Showing content with the highest reputation on 05/01/22 u svim oblastima
Woland
D i g i t a L i 2 drugih je reagovao/la na Woland za temu
3 poena -
SBB Router ili koji ?
Srecko i jedan drugi je reagovao/la na Mikorist za temu
https://adguard-dns.io/en/dashboard/auth Moraš da se registruješ i uloguješ da bi ovo video Encrypted DNS server addresses AdGuard DNS supports all modern encryption protocols. Encrypted DNS addresses contain your device identifier ("ecce1521") to enable AdGuard DNS recognize and filter your DNS requests. DNS-over-HTTPS https://d.adguard-dns.com/dns-query DNS-over-TLS tls://d.adguard-dns.com DNS-over-QUIC quic://d.adguard-dns.com Plain DNS server addresses Some older devices may only use unencrypted DNS. Only use the Plain DNS protocol if you have no other option. Plain DNS requires that you link your device's IP address so that AdGuard DNS can recognize its DNS requests. You have to relink your device every time its IP address changes. 94.140.14.49 94.140.14.59 ovde imaju podešavanja za razne rutere Open the preferences for your router. Usually you can access them from your browser. Depending on the model of your router, try entering one the following addresses: Linksys and Asus routers typically use http://192.168.1.1 Netgear routers typically use http://192.168.0.1 or http://192.168.1.1 D-Link routers typically use http://192.168.0.1 Ubiquiti routers typically use http://unifi.ubnt.com Enter the router login and password (Often the default values are admin / admin). Note that if you don't remember the password from your router, you can often reset it by pressing the button on the router itself. Some models have a specific application to manage them, in that case the application should be already installed on your computer. Find where DNS settings are located in the router's admin console. Choose one of the following AdGuard DNS servers and replace the current addresses with the addresses of the chosen server: Default servers If you want to block ads and trackers. IPv4: 94.140.14.14 94.140.15.15 IPv6: 2a10:50c0::ad1:ff 2a10:50c0::ad2:ff Non-filtering servers If you don't want AdGuard DNS to block ads and trackers, or any other DNS requests. IPv4: 94.140.14.140 94.140.14.141 IPv6: 2a10:50c0::1:ff 2a10:50c0::2:ff Family protection servers If you want to block adult content, enable safe search and safe mode options wherever possible, and also block ads and trackers. IPv4: 94.140.14.15 94.140.15.16 IPv6: 2a10:50c0::bad1:ff 2a10:50c0::bad2:ff2 poena -
A pa ne tuuuuuuu!!!! Na pin 6 od Sparkosa!1 poen
Ko skida torrente (verovatno svi odavde) ekstra nivo zaštite (sa ili bez VPN) je da koristi opseg za blokiranje za eMule http://upd.emule-security.org/ipfilter.zip fajl sadrži u tekstualnom obliku sve IP adrese (opsege ) koje bi mogle da prijave nekog ko skida...... deo fajla 000.000.000.000 - 000.255.255.255 , 000 , Bogon 001.002.004.000 - 001.002.004.255 , 000 , China Internet Information Center (CNNIC) 001.002.008.000 - 001.002.008.255 , 000 , China Internet Information Center (CNNIC) 001.009.096.105 - 001.009.096.105 , 000 , Botnet on Telekom Malaysia 001.009.102.251 - 001.009.102.251 , 000 , Botnet on Telekom Malaysia 001.009.106.186 - 001.009.106.186 , 000 , Botnet on Telekom Malaysia 001.016.000.000 - 001.019.255.255 , 000 , Korea Internet & Security Agency (KISA) - IPv6 Policy 001.055.241.140 - 001.055.241.140 , 000 , Botnet on FPT Telecom 001.058.181.097 - 001.058.181.097 , 000 , AP2P on China Unicom Heilongjiang proxy 001.062.189.215 - 001.062.189.222 , 000 , botnet on China Unicom Heilongjiang 001.063.018.022 - 001.063.018.022 , 000 , SMSHoax FakeAV