Showing content with the highest reputation on 06/01/20 u svim oblastima
  1. Ma jok bre, mi naložili, održavam vatru ko zimus. Drva ima za još mesec dana, za juli će da mora da se dokupi.
  2. NIXIE
    Antivibracione podloške
    Za kraj teme, varijanta sa tri ležaja. Na DAC imam visoke nogice, nisu dovoljno visoke bile one sa dva ležaja.
  3. whoa, Daphile mnogo lakši za instalaciju nego što sam mislio i još radi na raspad laptopu iz špajza od pre 15 godina Prepoznao bez problema i Toppinga sa svim podržanim modovima i Wi-Fi karticu na laptopu. Sad još malo komplikovano dok ne prokljuvim šerovanje fajlova kroz mrežu, a wifi upload je painfully spor, al pustio sam neki radio O zvuku ne znam ništa, trenutno mi nakačeni moji C zvučnici na moje B pojačalo
  4. Probaj i Volumio. Evo kako da se spusti na HDD: NOTE: you will loose ALL the data on your HDD. - Flash Volumio 2 to a usb stick - Format another usb stick wit FAT32, and copy the unzipped downloaded x86 image to it. - Then boot from your usb volumio 2 stick. - Will until the UI is showing, the press ctrl-alt-F1 to open a terminal session - Log in with volumio/volumio - Type Code: Select all sudo blkid and check the output. - You should see /dev/sda, /dev/sdb and /dev/sdc (presuming you only have one disk in your x86 pc) The device with the labels "volumioboot", "volumioimg" and "volumiodata" is the one you booted from. The device with the single vfat partition is the stick with the volumio image, assume it is /dev/sdX (X being a, b, c...) The other device is your netbook's hdd, assume it is /dev/sdY (Y being a, b, c...) - When sure about the devices, type Code: Select all mkdir usb sudo mount /dev/sdX1 usb cd usb ls -l sudo dd if=fullnameofthevolumioimage of=/dev/sdY bs=4M sync cd .. sudo umount usb sudo rm -r usb poweroff - remove the usb sticks, reboot et voila
  5. Uzeo bi neke na 8 oma. Vecinom su bili na 4 ...
  6. evo USB kabl za DC dokasapljen, još da sklepam neko napajanje, sutra stižu neki opampi, izvukao sam neki laptop iz špajza da mu naglavim Daphile, polako bušim pločice za onaj preamp.... ima šta da se radi
  7. Ovo da stave za jun lagano.
  8. Mikorist
    apstraktna umetnost - gledaš a ne znaš šta je
  9. Mikorist
    niki bradonja mu oteo sajt
  10. Ehej... Nije me bilo neko vreme... Ne nije Koronka familijo... ? Elem, trazio sam neko resenje za BDejce ispod ploce i ovo ispalo najprakticnije... Kad sam vec krenuo da ih kacim na stubice bilo mesta i za hladnjake koji pretekli iz narudzbine delova. I ako nema grejanja BD-ejaca, rekoh da ih iskoristim...
  11. Zen Mod
    ZM, random zanimacije
    vidvid, ko se to meni raduje ......
  12. Zen Mod
    o je upravo dobih info da je akcija usvercavanja posiljke Metglasa uspesno zavrsena
  13. Ne preteruj. Trafo može biti put za nirvanu ili u propast, dobri su skupi.
  14. nisi čuo Iron Pre posle OPA1612 čekam onog Guju da mi pošalje Sigmu - pa da čijem da li će da ukenja zvuk ili će još bolje da bude
  15. misliš -127db
  16. Auu, ima stanovi da pojeftine u komsiluku kada dva mikroba krenu da vezbaju skale
  17. to ti je moja omiljena vrsta sporta tako uradjeni Primare CD-ovi, Teac DAC , i jos poneke boranije DAC vidi samo primar direktno, izmedju dve faze, loadingom sekundara postizes linearnost grupe DAC+trafo, dalje po moranju , koliko signala ispadne pa koliko ga moras pojacati kad ima mest, onda diskretno, kad nema onda OPA1632 , svira za nebiliviti
  18. Hvala svima na odgovorima. Najverovatnije ćemo u Mokranjac, presudila komšinica mladja godinu dana. Iće će zajedno. Motivacioni faktor pobedio, mislim da će uz društvo i nekog poznatog najlakše prevazići ukrase, punktirane ritmove, trodele itd gde mnogi odustanu.
  19. Mikorist
    Ima onaj Grčki audiofil - kome ceo sistem - visi u vazduhu Četiri sajle ušafljene u plafon drže ceo Rack a između ima lagere - i sve visi zajedno u zraku Kaže da je lebdeći rack 50% zvuka
  20. grone
    Zvucnici pa jos zvucnici ovog puta i 12-ice! Otiso samo da gledam pa tako...
  21. 0 poena
  • Trenutno na sajtu   1 član, 0 Skrivenih, 1950 Gosta (Pogledaj celu listu)
