gluv_i_udaren Napisano Avgust 18, 2019 #1717 Napisano Avgust 18, 2019 12 minutes ago, krca44 said: narednih dva miliona godina?
krca44 Napisano Avgust 18, 2019 #1718 Napisano Avgust 18, 2019 3 minutes ago, gluv_i_udaren said: dva miliona godina? Ne secam se koliko rekose, bio sam klinac ( osnovna skola ? ), nesto tipa dve nedelje ili slicno...
gluv_i_udaren Napisano Avgust 18, 2019 #1719 Napisano Avgust 18, 2019 lol No dobro, nema to puno veze sa periodom poluraspada, valjda dok se malo smanji koncentracija radioaktivne prašine u vazduhu, crne kiše ili čega već. Posle može lopte opušteno lol krca44 je reagovao/la na ovo 1
NIXIE Napisano Avgust 19, 2019 #1720 Napisano Avgust 19, 2019 9 hours ago, krca44 said: Aaaa Cernobil si zaboravio ... Već sam bio veliki kad se desilo.
krca44 Napisano Septembar 7, 2019 #1721 Napisano Septembar 7, 2019 Trilogy 915R preamp iznutra, 6N6P sa trafo-om na izlazu Nesic je reagovao/la na ovo 1
shonne Napisano Avgust 18, 2020 #1722 Napisano Avgust 18, 2020 3D stampac, drvo [emoji3526] krca44 je reagovao/la na ovo 1
Aleks Napisano Oktobar 16, 2020 #1723 Napisano Oktobar 16, 2020 vladd, stefaca and dejanco32 je reagovao/la na ovo 3
Aleks Napisano Oktobar 18, 2020 #1724 Napisano Oktobar 18, 2020 Dynaudio Arbiter I posle kažu diyeri preteruju
NIXIE Napisano Oktobar 19, 2020 #1725 Napisano Oktobar 19, 2020 pre 18 časa, Aleks reče Dynaudio Arbiter Reklamira se kao najbolje pojačalo na svetu, šteta što se više ne proizvodi. The Arbiter project was something that Dynaudio started ONLY to help with development of their speaker component and loudspeaker designs, in such that the Arbiter does not have any character of its own……..the sound is completely neutral and only amplifying the original source. They are truly amazing, cost-no-object designs, and are no longer in production which retailed at $300,000 for the package (USA: $120,000 for each amp and $80,000 for the preamp). Dynaudio produced and sold 30 pairs of the amps and 40 preamps Dynaudio Arbiter Amp Effective Output: 620W (8Ω), 1072W (4Ω), 1670W (2Ω) Frequency response: 0.3Hz-300kHz (-3dB) THD levels: less than 0.005% (8Ω) S / N ratio: 103dB or more Input Impedance: 2000Ω Input Sensivity 2,25V, 6,75V Damping Factor: 1000 or more (Output 1), 40 or more (output 2) Power consumption: 120W, 2000W (Max) Size (WHD): 27.5 × 80 × 67cm Weight: 140kg each Output level (maximum): 17V (Balanced), 8.5V (unbalanced) Frequency: 5Hz-100kHz (± 0.1dB) THD level (maximum output): less than 0.005% S / N ratio: 128dB or more (line), 78dB or more (Phono) Crosstalk:-127dB (100Hz),-110dB (1kHz),-92dB (10kHz) Pre-Amp Input impedance: 2000Ω (Balanced), 11000Ω (unbalanced) 14-47000Ω (Phono) Output impedance: 100Ω (balanced), 50Ω (unbalanced) Consumption power: 25W, 250W (max) Size (WHD): 27.5x27.5x47.5cm Weight: 80kg The amps S/N are #025 and the pre-amp is #017. “The units are kept in excellent condition with no scratches or marks , I have the original remote control, owners manual, box and packing materials.
Zen Mod Napisano Oktobar 19, 2020 #1726 Napisano Oktobar 19, 2020 Lab pojacalo ne mora da znaci i najbolje pojacalo kud ces bolji primer od Halcro - a oni se bas nesto i nisu proslavili brojevima prodatih uredjaja msm, za nekoga je definitivno najbolje pojacalo .......
Aleks Napisano Oktobar 19, 2020 #1727 Napisano Oktobar 19, 2020 pre 2 časa, NIXIE reče Reklamira se kao najbolje pojačalo na svetu Najbolje pojačalo... tako relativan pojam, isto kao i najbolji zvučnik, najbolji preamp, itd. Kada se to spakuje u rečenicu sa "reklamira se" onda sve jasno Mene mi samo interesantno, onako ne izgleda loše, msm mene mi lepo, al samo da ne pričamo psole kako diyeri preteruju sa over-dizajnom
NIXIE Napisano Oktobar 19, 2020 #1728 Napisano Oktobar 19, 2020 pre 38 minuta, Aleks reče "reklamira se" Pogrešio sam, reklamiralo se (nekad) ne prave ga više. I onako je bilo u reklamne svrhe, kao WW što pravi Bugatti i gubi pare na svakom primerku.
neskor Napisano Oktobar 22, 2020 #1729 Napisano Oktobar 22, 2020 ovo ne izgleda kao losa ideja za DIY projekte krca44, djmilicic, zerowaf and 1 član je reagovao/la na ovo 4
djmilicic Napisano Oktobar 22, 2020 #1730 Napisano Oktobar 22, 2020 pre 8 minuta, neskor reče ovo ne izgleda kao losa ideja za DIY projekte Sve sa šoderom ispod
zerowaf Napisano Oktobar 22, 2020 #1731 Napisano Oktobar 22, 2020 Amp na dasci, Level 1000 djmilicic je reagovao/la na ovo 1
shonne Napisano Decembar 20, 2020 #1732 Napisano Decembar 20, 2020 Beauty [emoji846] zika je reagovao/la na ovo 1
prophet Napisano Decembar 25, 2020 #1733 Napisano Decembar 25, 2020 Ako se pitate otkud ovo u Hi-End, odgovor je da nije zbog izgleda već zbog zvuka. zerowaf je reagovao/la na ovo 1
zerowaf Napisano Decembar 26, 2020 #1734 Napisano Decembar 26, 2020 pre 2 časa, prophet reče odgovor je da nije zbog izgleda već zbog zvuka. Je li to ona što se čuje kao F1? prophet je reagovao/la na ovo 1
Aleks Napisano Januar 24, 2021 #1735 Napisano Januar 24, 2021 Šta čoveku više treba... Zar je mnogo I još samo da je pored neke vode, more, jezero, nebitno... P.S. Ovako ja zamišljam idealnu dnevnu sobu. TV-a bez. vladd, krca44 and zerowaf je reagovao/la na ovo 1 2
prophet Napisano Januar 24, 2021 #1736 Napisano Januar 24, 2021 Pitace se komsije: Sta je sa[mention=1572]Aleks[/mention] -om? Po ceo dan gleda u zid.[emoji23] Vix, Aleks, Srecko and 2 ostalih je reagovao/la na ovo 1 1 2 1
Koja Napisano Januar 24, 2021 #1737 Napisano Januar 24, 2021 Magacioner taman takvu sobu treba da ima
