  2. Bogdan08
    A to da po klasi. Al ja mislio kako sam je doveo u red, zaista nikad sem jedne kasete nije guzvao, brzinu drzi okej itd itd al da ga ne falimo jer ce se pokvariti
  3. Zen Mod
  4. Danas
  5. Bogdan08
  6. Zen Mod
  7. Bogdan08
  8. Juče
  9. Da napisao sam sličan tekst. Dao mi ovaj ideju
  10. Večernje Novosti
  11. Bogdan08
  12. Pre nedelju dana
  13. Natasha Agrama Jazz singer from Hollywood, CA. Comes from a deep musical heritage: her grandfather was Antonio Prieto, one of the most renowned and popular singers in Latin America. Her stepfather is the legendary four-time Grammy award winning jazz bassist and composer, Stanley Clarke.
  14. Bogdan08
  15. Zen Mod
  16. Bogdan08
  17. Zen Mod
  18. Bogdan08
  19. Kej 95 - Stari Slankamen. Somovina, šaran, smuđ - roštilj ili prženje po izboru. Cene izuzetno prijateljske obzirom na okolinu ( NS i Bgd ). Početna | Restoran KEJ RESTORANKEJ.RS
  20. Belo brdo riblji restoran, najbolji fileti soma koje sam jeo!
  21. č kao "bašča sljezove boje"
  22. Ko onaj vic: Zemlja je okrugla, a j*bu se na svakom cosku!
    453.4k
    milos68
    milos68
