Showing content with the highest reputation on 04/19/22 u svim oblastima
  1. verovatno bi bilo bolje uz regularan streamer ili PC, ali streaming servisi su sve lošiji; navodno bolje zvuče fajlovi sa lokalne mreže / diska - meni je to sve veoma slično. posle prvobitnog oduševljenja streamingom zbog izbora, dostupnosti, hires formata, cene vratio sam se na CD, kao ultimativnom digitalnom formatu
  2. https://www.diyaudio.com/community/threads/sissysit-p-or-how-i-proved-fact-of-making-more-hats-than-pa-did.385400/#post-7000665 Well, anyone at least partially partial with my omnipresent babbling, knows about endless series of M2 derivatives, I made sorta recently All of them having M2-like Front End (my biggest Fetish), so entire voltage gain got from autoformer, so no (overall) NFB involved Also - all of them having second of my recent Fetishes - Square Law OS Ok, that is line of unnecessary long line of M2 derivatives, difference being that each is having different quirk of OS parts Then came next fixation point... when I concocted FE for Babelfish XA252, biggest part of invention was proper name for same FE - Plethora of Pinjatas ....... so I ( naturally) came to idea of making second totally unnecessary line of derivatives, now having Plethora of Pinjatas FE, and simply varying already proven SL OS iterations This line having slightly different ( sorta mirrored/flipped/downundered/whatever) biasing mechanimus, comparing to older specimens, this one directly taken form Babelfish XA252 Comparing to older ones ( having opto between Mosfet Gates and fixed resistors from rails to gates), there are current mirrors from rails to fixed resistor(s) between Mosfet gates; result is better Iq behavior in domain of rails change, same as better Iq behavior in thermal change domain, and also firmer relaxation factor (Iq stability in dynamic domain; think recovery time if change occurs with long large signal) Anyway, let's ignore Babelfish XA252 as first one, declare SissySIT P (P suffix for Plethora of Pinjatas family) as first one Am I happy ...... yes! (this one done, so I can think of working on next ) Confirming same amp sound character, for amps made without NFB and with Autoformer gain and amps made with sorta heavy NFB and active gain ....... well, not exactly a novelty per se this post intentionally made pic-less - in case of later edits, lesser mess
  3. U srcu mi je osećaj isti kao Klarksonova faca kad vidim tako ubijenu Ultraleggeru
  4. Uz sve to i: ŽIVOTNA PRIČA VLATKA STEFANOVSKOG: Put kojim sam išao nije bio asfaltiran, Bog me je sačuvao do sada! | Serbiantimes.info SERBIANTIMES.INFO On je jednostvano – Vlatko. Vlatko „Leb i sol“. To je oduvek išlo jedno s drugim. Manje je poznato da mu Vlatko nije pravo ime. Odsvirao je na hiljade koncerata. Proputovao gde god je zamislio. Sazidao dve kuće. Decu je izveo na pravi put i ponosan je na njih, piše Kurir. Imao sam pehova koliko […]
  5. ninja
    Audio fajl server, Izbor računara
    Tidal zvuči odlično ali ne na telefonu i sa premium pretplatom. Ja ga imam vec par godina, ima jos nesto Francusko, ne sjećam se imena, kažu jos bolje. evo, sjetih se :-) /assets-static/img/logo/qobuz_logo_og.png Qobuz - High quality music - Unlimited streaming and Hi-Res download store WWW.QOBUZ.COM More than 80 million tracks available for high sound quality unlimited streaming. Qobuz is also the worldwide leader in 24-Bit Hi-Res downloads.
  6. Po merenjima ne može da svira dobro...
  7. How it sounds? Well, as close Cousin ( younger one) of Babelfish XA252 SIT Good enough for Mighty Moi
  8. Ovoliki trud odjednom, mora da je zbog toga što se bližimo prazniku rada😁. Sjajno!
  9. Evo ih po cjeloj sobi, gore, dole lijevo desno. Evo jedan izašao na balkon! Baš su nestašni!
  10. @Aleks me navlaci na blud...probace se prvo mono u Aleph kutiju sa novom maticnom plocom 😁
  11. 0 poena
  • Trenutno na sajtu   3 članova, 1 Skrivenih, 2158 Gosta (Pogledaj celu listu)
