Koja Napisano Jul 19, 2023 #45 Napisano Jul 19, 2023 13 minutes ago, Mikorist said: A pre toga će da bude generalni reset planete. Neki asteroid ili vulkan i/ili zemljotres - klimatska promena. Koji će vratoti gospodu na toljage i sekire. Survival uživo. Analogni A mass extinction is a short period of geological time in which a high percentage of biodiversity, or distinct species—bacteria, fungi, plants, mammals, birds, reptiles, amphibians, fish, invertebrates—dies out. In this definition, it’s important to note that, in geological time, a ‘short’ period can span thousands or even millions of years. The planet has experienced five previous mass extinction events, the last one occurring 65.5 million years ago which wiped out the dinosaurs from existence. Experts now believe we’re in the midst of a sixth mass extinction. What’s causing the sixth mass extinction? Unlike previous extinction events caused by natural phenomena, the sixth mass extinction is driven by human activity, primarily (though not limited to) the unsustainable use of land, water and energy use, and climate change.
Mikorist Napisano Jul 20, 2023 #46 Napisano Jul 20, 2023 Još malo pa nećemo morati da kucamo na forumu. Može da se integriše kao admin na forumu - pa neka se objašnjava black coffe je reagovao/la na ovo 1
Leonardo Napisano Jul 20, 2023 #47 Napisano Jul 20, 2023 (izmenjeno) "Koji je najkvalitetniji wc papir ?" Da si pitanje postavio sremačkim rečnikom, dobio bi ovakav odgovor. Idealan spoj ekonomije, ekologije i udobnosti. Izmenjeno Jul 20, 2023 od Leonardo Mikorist and Srecko je reagovao/la na ovo 2
NIXIE Napisano Jul 20, 2023 #48 Napisano Jul 20, 2023 pre 57 minuta, Mikorist reče Možete probati različite marke i vrste wc papira kako biste pronašli onaj koji vam najbolje odgovara.
Mikorist Napisano Jul 29, 2023 #49 Napisano Jul 29, 2023 ChatGTP je trruba za programiranje. Nikom normalnom ne savetujem da neke ozbiljne stvari radi sa AI. Znači ne vidi više stvari odjednom, mora da mu nacrtaš tačno šta hoćeš , mogućnost da predvidi šta hoćeš je mala...Primer..... Kazem mu da hoću da se bash skripta zaustavi u loopu ako se pojavi generisan fajl kao Finalni_12345_344.txt a on mrtav ladan kaže ubaci Finalni_12345_344.txt u # Check if any file with the desired pattern was found and break the loop if it was if [ -n "$(Finalni_12345_344.txt )" ]; then echo "File found! Stopping the loop." break fi done a treba da traži po paternu Finalni_*.txt gde zvezda oznaćava sve moguće kombinacije # Check if any file with the desired pattern was found and break the loop if it was if [ -n "$(find . -maxdepth 1 -type f -name 'Finalni_*.txt' -print -quit)" ]; then echo "File found! Stopping the loop." break fi done Unekim slučajevima je totalni idiot. i bukvalista . Ja ovome ne bi dao ništa da mi radi... Samo za igrice gde se životi ne dovode u pitanje. Kola da vozi AI nikako..ima da ga izginemo svi .
NIXIE Napisano Jul 29, 2023 #50 Napisano Jul 29, 2023 Zna li Arduino da programira? Možda mi zatreba nekad.
Mikorist Napisano Jul 29, 2023 #52 Napisano Jul 29, 2023 Kažem mu da hoću da iz text fajla odvoji segmente.... segmenti su odvojeni vertikalnom crtom | u fajlu 1.txt text1 | text2 | text3| text4 želim da dobijem u fajlu 2.txt text1 | text2 | text4 iz fajla 1.txt a on mi kaže evo ti python skripta import re # Function to process the text and extract the desired parts def extract_text(input_file, output_file): with open(input_file, 'r') as f: input_text = f.read() # Regular expression pattern to capture the desired text pattern = r'(\b\w+_\w+\b)\s*\|\s*(\b\w+_\w+\b)\s*\|\s*\w+\s*\|\s*(\b\w+_\w+\b)\s*\|' matches = re.findall(pattern, input_text) # Create the new text format from the extracted matches output_text = "\n".join([" | ".join(match) for match in matches]) # Write the new text to the output file with open(output_file, 'w') as f: f.write(output_text) # Example usage input_file = '1.txt' output_file = '2.txt' extract_text(input_file, output_file) Skripta ne radi ništa....Imam prazam fajl. Previša ga tupi i komplikuje.... Rešenje je u bash jedan red cat 1.txt | cut -d '|' -f1,2,4 > 2.txt On kaže u pravu ste izvinjavam se na konfuziji....
Mikorist Napisano Jul 29, 2023 #54 Napisano Jul 29, 2023 I to je pitanje.... postavis mu isto pitanje tek iz 6/6 odgovora dodje do istoga ali to zavisi koliko je opterecenje...baguje za medalju i usporava
Mikorist Napisano Jul 29, 2023 #55 Napisano Jul 29, 2023 Najbolje odgovore daje kad ameri spavaju Navijes sat lepo LightMatic je reagovao/la na ovo 1
Brijac Napisano Jul 29, 2023 #56 Napisano Jul 29, 2023 Jbg, pitanje je da li se pohranjuje odmah, tj. da li iz pohranjenog (ispravljenog) inputa odmah uzima da procesira uzivo. Ako ne koristis placenu verziju, onda sigurno ne. Tu koristi baze mesecima u nazad.
