Srecko Napisano Septembar 17, 2024 #7041 Napisano Septembar 17, 2024 (izmenjeno) Voleo bi da mi neko objasni, kad vidi ove slike, koliko treba neko da bude lud da da npr. za “Chord Mojo” 500 i više GBP. Bravo Miko, NIXIE i Leo! Izmenjeno Septembar 17, 2024 od Srecko Mikorist and NIXIE je reagovao/la na ovo 2
Doktor Napisano Septembar 17, 2024 #7042 Napisano Septembar 17, 2024 ^ Kako ko ? Pa brednomani. Ima ih gomile. Mikorist, zerowaf, NIXIE and 2 ostalih je reagovao/la na ovo 3 2
Kuja Napisano Septembar 17, 2024 #7043 Napisano Septembar 17, 2024 (izmenjeno) 2 hours ago, Srecko said: Voleo bi da mi neko objasni, kad vidi ove slike, koliko treba neko da bude lud da da npr. za “Chord Mojo” 500 i više GBP. Nije sve u veličini i količini gvožđa i delova! Vaš iPhone je 5.000 puta brži od Cray 2 super kompjutera iz 1985-e. Chord u svojim DAC-ovima koristi FPGA čipove koji su isprogramirani da vrše funkciju DA konverzije i ne zahtevaju isto okruženje kao klasični "off the shelf" čipovi tipa Burr Brown, ESS Sabre, AKM, itd. Pretpostavljam da je to i razlog za manjak delova na PCB-u! 1. What is an FPGA-based DAC? An FPGA-based DAC is a digital-to-analog converter that uses a Field-Programmable Gate Array (FPGA) as its core component. An FPGA is a type of programmable logic chip that can be reprogrammed to perform specific functions. In an FPGA-based DAC, the FPGA is programmed to perform the digital-to-analog conversion process. This allows for more flexibility and customization in the conversion process, resulting in higher quality audio output. 2. Advantages of FPGA-based DACs One of the main advantages of FPGA-based DACs is their flexibility. Since the FPGA can be reprogrammed, it allows for more customization in the conversion process. This means that the audio output can be tailored to the specific needs of the user or application. Additionally, FPGA-based DACs can be updated with new firmware, allowing for improvements in performance and functionality. Another advantage of FPGA-based DACs is their high precision. The FPGA can perform the digital-to-analog conversion process with a high degree of accuracy, resulting in a more accurate audio output. Additionally, FPGA-based DACs can support a wide range of audio formats and sample rates, making them versatile enough to be used in a variety of applications. 3. Comparison with other DAC options There are several other options for DACs, including traditional DACs and Sigma-Delta DACs. Traditional DACs use a resistor ladder network to perform the digital-to-analog conversion process, while Sigma-Delta DACs use oversampling and noise-shaping techniques to improve the audio quality. However, FPGA-based DACs offer several advantages over these options. Compared to traditional DACs, FPGA-based DACs offer more flexibility and precision. The FPGA can be reprogrammed to perform the conversion process in a way that is tailored to the specific needs of the user or application. Additionally, FPGA-based DACs can support a wider range of audio formats and sample rates. Compared to Sigma-Delta DACs, FPGA-based DACs offer more customization options. While Sigma-Delta DACs use oversampling and noise-shaping techniques to improve the audio quality, they are limited in their flexibility. FPGA-based DACs, on the other hand, can be reprogrammed to perform the conversion process in a way that is tailored to the specific needs of the user or application. Izmenjeno Septembar 17, 2024 od Kuja Srecko and LightMatic je reagovao/la na ovo 2
Brijac Napisano Septembar 17, 2024 #7044 Napisano Septembar 17, 2024 Stara nokia je i dalje bolja za obavljanje osnovnih funkcionalnosti, poziv poruka, a mozee i da ucmekas coeka ako te iznervira, iiiii nece se unisti u procesu 😁 E pa vis, tako je i ovde. Ako ne platis sumanuto velike kolicine novca, neces dobiti bolje dakce od krstenog multibit daca Izgubis sve drangulije, i "svetla velegrada", ali dobijas dobru osnovnu funkcionalnost. Vix, LightMatic and Srecko je reagovao/la na ovo 1 2
