  2. Bogdan08
  3. Zen Mod
  4. Bogdan08
  5. Juče
  6. Da napisao sam sličan tekst. Dao mi ovaj ideju
  7. Večernje Novosti
  8. Bogdan08
  9. Pre nedelju dana
  10. Natasha Agrama Jazz singer from Hollywood, CA. Comes from a deep musical heritage: her grandfather was Antonio Prieto, one of the most renowned and popular singers in Latin America. Her stepfather is the legendary four-time Grammy award winning jazz bassist and composer, Stanley Clarke.
  11. Bogdan08
  12. Zen Mod
  13. Bogdan08
  14. Zen Mod
  15. Bogdan08
  16. Kej 95 - Stari Slankamen. Somovina, šaran, smuđ - roštilj ili prženje po izboru. Cene izuzetno prijateljske obzirom na okolinu ( NS i Bgd ). Početna | Restoran KEJ RESTORANKEJ.RS
  17. Belo brdo riblji restoran, najbolji fileti soma koje sam jeo!
  18. č kao "bašča sljezove boje"
  19. Ko onaj vic: Zemlja je okrugla, a j*bu se na svakom cosku!
  20. Bogdan08
    K: Remen 66x3x0.5
    453.4k
    milos68
    milos68