Fraud Trojan 001.093.021.147 - 001.093.021.147 , 000 , SMSHoax FakeAV Fraud Trojan 001.093.026.097 - 001.093.026.097 , 000 , SMSHoax FakeAV Fraud Trojan 001.179.128.002 - 001.179.128.002 , 000 , SMSHoax FakeAV Fraud Trojan 001.179.128.003 - 001.179.128.003 , 000 , SMSHoax FakeAV Fraud Trojan 001.179.136.040 - 001.179.136.047 , 000 , Communications Police Bangkok 001.179.138.224 - 001.179.138.231 , 000 , Royal thai Navy College Of Nursing 001.179.140.200 - 001.179.140.203 , 000 , Traffic Police Bangkok 001.179.146.052 - 001.179.146.055 , 000 , Central-Police-Training-Division TH 001.179.147.002 - 001.179.147.002 , 000 , SMSHoax FakeAV Fraud Trojan 001.179.153.216 - 001.179.153.219 , 000 , Ministry-of-Public-Health TH 001.179.164.124 - 001.179.164.127 , 000 , Armytp45-TH 001.179.167.188 - 001.179.167.191 , 000 , Southern Border Provinces Police Operation Center 001.186.188.000 - 001.186.188.127 , 000 , Detected AP2P on D-VoiS 001.202.096.052 - 001.202.096.052 , 000 , Detected AP2P on ChinaNet Beijing proxy 001.204.179.141 - 001.204.179.141 , 000 , Botnet on ChinaNet Guizhou 001.226.051.218 - 001.226.051.218 , 000 , Detected AP2P on SK Broadband proxy 002.051.000.165 - 002.051.000.165 , 000 , SMSHoax FakeAV Fraud Trojan 002.056.009.116 - 002.056.009.116 , 000 , Detected kad activity on E-Rent LLC (hijacked) 002.061.073.179 - 002.061.073.179 , 000 , SMSHoax FakeAV Fraud Trojan da bi ovo radilo reicmo na qBittorrent (koji ja koristim) fajl mora da se preimenuje iz guarding.p2p u ipfilter.dat i da se učita u sam program Koristim jednostavnu skriptu za automatski apdejt #!/bin/sh cd ~/.config/qBittorrent/ curl -sS http://upd.emule-security.org/ipfilter.zip > ipfilter.zip unzip ipfilter.zip rm ipfilter.zip rm ipfilter.dat mv guarding.p2p ipfilter.dat i to je to...1 poen
VPN može ekstra da se naruči - košta $71.76 na dve godine. Sa tim može da se gleda Netflix, Hulu, HBO Max, Amazon Prime Video, Disney+. Cepa brzina preko VPN skoro kao i bez njega...Preko mog rutera može direkt VPN tunel da se otvori sa njima. A može i posebno na svaki uređaj i/ili browser.... CTO njihov https://www.crunchbase.com/person/andrey-meshkov Firma radi na Kipru po njihovim zakonima1 poen
1. Teški... prešao na MTS optiku zbog istog problema. (Nema N1 na MTS - zabole me mnogo zbog toga) 2. Da ... (i mnogo više od toga) ako je dovoljno dobar ruter (zver od rutera) - postavljen u bridž mode koji ne daju na SBB 3. RB4011iGS+5HacQ2HnD-IN Evo ti celo uputsvo i problematika oko toga https://www.diyaudio.rs/topic/9837-problem-sa-sbb-ruterom/page/6/#comment-403302 Na sve ovo sam dodao pre neki dan /img/og-welcome.png?version=335 AdGuard DNS — ad-blocking DNS server ADGUARD-DNS.IO Create your DNS server that will protect your personal data, block ads and tracking and allow you to control access to specific content on the Internet. Nemam više nikakve reklame - ni na jednom MacOS/iOS uređaju - bilo da je vajrles ili ne....for free... Zvekneš DoH DNS Server i ćao-zdravo reklame - maliciozni sajtovi i trakeri + Statički isti Da ne pričam da može bilo koji ovaj servis na klik da se isključi1 poen
