Showing content with the highest reputation on 01/30/24 u svim oblastima
  1. Vix
    Fullrange, pa jos i dzabe
  2. Doktor
    Unbound - YouTube Music MUSIC.YOUTUBE.COM Provided to YouTube by The Orchard Enterprises Unbound · Alex Skolnick Trio Conundrum ℗ 2018 Skol Productions Inc Released on: 2018-09-07 Auto-generated... Stari znanac - Aleks Skolnik. Ovog Baju i njegov trio pratim unazad 2 decenije, praktično od albuma Transformation. https://www.discogs.com/master/527047-Alex-Skolnick-Trio-Transformation
  3. U istom jugonostalgičnom raspoloženju listamo EX YU kompilacije: Yugoton Funk Vol 1 "Yugoslavia - six republics, four decades, one dictator and a single record label that ruled them all: Jugoton (Zagreb, Croatia). Jugoton was by far the country's largest label with the strongest and most diverse output that stretched from Balkan roots to contemporary trends and the sound of tomorrow" Arsen Dedic - Punom parom, Marijan Kasaj - Ideja, Tihomir Pop Asanovic - Mali crni brat, Igor Savin - Alfa, Ipe Ivandic - Dzambo, Dalibor Brun - Davni zivot i još svašta razno. A pobedili su... Pro Arte, sa prog-psihodelijom Ko vječnu tugu nosi
  4. Prolupao sam , Welcome verovatno piše na telefonu kad ga starujem.
  5. I to sve ima jedan pregOreo.....
  6. Ni običnu muziku nismo savladali, a već jezdimo ka kvantnoj
  7. slusala mi zena neki dan, ja pribelezio za kasnije
  8. Koji god od tih starih...Jedan je preživeo pad sa 5 sprata
  9. 1 poen
  10. Brate Nokkia telefoni su radili k'o zmaj - ja i dan danas imam / koristim jednu malu dobru Nokkiu kad ne moram da nosim 100gr+ mini racunar u dzepu.
  11. ama skenirao lobanje osoblju iz sluzbe posle ekcesa sa UAP . kao nismo znali da je 700GHz letalno p.s. ako vidis NLO bezi koliko te noge nose od njega
  12. 1 poen
  13. 1 poen
  14. Doktor
    Honey Sweating - YouTube Music MUSIC.YOUTUBE.COM Provided to YouTube by Universal Music Group Honey Sweating · David Torn · Terry Bozzio · Mick Karn Polytown ℗ 1964 Silva Screen Records Ltd. Released on... Ozbiljna priča.
  15. Savršenstvo je kad ima mane sa kojima možeš da živiš, ali da, poenta je da su mi se kockice složile. Nisam nikad do sad pomislio “to je to” nego obično “to je skoro to” (tj. i dalje ima nešto sa čime ne mogu da se pomirim).
  16. Woland
    nikada ništa ne radi do detalja kako treba; u onom momentu kada to prestane da ti smeta, i svu pažnju usmeriš na muziku, tada prestaneš da budeš audiofil; istina je da se kockice sklope, ali ne kada je sistem doveden do savršenstva - to nikom nije uspelo moj je daleko od savršenog, količnik njegovih vrlina i mana je za mene prihvatljiv takav kakav je.. nemam potrebu, zapravo - ne želim, čak ni gajtan koji su mi doneli da testiram ovo je sasvim lični stav, nije primenjiv za svakog.. i nije nužno da bude
  17. Spakovah jedan mali dačić sa AD1865N-K. Čisto da potrošim delove od eksperimenata. USB ulaz samo, Amanero Kineski, odličan, radi sa originalnim drajverima. Ima i mali Oled displej, piše Welcome kad se uključuje. Nemam primedbi na zvuk. Trafo je 10VA Trafomatik, slepi navojak + magnetni oklop za svaki slučaj da se ne pojavi neki brum jer sve je jako blizu trafoa. Kutija 160x160x65mm plastična naravno. Treba još da secnem parčence klirita da ga turim ispred displeja i fiksiram displej. I može da se zatvara.
  18. Oprez! Od ovog mož' das' rikne! 4 lica Jazza Davne 1977. su Koncertna direkcija Zagreb, Centar za kulturnu djelatnost omladine, zatim RTV zagreb zajedno s Jazovskim društvom Ljubljana po prvi put realizirali ideju o okupljanju ponajboljih jugoslavenskih Jazz muzičara bez obzira u kojem orkestru ili zemlji trenutno djelovali. Pa se taj cream de la cream YU Jazza složio od Duška Gojkovića (truba, flg horn), Bora Roković (klavir), Jovan Miković (tenor sax), Krešimir Kres Remeta (bas), Damir Dičić (gitara), Ratko Divjak Rale (bubnjevi). a tu je i, tako ju je nazvao Boško Petrović koji također svira na albumu (vibrafon), prva dama jugoslavenskog vokalnog Jazza - Nada Knežević kojoj je ovo zapravo prva Jazz ploča. Premijera je održana u Koncertnoj dvorani Lisinski, sljedeći dan su nastupili u Lapidariju i dan iza toga u dvorani ljubljanskog kina "Union". Snimani su i zagrebački i ljubljanski nastupi, pa je ovaj dvostruki album sastavljen od snimaka svirki u Zagrebu i Ljubljani, a onaj nastup u Lapu je snima za televiziju. Album je sastavljen od autorskih pjesama Duška Gojkovića ("Kosmet" i "Ribara starog kći"), Boška Petrovića ("Moja balkanska dama" i "San zelenog jastoga"), Bore Rokovića ("Djeca rastu brzo") i Damira Dičića ("Pjesma za tebe" i "Nježni dodir"), a uz autorske pjesme se na trećoj strani nalaze i četiri Jazz standarda drugih autora. Ako nemate, kupite, ukradite, posudite, namolite....bit će vam drago što jeste!
  19. NIXIE
    I oma na konkretan poso. Zamena mikroprekidača na mišu. Tako je lako, nestvarno.
  20. NIXIE
    Malo je kabastije nego što sam mislio. Poveke. Ali radi za medalju. Da sam znao koliko je dobro, odavno bi kupio.
  21. Brijac
    Stigel sledeci upgrade za sistem. Streacom FC10 Alpha kuciste. HT4, SH2, LH4 dodaci. Kao i HDPLEX 400W DC-ATX napajanje.
  22. Je si li razmišljao o tome da im secneš whizzer i da ih onda upariš sa nekim visokotoncem, npr Fountek NeoCD3,5H(ili nešto poput toga što bi moglo bez atenuacije) ?
  • Trenutno na sajtu   2 članova, 0 Skrivenih, 1682 Gosta (Pogledaj celu listu)
