Pioneer CS-801 : zamena delova na skretnici
DJ Q.T Live -
To samo Japanci mogu da naprave!
Thread 'Unique 20cm Full-Range Styrofoam Flat Speaker with DIY Ironless Repelling Magnet Motor (Perfect Flat Impedance 20Hz-20kHz!)' https://www.diyaudio.com/community/threads/unique-20cm-full-range-styrofoam-flat-speaker-with-diy-ironless-repelling-magnet-motor-perfect-flat-impedance-20hz-20khz.444473/
Trenutno na sajtu 10 članova, 1 Skrivenih, 85 Gosta (Pogledaj celu listu)
Ukupan broj tema453.3k
