Showing content with the highest reputation on 04/24/21 u svim oblastima
7 poena
black coffe i 2 drugih je reagovao/la na vladd za temu
Pazi kad niko ne kaze Kinez, slomljen a radi. Da je slucajno njemac, eee tada bi talambasi zvecali3 poena -
black coffe i 2 drugih je reagovao/la na gluv_i_udaren za temu
Moje pukotine na displeju izgledaju još strašnije3 poena -
-Tad sam bio gluplji a imao sluh za medalju. Sad sam za nijansu pametniji ali sam gluv3 poena
^ Ocigledno je da si tada, u tom audio sistemu imao neku "koficu" od phono preamp-a, kao i gramofonskog setupa. Takodje, polizana igla na gram. glavi upravo pravi te senzacije da CD medija bude superiornija u odnosu na vinil.3 poena
Old Soul
Mentok i jedan drugi je reagovao/la na Zen Mod za temu
Did mount 1T813 today, in place of 2N1099 fired it up, it set itself exactly at same Iq (as previously 2N1099) , did just minor tweak of output offset same situation for both channels - everything perfect in static state then connected old crummy Sigene to input, scope to out, no load, just to check does modulation reaching output first channel OK second channel - started , and somewhere at half ( of max) thingie just went South - speaker DC protection dissengaged relays, got 48V across 0R11 resistor group ( where I need to see 110mV) powered it off, logical check - dead mosfet, dead Ge, two 0R22 resistors dead ( there is a reason why there are 2 or 3W jobbies) was it 1T813 Dud ? most likely ...... and now I'm thinking what and how to test them if I decide to get them in quantity it seems test with actual load, fastest way of Ge tossed in 1L container of demi water is easiest way to do it anyway - replaced what's Dodo, checked rest of circuit and fired it up again this time everything went good, so did tried both channels with load, up to clipping2 poena -
Srećkove Zavrzlame
Mikorist i jedan drugi je reagovao/la na zerowaf za temu
Ti su jos i dobri. Vidio sam neke kojima vrat uopce nije ugradjen...uopce ga nemaju, jbt! Al´ kad vidis glavurde gore jasno je da nema tog vrata koji bi to nosio.2 poena -
Srećkove Zavrzlame
zerowaf i jedan drugi je reagovao/la na Mikorist za temu
Ama jurim neke likove na bezri sad - ja njima kripto oni meni sumu na paypal. Ima cak i nekih odavde koji rade. Jedino me strah sto su celavi i imaju kajle oko vrata2 poena -
zerowaf i jedan drugi je reagovao/la na gluv_i_udaren za temu
Struggle is real bro hahahah2 poena -
Srecko i jedan drugi je reagovao/la na zeljkor za temu
Hocu da malo eksperimentisem, pa sam narucio.2 poena -
Srećkove Zavrzlame
vladd i jedan drugi je reagovao/la na shonne za temu
ma kakav Rogic, sve diy se radi ovde na jug samo jos moramo maticne i procesore da kupujemo2 poena -
Srećkove Zavrzlame
Srecko i jedan drugi je reagovao/la na Doktor za temu
Sta su to tacno - dobri sistemi ?2 poena -
Srećkove Zavrzlame
nemate vi pojma kako se flac i slicni formati na dobrim sistemima cuju2 poena -
Srećkove Zavrzlame
Srecko i jedan drugi je reagovao/la na Mikorist za temu
Jbg. A prodao Filips i uzeo gori CD plejer jer je pisalo u casopisu da je bolji A igle na gramofonu sam menjao samo kad riknu. Posle sam saznao da ima bolja od tehniksa. I natakario thorens2 poena -
gluv_i_udaren je reagovao/la na Leonardo za temu
Rešenje je kit za reparaciju šoferke, 800 dindži i vozi https://www.kupujemprodajem.com/automobili-delovi-i-alati/auto-auto-stakla/reparator-za-sofersajbnu-repare-kit-reparacija-auto-stakla/oglas/648990931 poen -
black coffe je reagovao/la na gluv_i_udaren za temu
Hahaha, švabo bi bio smrtno ranjen, a za kineza je to samo ogrebotina...1 poen -
Miko, vidite da to nije za Vas, stalno razmišljate da li će i koliko će BC da padne ili poraste, umesto o devojkama[emoji3]. Stalno ste pod stresom[emoji3]. Ne valja to, a ti cekavi i sa kajlama, kao pravi prijatelji; oni bi da Vas rese tih problema[emoji3].1 poen
Znam kako ti je! Do neki dan sam imao dva mobitela (jedan sluzbeni) i na oba pukotine kao paukova mreza i kud sam ionako corav za na blizu, jos i te pukotine, pa pomicem tekst gore dolje dok ne nadjem dio u kojem mogu procitati nesto.1 poen
