Showing content with the highest reputation on 10/12/23 u svim oblastima
  1. Nova JLS kartica, AD1862 sa šifterima i AK4118 Receiver Board. Svira, verujte.
    6 poena
  2. ja trosim ovaj http://shop.vremeplov.co.rs/Shop/Product?name=Tinol-zica-ALPHA-Fluitin-0.75mm-pak-250gr-Sn60Pb38Cu2&accountingCode=14095 1mm, to vec spada u montazu oluka
  3. 2 poena
  4. A evo i dokaz https://youtu.be/UE-t_StsPWU
  5. Mikorist
    Ei Nis projekat
    Ja bi isao odma u startu (da sam imao ovu pamet onda) sa Eminence Deltalite II 2510 za bass-ove...Kakvi Ei Nis kakvi bakraci. EMINENCE WWW.PLAYER.RS EMINENCE msm ja sam licno bacio direktno u kantu 2 puta vise para na Ei zvucnike nego na par ovih nikad nisu prosvirali kako treba.mislim prosvirali su od riknjavanja. Sad kad sam poludeo moze i 15 Eminence Deltalite II 2515 WWW.THOMANN.DE 15" Neodymium woofer Power rating: 300W RMS (600W program), Impedance: 8 Ohm, Frequency response: 54 Hz - 3.7 kHz, Sensitivity: 99.2 dB, Playback behavior specially designed for sound systems, but equally suited for electric guitars, electric bass,... pa zveknes u ovo Yamamoto Acoustic Craft 38cm 2-way Speaker System YS-500 1 unit EXCLUSIVE-AUDIO.JP Please note that this product will incur shipping charges regardless of the purchase price. This is a made-to-order product. Price is for one unit. It takes about 2-3 months for delivery. A unique work that makes you want to explore the labyrinth of sound High-performance 2-way system with wood horns at its core Description The YS-500 is a 2-way speaker system built around the SS-500 wood horn. The speaker units employ a 38cm...
  6. 2 poena
  7. Jedno je isprojektovana shema, a drugo je stvarnost. Verovatno su primetili kod prototipa, oscilovanja na visim frekvencijama, pa su povecali vrednost, dok nisu bili zadovoljni. Treba ostaviti kako je. Zasto proizvodjaci ne ispravljaju sheme, to je posebno pitanje. Mozda, da ih neko ne bi kopirao?
  8. 2 poena
  9. C/P: Dođe neki tip u šumariju tražiti posao. Dobije posao i šef mu kaže: Nakon sat vremena tip se vraća i veli šefu: Šef sav zbunjen i u nevjerici ode provjeriti. Stvarno, šuma posječena. Vraća se šef i veli: Šef ode provjeriti i ne vjeruje da je šuma posječena. Kad se vratio pita tipa:
  10. Dobar je mechanic skroz 63/37, pogotovo za cenu (fluks kojim pune je top, sto pripisujem i pored homogenosti alfa fluitina, da ga izdvaja i fluks). Paste su im dobre isto, vrlo sitne cestice, uz stensil i hotplate, profi prica.
  11. kolega @sp300b mi je preporucio kineski brand Mechanic svojevremeno mi poslao roll 0.5 da imam za SMD work, perfektno kome nije zurba, isplati se naruciti sa Alija
  12. Što reče @Zbora, do OP-ampa je.
  13. NIXIE
    Electrocompaniet AW-75
    Mrzi ih verovatno.
  14. Nema ništa od tih vaših uređaja bez mašinske obrade.
  15. Pristiglo preko naših regularnih transportnih puteva... Oprali me fino. Ušteda je tačno 0 dinara i 0 dana u odnosu da sam poručio od majstora iz KŠ. Sad jos samo da stignu i polikarbonati za bajpasa i imam sve... Sem pcb-s
  16. Ja ga upalim kad dođem iz A i ugasim prije nego što odem. Znači, po pet dana u komadu je "On". A zaboravim i LuDEF-a ugasiti, pa je i on većinom upaljen. Struju i ostalo plaća žena, pa ne vidim da je išta skuplje (iako ja uplatim njoj za troškove), a ako se isuše elektroliti ...će se stave drugi - opet mokri.
  17. Zen Mod
    TVC
    znas kako stvari funkcionisu : ti pitas ; neko ti odgovori ; onda ti ides i radis svoj domaci zadatak - proveravas ono sto ti je neko odgovorio ; onda dodjes opet i pitas dalje , ali da se vidi da si uradio domaci . ako potenciras svoj izbor , bez obzira koliko on bio pogresan - ne mozes ocekivati da ti neko sazvace deo po deo projekta . u celoj stvari jos si daleko od bilo kakvih cena ( da ne pominjem da potenciras izbor cevi kao da kosta 100 a ne 2 eura ) , jer jos nista nije definisano . niko ti nije pokusao nista ni prodati ni navesti te na neku kupovinu , nego ukazati na kompleksnost teme , kao i na tvoj pogresan izbor cevi , kao da je jedina na svetu . a ne valja za to sto hoces ; niti je specijalno linearna , niti ima dovoljno malu unutrasnju otpornnost , niti dovoljnu strminu . niti si proverio nabavljivost i cenu bilo koje druge cevi koje sam navodio . da si se postavio kako treba - mozda bi i upoznao dovoljno cestu praxu na ovom forumu - da se lako desi da ti neko i pokloni potrebne lampe . nadji neki projekat na netu , pa ga radi .......... dosao si , sa belim listom papira , trazis da ti ga neko ispise , a stalno otimas olovku iz ruke . sretno ti bilo u osvajanju sveta cevi
  • Trenutno na sajtu   0 članova, 0 Skrivenih, 1612 Gosta (Pogledaj celu listu)