Kuja Napisano Septembar 17, 2024 #7045 Napisano Septembar 17, 2024 (izmenjeno) ...Čisto da ne budem pogrešno shvaćen, ja lično preferiram zvuk mog DAC-a koji ima PCM 1704K čipove i potpuno diskretni izlazni deo bez OP ampova. Svira mi (za moj ukus!) mnogo bolje od svih Sigma-Delta DAC-ova koje sam imao prilike da čujem. Nažalost nisam do danas uspeo da čujem ni jedan Chord DAC, a mnogi koji jesu kažu da sviraju odlično. Kapiram da zvuk dosta zavisi i od znanja i umešnosti programera koji programira taj FPGA čip. Izmenjeno Septembar 17, 2024 od Kuja Brijac, LightMatic and Srecko je reagovao/la na ovo 3
Brijac Napisano Septembar 17, 2024 #7046 Napisano Septembar 17, 2024 Delta Sigma isto. Ima tih modernih dacovi koji sviraju brukica, bolje nego ove stari porsei, ali kostaju, bas Tu ljudi koji su vrsni programeri i matematicari rade pos'a. LightMatic je reagovao/la na ovo 1
Doktor Napisano Septembar 17, 2024 #7047 Napisano Septembar 17, 2024 TDA1541A - nema dalje. Kuja and LightMatic je reagovao/la na ovo 1 1
Kuja Napisano Septembar 17, 2024 #7048 Napisano Septembar 17, 2024 (izmenjeno) Slažem se, odličan je! Imao sam davno TDA1541A NOS DAC Peđe Rogića sa kojim sam se sit naslušao muzike, ali su nove tehnologije i formati zahtevali da se krene dalje. Sadašnji PCM1704K DAC mi je dao ono što mi se sviđalo kod TDA1541A, pa je sve to još unapredio. Izmenjeno Septembar 17, 2024 od Kuja Lemić and LightMatic je reagovao/la na ovo 2
Mikorist Napisano Septembar 17, 2024 #7049 Napisano Septembar 17, 2024 Ama i sa najeftinijim AD1865 ima da se naslušaš muzike. Pogotovo na ovaj način kako je odrađeno u temi. Srecko, LightMatic and Kuja je reagovao/la na ovo 2 1
Srecko Napisano Septembar 17, 2024 #7050 Napisano Septembar 17, 2024 13 minutes ago, Kuja said: Nije sve u veličini i količini gvožđa i delova! Vaš iPhone je 5.000 puta brži od Cray 2 super kompjutera iz 1985-e. Chord u svojim DAC-ovima koristi FPGA čipove koji su isprogramirani da vrše funkciju DA konverzije i ne zahtevaju isto okruženje kao klasični "off the shelf" čipovi tipa Burr Brown, ESS Sabre, AKM, itd. Pretpostavljam da je to i razlog za manjak delova na PCB-u! 1. What is an FPGA-based DAC? An FPGA-based DAC is a digital-to-analog converter that uses a Field-Programmable Gate Array (FPGA) as its core component. An FPGA is a type of programmable logic chip that can be reprogrammed to perform specific functions. In an FPGA-based DAC, the FPGA is programmed to perform the digital-to-analog conversion process. This allows for more flexibility and customization in the conversion process, resulting in higher quality audio output. 2. Advantages of FPGA-based DACs One of the main advantages of FPGA-based DACs is their flexibility. Since the FPGA can be reprogrammed, it allows for more customization in the conversion process. This means that the audio output can be tailored to the specific needs of the user or application. Additionally, FPGA-based DACs can be updated with new firmware, allowing for improvements in performance and functionality. Another advantage of FPGA-based DACs is their high precision. The FPGA can perform the digital-to-analog conversion process with a high degree of accuracy, resulting in a more accurate audio output. Additionally, FPGA-based DACs can support a wide range of audio formats and sample rates, making them versatile enough to be used in a variety of applications. 