Showing content with the highest reputation on 07/17/23 u svim oblastima
Windows 10, Windows 7 i ostala WIN familija
LightMatic i jedan drugi je reagovao/la na Zen Mod za temu
da da, samo vas gledam, vas dvojicu Mikum & Doc2 poena -
ChatGPT
Srecko i jedan drugi je reagovao/la na Zbora za temu
Tell me about Zen Mod amps. ChatGPT Zen Mod amps are a type of amplifiers known for their minimalist design and high-quality sound reproduction. They are designed by Nelson Pass, a renowned audio engineer and the founder of Pass Labs. The term "Zen Mod" reflects the philosophy of simplicity and focus on the essence. Zen Mod amps typically follow a minimalist approach, using a simple Class A topology that aims to provide a clean and direct signal path. Some key features of Zen Mod amps include: Class A operation: Zen Mod amps operate in Class A, which means they have a constant current flowing through the output stage at all times. This design helps reduce distortion and improve linearity. Minimalist design: Zen Mod amps are characterized by their simple and uncluttered design. They often have a small number of high-quality components, avoiding unnecessary circuitry to maintain signal integrity. High-quality components: Zen Mod amps are built using carefully selected components such as transistors, resistors, capacitors, and transformers. These components contribute to the overall performance and sound quality of the amplifiers. Transparent sound reproduction: Zen Mod amps aim to reproduce the input signal faithfully without adding excessive coloration or distortion. They strive for a transparent and detailed sound reproduction. DIY-friendly: Nelson Pass supports the DIY culture, and many Zen Mod amplifier designs are openly available for enthusiasts to build their own amps. This fosters a community of audio enthusiasts who appreciate the craftsmanship and performance of Zen Mod amps. It's important to note that Zen Mod amps come in different models and variations, each with its specific features and performance characteristics. The exact specifications and details may vary depending on the model and design version. In summary, Zen Mod amps are known for their minimalist design, high-quality components, and focus on delivering transparent and detailed sound reproduction. They have gained a strong following among audio enthusiasts who value simplicity, craftsmanship, and uncompromising sound performance.2 poena -
Još jedna tema o... Hiraga pojačalu
LightMatic je reagovao/la na zerowaf za temu
I u pravu si! Morat cemo uvesti klauzulu da tekst mora imati vise od 12 redova i vise od sedam slika! Siroti Zen... s cime ga sve mi gnjavimo. U temi o Midi Kompenzatorima cu reci s cime sam ga ja danas gnjavio (jednom kad nesto malo i napravim, pa imam sto i napisati). Davim ga kao da sam iz Tušilovića.1 poen -
Ima. Onaj @Mikorist link. Imao fake, kupio za 1403 dinara. Fercera. Microsoft Windows 10 Professional CD Key - Instant Delivery at CJS CD Keys WWW.CJS-CDKEYS.COM Buy Activation CD Key Code for Windows 10 Pro at CJS CD Keys and receive your key instantly after payment. Genuine and unused.1 poen
2 / 2 Zen Mod pojačala se odnose na pojačala koja su dizajnirana i izrađena od strane Aleksandra Prodanovića, poznatog kao Zen Mod. Zen Mod je inženjer i istaknuta ličnost u DIY audio zajednici. On je poznat po inovativnim dizajnima pojačala i njegovim doprinosima audio zajednici. Zen Mod pojačala karakteriše jednostavnost, elegancija i visokokvalitetno reprodukovanje zvuka. Često se ističu minimalističkim pristupom dizajna, fokusirajući se na osnovne komponente i kola kako bi se postigla optimalna performansa. Pojačala Zen Moda su visoko cenjena zbog izvrsne kvalitete zvuka, pouzdanosti i efikasnosti. Jedan od značajnih doprinosa Zen Moda je razvoj serije pojačala Pass Labs Aleph, koja se temelji na dizajnima Nelsona Passa, poznatog audio inženjera. Zen Mod je dodatno unapredio i prilagodio ove dizajne pojačala, dodajući svoj jedinstveni pečat i modifikacije. Zen Mod pojačala su stekla popularnost među ljubiteljima zvuka i graditeljima DIY audio sistema zbog izuzetne performanse i vrednosti koju pružaju. Poznata su po pružanju prirodnog, detaljnog i upečatljivog zvuka koji privlači audiofile i ljubitelje muzike. Važno je napomenuti da se dizajni i pojačala Zen Moda često raspravljaju i deljeni unutar DIY audio zajednice, a Zen Mod aktivno učestvuje na forumima pružajući podršku i savete drugim ljubiteljima zvuka. Za detaljnije informacije o Zen Mod pojačalima i njegovim doprinosima, možete posetiti njegovu veb stranicu ili istražiti DIY audio forume gde se njegov rad raspravlja i ceni. Was this response better or worse? BetterWorseSame Regenerate response1 poen
Iron Spark
LightMatic je reagovao/la na mutayu za temu
@Zen Mod Ubacio 0R na poziciju R38 i 100R na poziciju R32 i potpuno izbacio C13. Preslusao 10-tak numera najrazlicitijih zanrova i mislim da je zvuk dosao na svoje mesto. Trafo ostaje vezan za 6dB gaina dok ne uradim Old Soul Ge pa cu onda da probam kako bolje zvuci, sa 6 ili 12 dB gaina. Narednih dana sledi slusanje razlicite muzike sa razlicitih izvora ali vec sada mogu da kazem da su utisci odlicni, cak i bolji od toga 😀. Me happy!1 poen -
Brijac je reagovao/la na LightMatic za temu
Dobra večer drago društvo, napokon (nadam se) mali napredak u izradi. Naime, u prošli petak, raskupus'o sam 'iragu na rađi, da bih odradio napajanje po nesebičnim i uvijek korisnim savjetima našeg MZM-a. Našao sam komad bakrene ploče dovoljan da mogu srediti masu , pa prilažem slike onoga što sam postigao. Nadam se da opet nisam zeznuo stvar, molim za strpljenje sa mojom malenkošću, uzmite u obzir da sam čistokrvni hercegovački kenjac. Slikao sam i demontirane kanale pojačala a pošto sam ja lako ložljivi Fi-Fi narkoman, javila se i sumnja da jedini (sa sigurnošću mogu reći da su original koje imam) driverski i izlazni tranzistori nisu adekvatni za trenutnu poziciju, kao ni anti-oscilacijski kondenzatori, pa bih zamolio umne i iskusne glave da me usmjere na pravi put. Koristio sam tranzistore iz jednog gnjilog Kenjvuda, neki "filozof" je spojio MM glavu od gramovuna na ulaze MC predpojačala, što je izazvalo pregaranje istog MC pp., elektrolit se "razlio" po željezariji što je bio ogavan prizor, a na sreću ostatak elektronike je preživio, tako da sam odstranio već rečene tranzistore i ugradio ih u 'iragu. Oni 2SA872/2SC1775 tr. su iz Jovica (JVC) risivera. Priložena je i šema (ako mogu svoje hijeroglife nazvati šemom) po kojoj su zgotovljeni kanali pojačala. Sve mi se čini da će zbog ovih mojih kilometarskih poruka nadležni uvesti ograničenje teksta....0 poena
Trenutno na sajtu 0 članova, 0 Skrivenih, 1529 Gosta (Pogledaj celu listu)
