2821 -
34
Postovi objavljeno od neskor
ja sam to lepio super lepkom i nisam imao problema
uzeo spric sa tankom iglom i u njega sipao super lepak i samo napravio krug lepkom izmedju baze i stakla
posle toga spric mozes da bacis
sada da li je to idealno resenje, verovano nije
takodje podrazavam ideju da aktiva ide samo na basove do nekih max 180Hz imho
sve preko toga dramaticno utice na kvalitet zvuka
probao, igrao se sa vrhunskim analognim i digitalnim skretnicima par godina i odustao
sve je to bilo lepo na papiru i merenjima ali ubio srz muzike
vratih se na pasivu i opet uzivam u muzici
verovatno to ide sa ukusom, ja npr. ribone nikad nisam mogao da slusam
A very simple method would be a relay switched B+ with the relay being triggerd by the bias voltage. Either have the B+ on a spearate transformer which is switched on through the relay. Or have the relais in the ground connection to the center tap.
If the bias voltage fails, the relay opens and B+ is drained through bleeder resistors and power tubes.
If the bias voltage doesn't come up at turn on, the relay stays open
a ako neces puno da se patis imaju i one gotove plocice za automatski bias
Auto Bias Modul for two Tubes (Single pcb to Control 2 Power Tubes) | eBay
WWW.EBAY.CA
Find many great new & used options and get the best deals for Auto Bias Modul for two Tubes (Single pcb to Control 2 Power Tubes) at the best online prices at eBay! Free shipping for many products! -
Bias Supply protection | diyAudio
WWW.DIYAUDIO.COM
OK so here is a question, The bias supply...if it fails the amp could be toast:eek: So how do we protect the Bias supply and still have a fail safe amp..:confused: One idea is to use a fail... -
Fixed Bias Protection
WWW.DIY-AUDIO-GUIDE.COM
Fixed bias protection prevents bias runaway that damages your power tube, speakers and output transformers. -
19 minutes ago, gluv_i_udaren said:
Možda bi i prosvirao da se stavi nešto kršteno na izlaz.
neke cefke
ja slusam ovo pojacalo sa sluskama koje su 600R i nemam zamerku na gain uopste, niti hod volume pota
6SN7 nema kond u paraleli sa otpornikom u katodi, tako da je pojacanje sigurno manje nego sto si naveo
nisam nikad merio velicinu izlaznog signal u odnosu na uzlaz, moram probati
jel neko mozda slusao one Chord male dakove sa FPGA chipovima?
Just a moment...
RA.CONew disc format combining CD and vinyl technology is 'pinnacle of recorded sound,' says founder T Bone Burnett
- vladd, gluv_i_udaren, zerowaf and 1 član je reagovao/la na ovo
- 4
2 hours ago, Beli_Ninja said:
Misliš na DL103R ili DL103, i koja je tu razlika u opšte ako može neko da mi objasni?
Mislio sam na DL103R, mada ni klasicna DL103 nije uopste losa
- Beli_Ninja je reagovao/la na ovo
- 1
12 hours ago, asimze said:
Da li neko ima u SACD formatu To a Finland station Dizi Gilespi i Artur Sandoval. TIA!
da li si siguran da taj album uopste postoji u SACD formatu, posto ja to nisam nigde video
11 minutes ago, Koja said:
Čekaj šta je to, elektromagnet?
da
prvenstveno da bih mogao da merim VT4C i ostale cevi koje rade na malo vecem naponu, takodje neg napon ide od -100V
plus:
Compared to the uTracer3 the PWM frequency has been reduced to 1.2 kHz. This makes the effective heater voltage virtually insensitive to parasitic wiring inductances, resulting in more accurate heater voltages
- aaa zmaju! je reagovao/la na ovo
- 1
in Digital
Audio Note