3. Comparison with other DAC options There are several other options for DACs, including traditional DACs and Sigma-Delta DACs. Traditional DACs use a resistor ladder network to perform the digital-to-analog conversion process, while Sigma-Delta DACs use oversampling and noise-shaping techniques to improve the audio quality. However, FPGA-based DACs offer several advantages over these options. Compared to traditional DACs, FPGA-based DACs offer more flexibility and precision. The FPGA can be reprogrammed to perform the conversion process in a way that is tailored to the specific needs of the user or application. Additionally, FPGA-based DACs can support a wider range of audio formats and sample rates. Compared to Sigma-Delta DACs, FPGA-based DACs offer more customization options. While Sigma-Delta DACs use oversampling and noise-shaping techniques to improve the audio quality, they are limited in their flexibility. FPGA-based DACs, on the other hand, can be reprogrammed to perform the conversion process in a way that is tailored to the specific needs of the user or application. Igrom slucaja koristili smo FPGA čip za vođenje jedne PO rakete tako da sam veomaaaaa familijaran sa tim tipom čipa, ZNAM PUNO O TOME KAKO TO CHORD RADI i jako volim zvuk Chord DACs ali ne toliko za toliku razliku u ceni. Da bi taj proizvod (čiji sam tim vodio) bio primljen od strane TOC svi sklopovi moraju biti dokumentovani po standardu NO (zaboravio sam broj standarda sto i nije bitno za ovo). To znači da je i software iz FPGA morao biti u potpunosti dokumentovan (matematičko-fizički model, algoritam objašnjen, kod, ….. i na kraju kod pohranjen na fizički medij sa koga moze biti instaliran na FPGA i provereni u simulaciji parametri iz dokumentacije). Dakle znam u potpunosti sta Chord i kako radi (naravno jako malo znam o AD/DA konverziji i akustici generalno što Chord zna; kao što Chord verujem da ne zna mnogo o dinamici leta što ja znam ali za FPGA je nebitno šta “žvaće”). Dakle, tačno je da je to veoma pametan izbor za DAC (FPGA) jer kao da gađate topom (FPGA) muvu (zvuk kao fizička pojava) i da ne zavisite ni od koga (SABRE ……). Tačno je da biste promenom software mogli uskladiti zvuk sa novim fizičko-matematickim modelom kao posledicom novih saznanja o zvuku i tehnološkim principima ….. Tačno je ……. Sve je lakše sa FPGA osim ŠTO SVE MORATE DA URADITE SAMI, i to traje i košta a kao i sami što rekoste i Vama se više dopada zvuk Vašeg DAC nego Chord zvuk i niste jedini.
Doktor Napisano Septembar 17, 2024 #7051 Napisano Septembar 17, 2024 (izmenjeno) 9 minutes ago, Kuja said: Slažem se, odličan je! Imao sam davno TDA1541A NOS DAC Peđe Rogića sa kojim sam se sit naslušao muzike, ali su nove tehnologije i formati zahtevali da se krene dalje. Sadašnji PCM1704K DAC mi je dao ono što mi se sviđalo kod TDA1541A, pa je sve to još unapredio. Gore - Cambridge Audio CD3 ( prakticno danas relikvija ) - 4 x TDA1541A. Dole - Audial The Model - 1 x TDA1541A ( Pedja Rogic ). Tadasnji ( 2009 god. ) njegov landmark model. Obe djunte se slusaju ( priznajem da poslednjih godinu dana opet vise slusam CD3 ). Izmenjeno Septembar 17, 2024 od Doktor Kuja, krca44, LightMatic and 2 ostalih je reagovao/la na ovo 3 2
Kuja Napisano Septembar 17, 2024 #7052 Napisano Septembar 17, 2024 8 minutes ago, Mikorist said: Ama i sa najeftinijim AD1865 ima da se naslušaš muzike. Pogotovo na ovaj način kako je odrađeno u temi. Siguran sam! Ja sam odavno odustao od igranja sa uređajima i samo slušam muziku. Mislim da jedno deset godina ništa nisam menjao, samo sam se malo igrao sa kompjuterima kada je trebalo prilagoditi se novom dobu i strimingu. Sada sam i tu našao mir, evo mesecima me mrzi da probam kako svira M1 Macbook, što bi pre koju godinu bilo nezamislivo! Vix, LightMatic and Srecko je reagovao/la na ovo 2 1
Kuja Napisano Septembar 17, 2024 #7053 Napisano Septembar 17, 2024 4 minutes ago, Srecko said: a kao i sami što rekoste i Vama se više dopada zvuk Vašeg DAC nego Chord zvuk i niste jedini. Nažalost kao što rekoh nisam nikada čuo neki Chord DAC a voleo bih. ESS Sabre DAC-ovi su mi uglavnom zvučali naporno i veštački, dok mi AKM sviraju znatno bolje. Recimo, veoma prijatno me je u ulozi DAC-a iznenadila matora Hercules DJ RMX konzola mog sina, koja koristi AKM DAC čipove i koja svira odlično: Da ne znam za bolje, mislim da bih 'ladno mogao da je koristim kao DAC. Srecko and LightMatic je reagovao/la na ovo 2