Uvjek se nađem u nedoumici da objasnim kako svira DAC. Kad pogleda koju opremu imam, prosječan član ovog foruma če reči bljak. E to što je Topping D10s + Sparkos izvukao iz nje to dolazi do granice nevjerovanja. Dolazi u sukob sa raznoraznim shvatanjima. Scena vrlo kvalitetna po širini i dubini, definicija instrumenata perfektna, dinamika extra. Recimo kad Mingus počne da zavrče svoje vragolije i kada možete osjetiti svaku muzičku liniju, a on gruha li gruha. I nije to više nikakva kakofonija nego žestoka i komplikovana muzička struktura. Ili recimo Pogorelić, ovaj novi CD, kad gruhne po onom klaviru, a Sparkos sve viće: " ma mogu ja i bolje jarane". Da ne govorimo o Mozartovom Requijemu, Carmina burana ili Vivaldijeva 4 godišnja doba. Tu sistem pokazuje šta sve može i šta nemože. Sad mogu da shvatim @Muad'Dib kad on kaže, poslije njegovih apgrejdova, da mu je DAC u klasi onih od 2000 €. Svaka njegova stoji na mjestu i ima puno opravdanje. Ja sam svoj san ostvario pa vi sad vidite štačete. Avantura se nastavlja. Ovih dana stiže iz Britanije Qed RCA interkonekt, a mislim da sam skurbanio donatora da ljetos prihaja u moj dom i Supra USB. Ako ima @NIXIE certifikat onda se mora poslušati! Trenutno čekam da mi Matej skompletira kondova za skretnicu i ide nova žica u kutijama. VDH CS18, pa šta Bog da.1 poen
da li ce Black da zasija,ce se saznati jedino ako je doneses na slusanje u svoj sistem,i sve pogledas kroz kontekst zvuka kompletnog sistema....ako pogledas onaj drugi YT video sto je @Kuja okacio (AT440m vs Black vs Bronze) na tom Black svira prividno najbolje,ostale 2 sviraju tupo...moze se desiti ako je zvuk celog sistema na toplijoj/tamnijoj strani,da Black bude melem za sistem,uz to unosis u sistem i cevni phono,2 nove komponente u isto vreme,moze se desiti da dodje do nekog ispravljanja krive Drine,sasvim neplanirano...tu Black su dubiozno elaborilali svojevremeno na Steve Hoffman forumu pre jedno 7-8 godina,trebalo bi izbunariti tu temu,ali ako se dobro secam islo se na kombinaciju 27KOhma,umesto standardnih 47KOhma i neku cudno kapacititvno opterecenje.... sretno1 poen
I upravo tu je moja prednost. Kako nemam nameru da (ponovo) sakupljam hiljade ploca...ovih stotinak komada ce biti(ili je vec) probrano kao M,M-,VG+. Imam desetak japanskih izdanja iz sesdesetih i sedamdesetih godina koja kao da nisu slusana. Imam prva izdanja (americka i engleska) takodje u savrsenom stanju. Imam nova reizdanja koja su,po difoltu,nova. To ce biti moja zaostavstina...da sve ploce budu 1. M,M-,VG+ i 2. izdavacka kuca mora biti audiofilska. Da li sada Black moze da zasija? One ploce koje ne zadovoljavaju ove kriterijume,necu kupovati,a ako zelim da imam te naslove, bice na cd-ima.1 poen
Pa jeste .... mi smo poludeli a ti si postao normalan. Sad ćeš i ti ponovo1 poen
Da li ste vi ljudi normalni? 🤭 U proteklih pet godina sam bio lenj da uključim nešto da svira, a sada ću odjednom da vadim čipove... Baš1 poen
sta me briga , ja vise nisam u opasnosti od kratkog spoja izmedju dve slusalice ......... razvio sam trajni , pa vise nista lose ne moz da mi se desi0 poena
Pa baš lijepo vidjeti zadovoljne ljude oko sebe! Čestitam na DAC-u! Ne sumnjam da je to sad ozbiljan komad opreme, no najvažnije je to kako si opisao što osjećaš kad ti on priprema mjuzu! Bravo i kudos za obojicu!0 poena
Citao sam dosta na stranim forumima o ovoj temi...da sada ne postujem...ali parafraziracu: 1. Black je bolja od Bronze...dublji basovi,meksi visoki 2. Sa boljim phono preampom,sa Bronzom...zvuk priblizan Black Tako da mi ostaju te dve opcije definitivno...phono preamp je lakse pozajmiti,pa cu prvo probati tu kombinaciju. P.S. Ako drugi phono preamp opravda ocekivanja,plasim se da svrab ne postane nepodnosljiv,pa da dodam i Black...evo trcim da uplatim LOTO,za svaki slucaj.0 poena
Pa vadices, naravno, neces valjda to ostaviti tako... E sad, kako ce to vadjenje da utice na...ostale stvari, to ne bi znao kasti...0 poena
Ma neeeee... Ja sam poludeo... Ove godine u junu slavimo prvu godišnjicu braka... Štono kažu, što bi meni bilo bolje Mada, realno, bolje mi je 😁0 poena
Trenutno na sajtu 3 članova, 1 Skrivenih, 2158 Gosta (Pogledaj celu listu)
