Showing content with the highest reputation on 10/22/22 u svim oblastima
  1. Zen Mod
    Iron Pumpkin Industrial
    Make it super ugly - only possible way to have it for good, without someone buying it of me, as it already happened few times with those I had as mine - simply because they already been on disposal. One of cases I bought cheaply, exactly for prototypes purpose, redundant pcbs ( leftovers from protowork) used for both front and back plates, old/initial crude display. As intended to serve also as demo specimen, set of gain setting jumpers replaced with battery of relays, controlled with 5-step rotary switch at back. Title on functional display sez "SE", will re-flash later, because I evidently made it balanced - 3 SE inputs, 2 Bal inputs. Lousy pics - Alu case elements showing bad on white background
    6 poena
  2. bnb
    EAR 834,nekompletan kit.40 eura,stiglo za mesec dana.
    5 poena
  3. Ja sam mislio da je ovo veće… RPi Compute Module 4, 2GB rama i 32GB storage. Čekam ostatak da napravim KVM over IP za 4 kompjutera
  4. Probao. Svira. I to prilicno dobro, moglo bi ostati "definitivno" pretpojacalo u sistemu. Ali ipak, ne da djavo mira. Imam u glavi bar jos dva pretpojacala koje cu napraviti, tako da bi na kraju imao 4 komada Onda bi se odlucio koje da ostavim... Trenutno su sva sa "obicnim" napajanjem (cap multiplier/regulator), a koje bude definitivno onda ide shunt, bolji kondenzatori...
  5. Lice mrava posmatrano kroz mikroskop.Ne znam zašto me neodoljivo podseća na moju taštu
  6. Dumus
    Samo da prijavim novu spravu. Sin mi je danas preuzeo paketić od jednog našeg poznatog forumaša (kome se ovom prilikom izuzetno zahvaljujem na ovoj usluzi). Pošto sam trenutno van Bgd-a. Prvi utisci idu posle vikenda.... WTX-StreamTubes – Advance Paris WWW.ADVANCEPARIS.COM
  7. 1 poen
  8. NIXIE
    Baš je vopla.
  9. 1 poen
  10. Mora tako, ne može jedna sprava da utoli žeđ.
  11. Mikorist
    ALIEXPRESS
    Faber Castell Graf Von Mastilo imaš u Ušću. Cena je sitnica Ima i Faber Castell penkalo od 600E
  12. 1 poen
  13. Evo, zavrsio. Jos oko skretnice ima posla, ali drvo i komplet fejslifting zavrsen.
  • Trenutno na sajtu   3 članova, 0 Skrivenih, 1765 Gosta (Pogledaj celu listu)
