Showing content with the highest reputation on 05/02/21 u svim oblastima
  1. zerowaf
    Šta se p(j)eva?
    U autu imam tri USB-a od po ca 30 GB. Na jednom je Jazz, na drugom klasika, a na trećem mješanac Rocka, Bluesa i, pajz sad, Metallice. No, ništa od toga mi nije odgovaralo. Krenuo sam oko ponoći za Domaju i trebalo mi je nešto uz što mogu pjevati sam u autu, pa sam na mobitelu našao nekakav Đole mix i stavio na autoplay. Nakon što nisam razbio svijet od šale jer nije bio od stakla, što sam shvatio da je đaba konja vranih, da je Braci žao konja, nakon što sam naučio koliko je dugačka Dositejeva ulica u Novom Sadu i koliko tužnih ljubavi ima naišlo je ovo i, valjda sam bio taman u fazonu da se zaljepi za mene pjesma koju zapravo nisam poznavao i sad ne ide iz glave......
  2. чика-Брка
    Grec 10A ??
    de ode tema, sunac ti kalaisan.
  3. Sent from my SM-N975F using Tapatalk
  4. Pigy
    Grec 10A ??
    Tonska kontrola jedno od ovo dvoje.Stim sto mi se prva nesvidja jer ide prvo tranzistor pa kolo za regulaciju a pre toga mi je predpojacivac,muslim da je bolje da uzmem da napravim ona druga slika ali od tonske regulacije pa nadalje jer vec imam pretpojacivac.Napon ce biti stabilizovanih 18V.
  5. Nesic
    XMOS USB Kartica
    Simultaneous data protocol was used by Philips back in the days of the TDA1540 as the only mode it could be operated in. The TDA1541 then 1541A came later when the I²S protocol was standardized. Thus the TDA1541/A are I²S compatible. But since they were made to be compatible also with previous Philips CD hardware originally intended/designed to work with the TDA1540, they can work in simultaneous data mode... The primary reason I moved to this mode on the 1541 was its convenience when working with up to 192kHz sampling frequencies. Simultaneous mode utilizes two separate data lines, one per channel because the TDA1540 was a single DAC where each channel necessitated its own data signal. Since in this case stereo data are not multiplexed in one line as with I²S but run simultaneously, the frequencies for both master clock and bit clock can be twice as low at any given sampling frequency. Once I ran this chip in simultaneous mode and took regular audio performance measurements, I was very surprised to see its jitter performance better than I’ve ever seen it before.
  6. 1 poen
  7. Nesic
    Nesiceve zanimacije...
    Još dan dva oko sitnica, pa da se puni... Prednja zahteva obradu, i to sam rešio sam da odradim. Videćemo ishod...
  8. Srecko
    Srećkove Zavrzlame
    Da se pohvalim[emoji16]. Uzeh, računarčić NUC “Intel BLKNUC7I3DNK2E”, sa SSD 240GB i 8GB rama na ploči. Proizveden u 11. mesecu 2020. i veoma fino očuvan (za sada radi a dokle će ne zna se[emoji16]).
  9. guja011
    Šta se p(j)eva?
    Balkan Trideset peta-sesta Moj stari vec godinama okrece bicikl svakog dana od kuce do preduzeca prva, druga, treca On je tridesetpeta-sesta bez skole, detinjstva i hleba on je tridesetpeta-sesta uvek tu kad zapeti treba On je tridesetpeta-sesta vecno treca smena on je tridesetpeta-sesta bez kravate, umorna i povijena Minimalac svakog prvog mala firma, sta ce sutra biti topao hleb i litar mleka akontacija, zajmovi, krediti On je tridesetpeta-sesta ne razume svaki izam on je tridesetpeta-sesta podmece ledja za realizam On je tridesetpeta-sesta preko sindikata na more on je tridesetpeta-sesta uvek u parteru, nikad gore
