2821 -
34
Postovi objavljeno od neskor
pozovi Trafco, oni su nekad to imali, koliko se secam
37 minutes ago, Sinke said:
Ako nađeš snage da se odvojiš od tog Tika, javi mi se!
moze, samo to nije bas jeftina sprava da se kupi kao donor za VU metre
Dual Analog VU Meter 2-way Amplifier/Speaker Audio Switcher Box w/Remote Control
WWW.EBAY.CO.UK
VU3 VU meter & audio switcher box is originally designed by Douk Audio: As a VU meter, with dual 60*35mm large meter, can dynamically decorate audio environment and provide incomparably visual effects when switching audio signals. As an audio switcher, easily to switch between two amplifiers and 2 pair of speakers, no need to plug in and out cables repeatedly to... -
pitas Trafomatic da ti proda par
moze i ovo
LCR RIAA, Shishido preporuka
ovo je moja preporuka
Rigol DS1054Z
posle se SW otkljuca za 100Mhz
https://www.diyaudio.com/forums/solid-state/267871-defect-channel-oscillates.html
Please note there are 2 small errors in the schematic; notably R614 goes (as expected) to negative rail, Q609 is a NPN (not a PNP) and R610 of the CCS also goes to negative rail.
Probaj Klirit u Zemunu, mada nisu bas nesto sjajni
1 hour ago, krca44 said:
Postoji li neki ton generator / osciloskop za neke razumne / manje novce, relativno precizan u odnosu na cenu ?
imas UNI-T UTG932E kao ton generator
https://eleshop.eu/uni-t-utg932e-function-generator.html
Mada gore pomenuti OWON koje sve to ima je sasvim dovoljan za neku amatersku upotrebu
Trenutno na sajtu 5 članova, 2 Skrivenih, 31 Gosta (Pogledaj celu listu)
Ukupan broj tema434.6k