Brijac Napisano Septembar 17, 2024 #7054 Napisano Septembar 17, 2024 (izmenjeno) Uskoro nesto jako lepo bazirano na TDA1541A Detaljno se istrazile iznutrice samog cipa, pa se i logika uzemljenja skroz menja. Dekapluje se na supply, ne na gnd. Nesto sto je i mvaudio probao, kod njega doduse na +5Vdc granu. Verujem da ce to biti kralj multibit dac-ova, al da ne trcim pred rudu.. Lepo pricah uzite cipceki od onog sa ebay, ali ima i dobrih vesti, krajem godine ce pustiti jos jednu seriju, medjutim sa malo uvecanom cenom jer to je to, nemaaa viseeee. AKM DS cipovi imaju mnogo bolje uradjen filter na samom cipu nego sabre. Jeftini DS dacovi koriste fabricke filtere, zato i zvuce isto. Izmenjeno Septembar 17, 2024 od Brijac zerowaf, Kuja, krca44 and 2 ostalih je reagovao/la na ovo 1 2 2
Beli_Ninja Napisano Septembar 17, 2024 #7055 Napisano Septembar 17, 2024 2 hours ago, Brijac said: Uskoro nesto jako lepo bazirano na TDA1541A Detaljno se istrazile iznutrice samog cipa, pa se i logika uzemljenja skroz menja. Dekapluje se na supply, ne na gnd. Nesto sto je i mvaudio probao, kod njega doduse na +5Vdc granu. Verujem da ce to biti kralj multibit dac-ova, al da ne trcim pred rudu.. Lepo pricah uzite cipceki od onog sa ebay, ali ima i dobrih vesti, krajem godine ce pustiti jos jednu seriju, medjutim sa malo uvecanom cenom jer to je to, nemaaa viseeee. AKM DS cipovi imaju mnogo bolje uradjen filter na samom cipu nego sabre. Jeftini DS dacovi koriste fabricke filtere, zato i zvuce isto. Ko je taj na ebay, može li link?
gluv_i_udaren Napisano Septembar 18, 2024 #7056 Napisano Septembar 18, 2024 5 hours ago, Kuja said: ESS Sabre DAC-ovi su mi uglavnom zvučali naporno i veštački, dok mi AKM sviraju znatno bolje Potpisujem.
Brijac Napisano Septembar 18, 2024 #7057 Napisano Septembar 18, 2024 6 hours ago, Beli_Ninja said: Ko je taj na ebay, može li link? Pisah ranije u temi. Philips TDA1541A Audio Dac Chip, 100% NOS WWW.EBAY.COM Find many great new & used options and get the best deals for Philips TDA1541A Audio Dac Chip, 100% NOS at the best online prices at eBay! Free shipping for many products! Rece mi da se prati, da ce samo osveziti oglas krajem godine. Ali jbg bice veca cena.
Beli_Ninja Napisano Septembar 18, 2024 #7058 Napisano Septembar 18, 2024 1 hour ago, Brijac said: Pisah ranije u temi. Philips TDA1541A Audio Dac Chip, 100% NOS WWW.EBAY.COM Find many great new & used options and get the best deals for Philips TDA1541A Audio Dac Chip, 100% NOS at the best online prices at eBay! Free shipping for many products! Rece mi da se prati, da ce samo osveziti oglas krajem godine. Ali jbg bice veca cena. Hvala. Nadam se da nije bio veliki problem ponoviti link, tema ima 300+ stranica...
Brijac Napisano Septembar 18, 2024 #7059 Napisano Septembar 18, 2024 Bio je pre dve strane xD Bi mi cudno da je okacio samo jos par komada, obicno okaci po 20 stock, i reko to je to poslednje. Bice verovatno oko 120e, sto je previse. Ali opet, postaje bas unobtanium. Tu su uvek polovni jeftini uredjaji sa tim cipom.
Mikorist Napisano Septembar 18, 2024 #7062 Napisano Septembar 18, 2024 pre 43 minuta, Zen Mod reče PCM1702 rulez Slušao sam i PCM1702.... I PCM63 i AD1862 i TDA1541A (Aya 2 kit) Uz napomenu da TDA1541A nije r2r DAC. Sve mu se svodi na to šta je na izlazu u I/V i kako je to izvedeno. Miro je usrao tu nešto. (ne može copy-paste za sve slučajeve) Amanero USB-i2s je bolji (prirodniji) od JLSounds i2soverUSB - čak i sa izolovanim napajanjima...Bacanje je para.... Što se tiče samih čipova razlika je na nivou ukusa , nikako kvalitativna i da je mala. Toliko je mala da jedan može da zameni drugi - PCM63K is PCM1702 in PCM63 case..... A opet mi se najviše dopada šta izlazi iz Pavouk-a. Onako sirovo direkt iz DAC čipa u RCA. I jbga. Oko ukusa nema rasprave...
