Mikorist Napisano Jul 30, 2022 #4842 Napisano Jul 30, 2022 Možda i nije - imaju dva uređaja u kompletu Super -RARE- Yamaha AD8X - DA8X (8x PCM63P-KY Burr-Brown) | Reverb REVERB.COM For sale is a rare to find combo Yamaha AD8X and DA8X converter with 8 PCM63P-KY Burr-Brown chips, all in fully working conditions and great aesthetics. a nisam uspeo da nađem za dž service manual za AD8X
neskor Napisano Jul 30, 2022 #4844 Napisano Jul 30, 2022 (izmenjeno) a ovo je DA8X http://www.fetaudio.com/wp-content/gallery/da8x/img_4982o.jpg https://www.synthxl.com/wp-content/uploads/2021/11/yamaha-DA-8X-Service-manual.pdf Major parts in DA8X: 1. DIR2 chip: YM3436D – this is a digital interface chip accept both AES/SPDIF and Y2 format signal widely use in Yamaha products since 1988. It is used in D2040 also. 2. YM6067: Parallel to Serial and serial to serial buffer x 2 chips, one chip support total 4 channels digital signal. 3. SM5803APT: 18 or 20 bit 8x oversample filter x 2 chips. 4. PCM63-KY or Y: DAC 20bit x 8 pcs; well know ladder type DAC which sound best back in 1989 period. 5. IV op-amp: M5238 dual op-amp. 6. Drivers op-amp: NE5532. 7. Resistor is 1/8W metal film resistors; not like D2020 use RMA resistors. 8. E-Capacitor: Elna Durex grade, I dissolder and verify the capacitors are still very good after 30 years. 9. Output couple capacitor is MUSE bi-polar Green capacitors. 10. Other film capacitor are either 5% or Soshin brand. Izmenjeno Jul 30, 2022 od neskor LightMatic and Mikorist je reagovao/la na ovo 2
Mikorist Napisano Jul 30, 2022 #4847 Napisano Jul 30, 2022 https://novi.kupujemprodajem.com/audio/cd-plejeri/akai-cd-69-hi-end/oglas/137293743?filter_id=1745137451 evo jedan CD plejer za rastur Koliko košta par čipova ni ovo nije mnogo
Koja Napisano Jul 30, 2022 #4848 Napisano Jul 30, 2022 Nasli su kako da nazovu CD player Mikorist je reagovao/la na ovo 1
Brijac Napisano Avgust 26, 2022 #4850 Napisano Avgust 26, 2022 Phy Hp full range zvočniki WWW.BOLHA.COM Phy Hp full range zvočniki Samo za poznavalce, kot novo! Cena po dogovoru. +386 41 Isti lik?
vladd Napisano Avgust 30, 2022 #4851 Napisano Avgust 30, 2022 Quad 33 + Quad 405 - Limundo.com WWW.LIMUNDO.COM Čuvena kombinacija predpojačala i pojačala kod audiofila širom sveta. Fenomenalna zvučna slika. Odlično očuvano. Kolekciona.
Zen Mod Napisano Avgust 30, 2022 #4852 Napisano Avgust 30, 2022 da je do 300 keka, pa da bude predmet igranja, i to teskog ovako kako jeste, samo za ukras
vladd Napisano Avgust 30, 2022 #4853 Napisano Avgust 30, 2022 Valjda se misli, kada si ljubitelj... Mada ima i opcija da se ponudi manje.
