da krene pod rucnom, a zena moze tako da vozi ceo dan
  5. Doktor
    Hrana za dušu . . .
  6. Mrzi me da tipkam, pa copy paste sa Big Diya: Well, I'm certainly not first one to ask Modushop Team is there solution for slim Monoblock case .......... Anyway , recently I did chat with our Italian friends ...... and thet are evidently willing to do something Basic idea is to have 4U/400 case, but narrower Entire package, (hoping they did understood my ZMEngrish) consisting of 3 iterations: 1. first logical iteration is one side having 4U/400 heatsink ( I don't care is it one piece or two) , while other side being blank plate ; you can orientate it by wish, so wth pair having one right and one left enclosure 2. second logical iteration is heatsinkless case, intended for separate PSU ( don't ask, I'm first one thinking of pair of cases per side, just as Demonstration of Force, if not necessity) ....... so penny-pinchers among Greedy Boyz can make one (pair) of mono PSUs and zillion of channel cases, then combine them Till End of Time 3.third logical iteration is both sides having heatsink, so you can squeeze nicely thought elegant Beauty of Amp inside ........ from whichever reason - easier to smuggle by Kerber, or esier to put more of them on shelf ..... or you just like them that way set of preliminary pictures enclosed, raw finish, not anodized ......... my Vote goes to front plate (as usual) covering entire width, including heatsinks What ya say ? Basic dimensions are sorta carved in stone ( zillion Greedy Boyz, zillion and one opinion) so don't bother to change that; what I'm asking now is - what you say for width of front plate ........... and do you have any (useful and beneficial!!) idea to add? Unification reasons (price for Greedy Boyz) - dimensions of "cage" itself must be the same for all 3 iterations; Now - I like idea of full width front for case with one and 2 sinks, I like the same for heatsinkless one - when looking them in pair, and I'm sorta ambivalent when thinking about empty space behind wide front plate without sinks; so...... as always - compromises......... I'm sure Gianluca will chime in, to give you details about width of case ...... I deliberately left that for him And yes, 'Talians - Danilo Petrucci is first man alive, after having 2 MotoGP victories, also claiming victory in Dakar stage for motorcycles Go figure; it must be something in the air or water, in Italy
  7. Ako je vakcinisan ne treba
  8. Koje tiple preporučaš?
  9. Trojica u kamionu! Jedan je zadužen kao koordinator poslova! Poslova je malo, a naših rođaka puno, pa se moramo svakako snalaziti.
  10. NIXIE
    Uher VG820
    To je završeno, idemo dalje.
  11. Ovi naši verovatno ne bi ušli u 50m2 ni da im pokloniš.
  12. Mislim da bi Krell bolje odgovarao.
  13. Zen Mod
    @Doktor sdće vikend pripremi viskić, dobar masan, pa kreni ćvidiš kako će das otčepi
  14. Još ako je duplo kvačilo i medjugas treba ti faks da popamtiš brzine i naučiš kordinaciju
  15. Dvojica da voze. Jedan upravlja, drugi da menja brzine
  16. djuma89
    Uher VG820
    NIje nesto lepo al je zato cvrsto😊 Taman ce da se hladi sa ove strane🤣 Čelik 1mm
  17. NIXIE
    Uher VG820
    Mislio sam ovako nešto, viđao sam to, čak imam par komada kući. Ako su tanke, stave se po dve. 100 STÜCKE 48*16mm edelstahl Flache Klammern Gerade Linie Metallplatten Reparatur Befestigung Die möbel anschlussarmaturen K251|flat straight bracket|flat steel bracketsstraight bracket - AliExpress WWW.ALIEXPRESS.COM Smarter Shopping, Better Living! Aliexpress.com
  18. Hod ručice ceo metar.
  19. E kako su bila lepa ona vremena. Dve ručice menjača, 20 brzina, 100% zadovoljstva. Neprocenjivo!
  20. Ama ubediće ih kao i za vakcinu. Ništa se ne brini. Nećeš moći nigde da se zaposliš ako voiziš sam. Ako si anti-roboter - opasan si po okolinu i ugrožavaš druge.....
  21. ebeš mi sve vredi samo ono auto uparkiravanje nekima.
  22. vladd
    Uher VG820
    Osigurac pre tog tranzistora je 100mA...ili 0,1A, prema kolektoru tako da moze...
  23. Meni se to ništa ne sviđa, ona verzija sa dva hladnjaka kao bočne stranice i može da prođe a ovo svaka kutija po jedan hladnjak kao punjač za akumulator ili tako nešto.
  24. Žene su bolji vozači, je recimo numem da vozim i kucam poruke na mobilni, možda zato što nemam automatski menjač.
  25. https://www.instagram.com/p/CYoQXQYsy5t/?utm_source=ig_embed&ig_rid=60f0d01e-42c3-44df-9da4-a9c8d52fc287
  26. Doktor
    Odgovor je jednostavan :
  27. asimze
    Pogodi me u po srca! Schulze. A šta veli za Mirage? Mislim da bi trebalo ovima na forumu za elektronsku muziku uvesti pod obavezno da 7 dana slušaju Klausa pa tek onda da mogu objavljivati po forumu. Da znaju ljudi ko je velemajstor.
  • Trenutno na sajtu   4 članova, 1 Skrivenih, 1924 Gosta (Pogledaj celu listu)
