Showing content with the highest reputation on 12/14/16 u svim oblastima
skrstic i jedan drugi je reagovao/la na Eci za temu
2 poena -
Prezentacija zvučnika Notax M
Dual i jedan drugi je reagovao/la na grau. za temu
cuo sam da su se švajseri iz neke zemlje pobili u redu dok su uplaćivali po neki cent za autorska prava passu, da je ovaj morao da ugasi pejpal nalog da se ne bi ponavljale ružne scene2 poena -
Leonardo i jedan drugi je reagovao/la na Aleks za temu
https://youtu.be/tnav0ZHLex4 Dole u komentarima se pojavio neki AndyAndy (prvi komentar) i dao baš sličnu izjavu kao neki ovde: Love the sound...BUT...the 3 inch full range driver the W5 using is the Fountek Fe85. A measly $12.80 each at partexpress. I don't care how it sounds...ain't gonna pay $3,500 base price for el cheapo drivers. Way too many choices out there....sorry. A onda je AudioPrana objasnio: So, it's the parts, not the engineering or the implementation that indicates sound quality. Well, that's an easily understood premise. Over-simplification is long been a cornerstone for those who have no engineering background. It's a way to quantify a belief or desire to know more than they do. Your assertion is backed up by everything except history and fact. Firstly, a speaker is made of more than just parts. It's first and foremost a design. For instance, the W5SE+ has silver and gold caps, silver wire, BB add ons etc. But even without those, it is the sound and the engineering behind the sound one pays for. Goldmund uses very inexpensive drivers in most of their speakers. It's not because they haven't auditioned the most expensive, or that they couldn't easily afford them. It's because, a certain driver (in this case, with more pliant surrounds) they can manipulate in a way of their choosing. You pay for the sound, for the engineering behind the sound, and for the knowledge that you'll never need another stereo (tank build quality) and styling...not for a bunch of parts. Any moron can buy some parts. It's typical in the audiophile community and diy communities to focus on parts price...on easily explained reasons for sound. ('did you see that cheap volume control?' 'can you believe the caps he used in that $30k amp?; 'his internal wiring is what I get for $3 a ft. at Rat Shack.'; & 'those transformers are off the shelf crap.' it's a way to feign knowledge of how something actually works, and thereby assessing a false value. True knowledge of how a driver is loaded (far more important than the driver itself) would be beyond what most DIYers could quantify. Because it takes lots of work and actual mathematics and listening. I would liken it to someone saying, 'you know the LED lights they're using in the Hubble Telescope, only cost $3.75 a piece. What a rip off for 2.5 billion dollars.'; Because getting into the years of work it took to gain the knowledge much less the engineering process to make something work the way they want, is just way beyond their ability to discuss. If you can make a speaker, that approaches the sound of the W5SE+ using the similar parts, please let me know. We'll buy it. But first, do me a favor. Add up the hours or years it took you to figure it out, the parts cost (not just the one's you used but the dozens you sampled), production costs, and we can determine at what price it should come to market. Amin2 poena -
Sutra ti javim - motor je u radionici kod majstora, ne znam oznaku1 poen
Ma užas !
Mikorist je reagovao/la na sir Oliver za temu
http://www.boredpanda.com/vladimir-putin-speaker-sound-of-power-petro-wodkins/1 poen -
@Mikorist Ma nije ovde reč o Boenikama, već o suštini omalovažavanja inženjerstva uopšte. Kao što reče, one LED diode na Hubble teleskopu koštaju $3.75/komad. Zašto onda Hubble košta milijarde dolara? BTW, si siguran da si video temu o Boenickama? Na našem forumu?1 poen
Ja sam precizirao josh odavno. http://www.diyaudio.rs/JBL/ skup hobi1 poen
gospodo švajseri, precizirajte: regalski ili knjigopolični zvučnik?1 poen
Ako uspem da nadjem vremena, sto kako stoje stvari nece ici lako , pravim svoju varijantu sa M2 jedinicama. Sumnjam da ce to da se desi pre kraja sledece godine ako ovim tempom budem morao da se bavim tekucim obavezama.1 poen
ako je na lampi napisano ecc82 12au7 5963 ta lampa mora da ima jako slicne karakteristike kao sto je dato u katalogu za tu lampu.5963 je projektovana za profesionalu sa smanjenim Ua -250v ali je zato robusnije izrade i trpi vecu disipaciju na anodi .stavljale su se u logickim kolima zbog pouzdanosti,ali imaju iste karakteristike kao ecc82.budalastina je ko tvrdi drugcije.mnoge 5963 su se pokazale u audio aplikacijama mnogo bolje nego vecina ecc82.ako je guma 14 -75 -155 onda je svaka guma koja ima tu oznaku pasuje na felnu od14 cola itd...imate dosta materijala na netu za tu temu.1 poen
