Showing content with the highest reputation on 10/31/23 u svim oblastima
  1. Leonardo
    diyAudio.rs Linux OS
    Miko, kod mene je ceo N1 rupa!? Da li je do tvoje skripte ili ubacivanja, nemam pojma.
  2. Mikorist
    Novi Beograd, Novi Sad,‎ Novi Pazar‎, Novi Kneževac‎, Novi Bečej‎, Nova Varoš‎, Nova Crnja‎. Nastranu šalu na stranu, napravio sam skriptu (Demona) koja radi isto što i Pi-hole i ubacio direkt u sistem. /usr/local/bin/update_hosts.sh #!/bin/bash default="https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts" tmp_hosts_file="/tmp/hosts.tmp" system_hosts_file="/etc/hosts" system_hostname=$(hostname) if ! curl -sSf "$default" -o "$tmp_hosts_file"; then echo "Preuzimanje datoteke hosts nije uspelo." exit 1 fi cp "$system_hosts_file" "$system_hosts_file.backup" #cuvanje hostname sistema echo "127.0.0.1 $system_hostname" > "$tmp_hosts_file" grep -E -v "^127\.0\.0\.1[[:space:]]+$system_hostname" "$system_hosts_file" >> "$tmp_hosts_file" # Replace the system's hosts file with the new one if ! sudo cp "$tmp_hosts_file" "$system_hosts_file"; then echo "Azuriranje fajla sistemskih hostova nije uspelo." # Vracam rezervnu kopiju ako azuriranje ne uspe sudo cp "$system_hosts_file.backup" "$system_hosts_file" exit 1 fi echo "Datoteka hosts je uspesno azurirana sa imenom hosta sistema." # Clean up rm -f "$tmp_hosts_file" rm -f "$system_hosts_file.backup" /etc/systemd/system/update-hosts.service [Unit] Description=Update /etc/hosts file Wants=network.target After=network.target [Service] ExecStart=/usr/local/bin/update_hosts.sh [Install] WantedBy=multi-user.target tajmer /etc/systemd/system/update-hosts.timer [Unit] Description=Timer for updating /etc/hosts file Wants=network.target After=network.target [Timer] OnCalendar=daily Persistent=true [Install] WantedBy=timers.target sudo systemctl daemon-reload sudo systemctl enable update-hosts.service sudo systemctl start update-hosts.service sudo systemctl status update-hosts.service sudo systemctl enable update-hosts.timer sudo systemctl start update-hosts.timer Automatski dnevno ubacuje najnoviji https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts čuvajući header i to je to. Nema plaćanja i ostalog, a nema i pogleda preko tarabe. Postoji već decenijama i nema ikoga ko se požalio. Da ja znam. Ovako izgleda sajt N1 posle ovoga. Tu gde su oglasi su rupe Ovo iznad nije dovoljno za Chrome. Treba i ovo dodatno kao ekstenzija: GitHub - mikorist/skip: Chrome extension to auto skip youtube videos seamlessly like AdBlockers GITHUB.COM Chrome extension to auto skip youtube videos seamlessly like AdBlockers - GitHub - mikorist/skip: Chrome extension to auto skip youtube videos seamlessly like AdBlockers I ovo stalno zastareva jer bukvalno svake nedelje menjaju SKIP dugme
  3. malopre dosao iz Sremcice, bio do Kragujca (prodavac elektronike sa KP). kupio 2 kom. TPA 3118 i neke regulatore i step up/step down dzidza bidze. kisa pala kad ne treba. na par momenata, od Zeleznika do Zarkova, tako jako padala kisa, da sam jedva vozio sa brisacima na max. ali, uspeo sam da nadjem parking, nedaleko od zgrade.
  4. NIXIE
    Kupuj dok nije otišlo...
    Pa nije, kako za koga.
  5. ManicP
    Ma s ovim Bobanom bi se dalo dogovoriti i ovde na forumu.
  6. grone
    Ako je do origigi JBL sve sto je dobro je preskupo i bog zna stanje! Za 409$ ima 2216ND radi za sve pare u svetu i novo je, posle trazi driver&hornu i ubija.... Bolje kloniraj 4367 kostace ti oko 2K.
  7. Doktor
    Malo da se podsetimo i Aduta. Sabat - Cetvorka. U kolekciji Vertigo Svaba i Warner Bros. Jenki. Pustam jenkijevsko izdanje jerbo sam to znacajno manje rabio ( iskusno ). Inace, oba Press-a nemaju kix-a, tako da ako naletite na bilo koji od ova dva, slobodno pazar. O numerama, albumu, ovaj put ne bih . . . antologija i obavezna lektira za sve. Pod obavezno u kolekciji od 50 vinila.
  8. shonne
    Zna se sta ide na velike zvucnjake, 40 komada onih tranzistora sto se @NIXIE interesuje, po kanalu. A ovo...malo da se deca igraju sa aktivom za velike zvucnjake i malo za njihovo merenje 😁😛🤗
  9. Zen Mod
    sad mozete da pravite i ML male ampove za one vase male zvucnjake
  10. BANAT
    Sav Taj Jazz !
    New Jazz Underground
  11. gluv_i_udaren
    Magnetofon
    Bližimo se četvrtini 21. veka, gramofon smo već izgustirali i razmišljamo o nabavci još nezgodnijeg i skupljeg načina za slušanje muzike. Samo nek je u rikverc! I’m in!
  • Trenutno na sajtu   2 članova, 0 Skrivenih, 1631 Gosta (Pogledaj celu listu)