Ama tek sad mi je jasno koja je peripetija podici kriptovalute....onaj kraken 5 evra uzima proviziju , banka u Luksemburgu 10 + ovde banka 2 evra - i to na sumu od 50 evra . Plus pises banci izjavu... mamalazi.1 poen
Jos pitas : https://www.audialonline.com/terms/ A mozes i platiti solarno, msm na dlan metnes Rogicu keke.1 poen
A jel prima Rogic pare na paypal ? Gledam da izbegnem doznake1 poen
ajde malo da pricamo o zvuku, dok ne pocne mec1 poen
Srećkove Zavrzlame
Srecko je reagovao/la na gluv_i_udaren za temu
Jeeste, ovo izgleda savršeno razumno1 poen -
Miko da se@shonne kazni primereno[emoji3]. Potpuno je zaboravio Noleta[emoji3]. Možda će danas izgubiti od Karatseva, zbog njega[emoji3]. Bavi se nekim DAC-ovima umesto da se koncentriše na Noleta[emoji3].1 poen
Srećkove Zavrzlame
Mikorist je reagovao/la na gluv_i_udaren za temu
Nije to ništa, ima on i audiophile grade d-link router...1 poen -
Da vidis samo pajpovi kako izgledaju na Hdplex za hladjenje proceosra. Usro sam se.1 poen
Ja sam tek krenuo da sastavljam studijski PC . Ocekujem jos neke delove. Onaj USB dodatni mi nije jasan i da li ovo vredi 600 i kusr evra https://audiopc.shop/en/winkel/usb-cards/audiophile-usb-card-v6-ppa-studio-paul-pang/ Pa cu tek onda da probavam Aye i ostalo1 poen
sa Aya, sa Pass line delom preampom i celim ovim sistemom, je legla kao detetu, samar . Neverovatno kako ovo zvuci, neverovatno. pure dsd, ovih dana cujemo. Ocekujem jos bolje.1 poen
izvolte na kafu, na raspolaganju dva dac-a, AYA sa tda1541A i Pure dsd1 poen
Zasto mora bas da bude to slusanje na FAK ? Mislis da ce tamo da se najbolje cuje ta superiornost FLAC-a u odnosu na druge medije ?1 poen
Postajemo neobzirni, starački, mozak krece da odbacuje neke detalje i procese, kao da je prezasićen. A ako se nešto vežba, to i drugačije stari i na drugačiji način se vremenom deformiše.1 poen
To je velika nepoznanica. Da nismo mi muškarci uspeli da potisnemo neke frekvencije[emoji3], pitanje je da li bismo evolucijski opstali[emoji3].1 poen
Šta, pa Vi ste bar znate, Mika sad ko zna šta čuje[emoji3]. Godinama navikao da ne čuje određene frekvencije (suprugu npr. znam iz ličnog iskustva) a sad bi hteo da čuje flac u punom sjaju[emoji3][emoji3][emoji3].1 poen
Svapski Stereoplay ? Nisi valjda odatle kopirao ?1 poen
A imao sam i dobar gramofon za to vreme i dek Nakamichi. Nikad nije zvucao CD Enigme bolje od tog. Cak sam rezao posle na Plekstoru pre nego sto je riknuo sam CD - jok....Nikad nije zvucao isto. I sad skidam razlicite verzije istog albuma u Flac ...jok more nije to to... Da li je kvalitet tog prvog - ili sluh - pojma nemam.1 poen
Ja imam suprotno iskustvo. Recimo prvo sam kupio plocu Yello - Flag pa potom CD. Zvuk je bio bolji za par kopalja na CD. Za Enigmu da ne govorim. Pokojni cale doneo iz Nemacke CD te godine kad je izasla. Ordjinal. Usro sam se u gace 1990 kad sam je pustio na Filips plejeru preko Sony pojacala i zvucnika. I to sam bas tad primecivao detalje i slojeve koje nema traka niti ce da ima ikad- tad sam imao definitivno bolji sluh nego sad.1 poen
Setih se necega...jos kao klinac. Moj rodjak je imao DUAL liniju, tamo negde krajem osamdesetih. Ja obozavao da slusam Tinu Turner na ploci kod njega, pa presnimio na kasetu. Nakon par godina, kupim ja CD plejer, pustim "We don't need another hero". Koje razocarenje! Bolje je zvucalo na kaseti (Basf chrome) nasnimljenoj sa ploce, nego na CD-u. Zvuk CD-a, kao da su Tinu Turner provukli kroz metalnu presu...1 poen
( Aneks Zero pohvali ) Lemovi mu tamjanom mirišu, anđeli se kroz drajvere glasaju Strujne žile s' nebesa pronose, blagoslov našijem ušima Zen Pesma nad pesmama1 poen
jok, propricao sam Eagle vise ne koristim ni mis ni tastaturu samo sedim i gledam u ekran1 poen
Gramofonska tema
Spachek je reagovao/la na gluv_i_udaren za temu
Ja kontam da me gramofon sa trubom deli od razvoda1 poen
Trenutno na sajtu 4 članova, 2 Skrivenih, 1830 Gosta (Pogledaj celu listu)