Spachek je reagovao/la na sir Oliver za temu
Prodavci u supermarketu baš imaju ideju da naprave džabe reklamu1 poen -
Vise puta sam se uverio da hi-fi moze biti skup a da jednostavno zvuci lose, a ida bude skup i da zvuci dobro. Da bude jeftin i da zvuci dobro, to j vec malo teze. Zato sam se i okrenuo samogradnji. U ovom slucaju tu lezi zec. Neko napravi u samogradnji dobar zvucnik za normalne novce, ali ako se krene u prodaju, pa se nakace pijavice na sve strane, onda to postane dobar zvucnik za nenormalne novce. Ipak, bolje dobar i skup zvucnik (u konkretnom primeru) nego skup i los zvucnik, a i toga ima koliko hocete...1 poen
kod mene je to bilo slicno prvi pogled na postavljene zvucnike i WAF kaze veliki su posle par minuta e bas su veliki juce je bilo probno slusanje iako moze da se vidi da nisu pozicionirani kako treba zvucnici izanjih ima brdo stvari prvi utsci su da to lepo svira u prvih pola sata lowtheri su prednjacili medjutim kasnije se to dosta umirilo i ujednacilo veoma cist zvuk ,detalji danas cu da pobegnem s posla pa malo ranije da se upustim u slusanje1 poen
važno je da najbolje zvuči sa parama kojima se raspolaže, a ne da se prodaje bubreg u potrazi za svetim gralom1 poen
chakija je reagovao/la na sir Oliver za temu
Opasan ovaj waterjet http://img-9gag-fun.9cache.com/photo/a2dDeOO_460sv.mp41 poen -
Traži se šema za pojačalo
HomeMadeAudioProject je reagovao/la na mancube za temu
1 poen -
Naglavna lupa. http://www.proelectronic.rs/LUPA-NAGLAVNA-LUPA-NAGLAVNA-9080.htm1 poen
Ne može Boki, niko da te razume, ko ne pravi zvučnike... Odnosno, svako ko je pravio, makar kao diy, a da to ispadne baš profi, zna koliko sve ispadne na kraju. Ja sad kada napravih kalkulaciju za Boenicke klon sam se frapirao... jeste, npr. bas drajver piše na sajtu 36e komad, ali dok to dojaše ovde ode na preko 120e za par... Slično je i sa onim "jeftinim" Fountecima, piše na sajtu 15 evra, a dok stigne do mog stana izađe na 50e za par. Pozadinski visokotonci su 14$ oba, a poštarina iz Solena je 85$ (nema nigde u Evropi da se nađu pa mora iz Kanade jer parts-express ne šalje u Srbiju), pa dodaj PDV carinu i muzički dinar... Dodati na to delove za skretnice, žice, konektore, drvenariju - stolar mi uzeo 30e samo da mi obradi jasen na datu debljinu, oblaganje iznutra, furnir, koža, lakiranje... prsteni od 3mm na CNC-u su tek posebna priča + eloksaža za njih. Sve to može u diy varijanti, ali da bi ispalo profi, da izgleda BOOM i da te nije sramota da prodaš nekome da stoji u njegovom životnom prostoru i izaziva divljenje + da svira sjajno... Izađe mnogo, mnogo više od sumirane cene drajvera. A gde su ruka i uloženo znanje? Realno, ovaj zvučnik npr. je u klasi Dayensovog Grande Piccolo-a - možda svira i bolje, možda svira i lošije, ali 100% sam siguran da su u istoj klasi i da su razlike među njima na nivou nijansi, što će reći: Nisam mnogo pogrešio, verujem... Ni ne pokušavajte da ga svrstate u klasu sa Sudio Monitorom, ili još gore Tizo-om...1 poen
black coffe je reagovao/la na Vix za temu
Ma ljudi bitno je da se nesto radi. Ako se proda, proda, ako ne, ne. Svaka roba ima svog kupca i svoju cenu. Samo nek se prave zvucnici, sa rupom ili bez nje...1 poen -
black coffe je reagovao/la na Impuls za temu
Evo par redova iz jedne pesme. Mnogo mi ovo sve lici na tu pesmu... Boki ne brini za cenu, meni je korektna jer mene Scanovi sa clasic drajverima kostaju 1000 a sam sam radio ...Jer su neko vreme Proveli na sceni Bili su vitez Ili gusar strašni S životinjama pričali Ko u pravoj basni Ili milioner U velikom svetu Sa par novčića U pocepanom džepu. Grad utihne I sve se utiša Zavesa se spusti Bez pravoga bisa Maleni su opet Svak u svome kutu Al u oku iskra Na prelepom putu.1 poen -
black coffe je reagovao/la na ninja za temu
Ajmeee, sve pametniji do pametnijeg ... ako nemate para da kupite nemojte ni kupovati, ko ima i svidja mu se, nek kupi. Ko nema a svidja mu se, nek posudi ili nek baci cigare, smanji voznju automobilom (ili ga proda, a motor zadrzi), ne ozeni se (ili se razvede) i ne pravi djecu ,... Boki, tebi sve najbolje i da ih prodas bilion, sto ovdje, sto tu .... i ako mozes, dodaj i jos jednu 0 na kraju1 poen -
Trenutno na sajtu 2 članova, 1 Skrivenih, 1373 Gosta (Pogledaj celu listu)