Zen Mod Napisano Avgust 30, 2022 #4854 Napisano Avgust 30, 2022 toga ni Doktor vise nije ljubitelj, po tu cenu vladd je reagovao/la na ovo 1
Doktor Napisano Avgust 31, 2022 #4855 Napisano Avgust 31, 2022 13 hours ago, Zen Mod said: toga ni Doktor vise nije ljubitelj, po tu cenu Kako nije ljubitelj "toga" ? Međutim, prodavac piše na oglasu da je to "čuvena" kombinacija preamp/amp. Nije tačno. Dva uređaja iz dve različite Quad linije vezane hronološki. Quad 33/303 je bio kombo, potom se pojavio Quad 44/405. 33/303 kombo bio za ESL 57, a 44/405 za ESL 63 ( čisto da se podsetimo ). Cena ova dva uređaja govori da je poslednjih par godina sve "nasvirano" sa cenama, pa tako i ove 2 komponente. Svojevremeno sam pazario Quad komplet 33/303/57, nakon nekih 6 meseci 33/303 kombo ( 33 preamp nije bio u radnom stanju, praktično za delova ). Cena "po komadu" je bila upola gore navedene cene, tako da je @Zen Mod delimično u pravu što se tiče epiteta "ljubitelj". LightMatic and NIXIE je reagovao/la na ovo 2
Kuršum Napisano Septembar 1, 2022 #4856 Napisano Septembar 1, 2022 https://www.kupujemprodajem.com/audio/pojacala/quad-405-quad-33/oglas/141025257 Evo pojeftinilo.
Kuršum Napisano Septembar 1, 2022 #4857 Napisano Septembar 1, 2022 Znam momka, Kuršumlija je moj grad. Ona uređaja su rifrešovama i sređena. Igor je dobar dečko. vladd and Doktor je reagovao/la na ovo 2
ManicP Napisano Septembar 26, 2022 #4859 Napisano Septembar 26, 2022 Eto nove pločke valjanog albuma... Videosex-Videosex LP (Reizdanje, Pre-Order,Oktobar) - Kupindo.com (72278337) WWW.KUPINDO.COM Videosex-Videosex LP (Reizdanje, Pre-Order,Oktobar) Oficijalno reizdanje legendarnog albuma slovenačkog synth-pop sastava Videosex, prvobitno objavlj LightMatic je reagovao/la na ovo 1
Koja Napisano Septembar 26, 2022 #4860 Napisano Septembar 26, 2022 Ne znam kakvo je to konkretno reizdanje, Ali sve te nove ploče što se sad prodaju, 180 grama, fensi pakovanje itd., zvuče krš. Tačno se vidi da su prosto uzeli CD master i narezali na ploču. Nikoga ne interesuje da nađe proper LP master iz tog vremena. Pa im ploča zvuči mutno, ne čuju se visoki tonovi, smešno kad se pusti uporedo sa starim izanđalim pločama iz jugoslavije koje su radili pijani. Naravno verovatno ima izuzetaka u vidu nekih kuća sa audiofilskom muzikom, ali ja pričam u glavnom o popularnom roku itd. LightMatic and vladd je reagovao/la na ovo 1 1
krca44 Napisano Septembar 26, 2022 #4861 Napisano Septembar 26, 2022 (izmenjeno) Jugoton, par izdanja koja imam su dobra. A to sto si primetio za visoke tonove - e to vazi i kad Ameri urade press sa analogne trake i naplate ga dosta skuplje. Jednostavno zvuci zatvorenije od nekadasnjih ploca. Svasta se promenilo u tehnologiji stampanja ploca i smatram da je jako tesko dobiti taj otvoreni zvuk kakav je nekad bio. Na primer formulacija za vinil krofnu od koje nastaje vinil vise nije ista, pa redom, uz lanac ka izvoru - koji je u 99℅ slucajeva DSD ili high-rec pcm jerbo niko vise ne radi remaster u analognom domenu, cak i kad imaju pocetnu analognu traku, cesto u ko zna kakvom stanju. Na kraju dodaj da svi mi pomalo razlicito cujemo i ta zatvorenost koju ti primecujes, cujem i ja ali - mnogi drugi je ne cuju. Izmenjeno Septembar 26, 2022 od krca44 LightMatic and zerowaf je reagovao/la na ovo 2
NIXIE Napisano Septembar 26, 2022 #4862 Napisano Septembar 26, 2022 Nakon tolikih decenija, ima li vajde od starih master traka, to je pitanje? U principu te istorijske vrednosti su baš i sačuvane zahvaljujući digitalnoj tehnologiji za buduće generacije. Mada malo njih će to stvarno zanimati, mislim na te buduće generacije. Ipak je to neka naša mladost, a ne njihova. Koja je reagovao/la na ovo 1