NIXIE Napisano Jul 30, 2023 #57 Napisano Jul 30, 2023 Garantujem da ne zna šta je poluautoput po ceni kompletnog autoputa. Zbora and gluv_i_udaren je reagovao/la na ovo 1 1
Aleks Napisano Jul 30, 2023 #59 Napisano Jul 30, 2023 pre 20 minuta, NIXIE reče Garantujem da ne zna šta je poluautoput po ceni kompletnog autoputa. Kao jezički model zasnovan na GPT-3.5, nemam pristup trenutnim podacima ili cijenama nakon rujna 2021. Međutim, možemo objasniti što je poluautoput i kako se razlikuje od potpunog autoputa. Poluautoput (engl. expressway ili semi-highway) je vrsta ceste koja je slična autoputu, ali može imati neka ograničenja u odnosu na potpuni autoput. Evo nekoliko karakteristika poluautoputa: Ograničenja brzine: Poluautoputi često imaju niže ograničenje brzine u usporedbi s potpunim autoputevima. Raskrsnice i križanja: Za razliku od autoputa, poluautoputi mogu imati raskrsnice, križanja ili semafore na nekim dijelovima, iako su obično ograničeni na mjesta gdje je to nužno. Prilazi i izlazi: Poluautoputi često imaju manje prilaza i izlaza u odnosu na autoputeve. To znači da je pristup ograničen na određene točke i nije tako čest kao na autoputevima. Manji broj traka: Poluautoputi obično imaju manje traka u usporedbi s autoputevima. To može rezultirati manjom propusnom moći i većim gužvama u prometu. Cijene gradnje i održavanja poluautoputa bit će manje od potpunog autoputa zbog ovih razlika u karakteristikama. Važno je napomenuti da su politike i standardi u vezi cesta i prometa specifični za svaku zemlju, pa će stoga i karakteristike i cijene poluautoputa varirati ovisno o mjestu. Ako želite znati trenutne cijene gradnje ili kakva je situacija u vezi poluautoputa u određenoj regiji, preporučujem da se obratite nadležnim tijelima za ceste ili stručnjacima iz te oblasti.
Archangel Napisano Avgust 7, 2023 #61 Napisano Avgust 7, 2023 (izmenjeno) Ne postoji veštačka inteligencija. To je potpuno pogrešan naziv i opis onoga što ljudi smatraju veštačkom inteligencijom. To što mi smatramo veštačkom inteligencijom je samo napredniji skup algoritama u veštačkoj neuralnoj mreži. Uzgred odgovori koje algoritam daje, su čist plagijat ljuckih misli i razmišljanja. Ni ne pomišljajte da je veštačka inteligencija svesna ili da može to da bude. Može da liči na inteligenciju, može da liči na svesnost ali zapravo nije to i neće ni biti. Pričamo o algoritmu. Koliko god je napredan to je ipak samo algoritam koji nema ambicija, želja, u smislu u kom ih čovek ima. Za to bi trebala da bude živa. A "ona" - to, nije ništa više od skupa silikona, električnih impulsa u obliku nula i jedinica. Može se koristiti kao veoma napredan alat i ništa više od toga. Može da oponaša inteligenciju kao što rekoh ali nikada neće biti to. Izmenjeno Avgust 7, 2023 od Archangel LightMatic je reagovao/la na ovo 1
Brijac Napisano Avgust 7, 2023 #62 Napisano Avgust 7, 2023 1 hour ago, Archangel said: nikada neće biti to. Ne bih se kladio u to Malo je pretenciozno pricati u apsolutima, pogotovu za ovakve stvari. Zbora je reagovao/la na ovo 1
Archangel Napisano Avgust 7, 2023 #63 Napisano Avgust 7, 2023 (izmenjeno) 7 minutes ago, Brijac said: Ne bih se kladio u to Malo je pretenciozno pricati u apsolutima, pogotovu za ovakve stvari. Ako bi se ikada desilo nekim čudom u šta sam siguran da neće. Bila bi to naj mračnija svest koju si u životu video. Jednostavno mrtve stvari ne mogu imati svest. Život>Svest>Inteligencija. Drugačije ne može. p.s. Može samo da oponaša gore navedeno ali nikada neće biti to. Izmenjeno Avgust 7, 2023 od Archangel
Brijac Napisano Avgust 8, 2023 #64 Napisano Avgust 8, 2023 Zar nije biblija/hriscanstvo puno cuda, mrtvi postaju zivi i tako to? No, sve je nemoguce dok ne postane moguce. I ovaj nas hobi je takav :) Zbora je reagovao/la na ovo 1
zika Napisano Decembar 3, 2023 #66 Napisano Decembar 3, 2023 (izmenjeno) ChatGPT Can Reveal Personal Information From Real People, Google Researchers Show WWW.VICE.COM The popular AI chatbot is divulging sensitive information from its training data, according to a team of researchers at Google. Scalable Extraction of Training Data from (Production) Language Models ARXIV.ORG This paper studies extractable memorization: training data that an adversary can efficiently extract by querying a machine learning model without prior knowledge of the training dataset. We show... images/chatgpt-extract_fig1poem.png Extracting Training Data from ChatGPT NOT-JUST-MEMORIZATION.GITHUB.IO Izmenjeno Decembar 3, 2023 od zika
