Showing content with the highest reputation on 01/12/22 u svim oblastima
  1. Aleks
    Malo malo pa se vratim "korenima" Čoveče, sad kad razmislim, mojima nije bilo lako... Ovo ide po pola dana (drugu polovinu u školi) na najjače, još tad napravio svoj prvi sub od nekog PA bassa, kutija ko natkazna Užas jbt
  2. Mrzi me da tipkam, pa copy paste sa Big Diya: Well, I'm certainly not first one to ask Modushop Team is there solution for slim Monoblock case .......... Anyway , recently I did chat with our Italian friends ...... and thet are evidently willing to do something Basic idea is to have 4U/400 case, but narrower Entire package, (hoping they did understood my ZMEngrish) consisting of 3 iterations: 1. first logical iteration is one side having 4U/400 heatsink ( I don't care is it one piece or two) , while other side being blank plate ; you can orientate it by wish, so wth pair having one right and one left enclosure 2. second logical iteration is heatsinkless case, intended for separate PSU ( don't ask, I'm first one thinking of pair of cases per side, just as Demonstration of Force, if not necessity) ....... so penny-pinchers among Greedy Boyz can make one (pair) of mono PSUs and zillion of channel cases, then combine them Till End of Time 3.third logical iteration is both sides having heatsink, so you can squeeze nicely thought elegant Beauty of Amp inside ........ from whichever reason - easier to smuggle by Kerber, or esier to put more of them on shelf ..... or you just like them that way set of preliminary pictures enclosed, raw finish, not anodized ......... my Vote goes to front plate (as usual) covering entire width, including heatsinks What ya say ? Basic dimensions are sorta carved in stone ( zillion Greedy Boyz, zillion and one opinion) so don't bother to change that; what I'm asking now is - what you say for width of front plate ........... and do you have any (useful and beneficial!!) idea to add? Unification reasons (price for Greedy Boyz) - dimensions of "cage" itself must be the same for all 3 iterations; Now - I like idea of full width front for case with one and 2 sinks, I like the same for heatsinkless one - when looking them in pair, and I'm sorta ambivalent when thinking about empty space behind wide front plate without sinks; so...... as always - compromises......... I'm sure Gianluca will chime in, to give you details about width of case ...... I deliberately left that for him And yes, 'Talians - Danilo Petrucci is first man alive, after having 2 MotoGP victories, also claiming victory in Dakar stage for motorcycles Go figure; it must be something in the air or water, in Italy
  3. Da crtam wifi? 🤣 Rekoh izmedju.. °|°
  4. vladd
    Gramofonska tema
    X kondovi crkavaju u kratak spoj, jesu iz klase "safety". ali im je posao da prave kurslus i aktiviraju osigurac. Y crkavaju u otvorenu vezu, pa su po toj sigurnosnoj osobini za nijansu povoljniji da se nadju paralelno prekidacu.
  5. NIXIE
    Gramofonska tema
    Oni jesu za te DC napone (400-450V), ali ih označavaju za AC napon. U principu mogu se koristiti svi folijski i keramički kondenzatori nazivnog napona 400VDC ili više, samo si ovi PP X2 izdržljiviji i testirani na višem naponu i time preporučljiviji za ovo. Ja sam ranije stavljao ISKRA poliester kondenzatore 8,2nF 630V jer sam imao gomilu toga i nije bilo problema.
  6. NIXIE
    Gramofonska tema
    275VAC ili 305VAC su obično označeni.
  7. zika
    https://img-9gag-fun.9cache.com/photo/aZr3Kz9_460svav1.mp4 duet.mp4
  8. mod podge sa latexom nisam probao, nesam dobio recept onomad, a gde god sam mogao naruciti premaze, nisu mi mogli dati info o rezultujucoj mekoci..... tako da sam zavrsio sa mojom antipacovskom recepturom imas na mom blogu, Tannoy ako vec ne priupitas i Branka da li ima nesto lokal nabavljivo
  9. Samo da prijavim da sam resio problem. Ovo sa benzinom je upalilo. Vesanja su sada (cini mi se), sasvim dobra. Mislim da sam ih mazao-cetkao 5 dana. Bas se, najzad, pojavio....sad, koliko je to dobro, videcu u narednih mesec dana. Hvala svima, narocito Zenu i Branku na savetima.
  • Trenutno na sajtu   4 članova, 1 Skrivenih, 1924 Gosta (Pogledaj celu listu)
