ZZZ
Sve objavljeno od ZZZ
  1. Excellent work !!! I just want to point one thing if You don't mind. Air in the chamber have a mass. And center of that mass and-or volume. With this kind of bracing, that global mass-volume divided into many smaller volumes and masses. Also the center of global mass shift from one to many points, apart from each other. This is resulting for driver to saw much smaller volume that it actually present, if You subs-tract volume of bracing from the global volume. Much smaller... We have had this topic in the forum if I am remembering well, before some time. And a guy, remove inside bracing, reporting with the huge step forward in the sound outcome. In the lower end and ballance generally. The common builder reflex is just to add volume of bracing inside to accomplish same volume from the starting point, but it is not just like this... On the other hand, walls are really isolated. Try to measure the cab, and compare to the simulated result in the low region. If it is differs, it would be from that effect i was explain. And it will act like smaller volume in the simulations. cheers
  2. ovog malog netko udario čekićem
  3. Zen sklojocnu li te iskre?
  4. ZZZ
    Boenicke W5 SE
    To je uzina za bajatovica i dacica
  5. ZZZ
    Woland
    Jel ima negde dudovace da se najde? Meni jedino to radi (70%) malo gori glasne zice ali ukus perfektan...
  6. Jel moze neka fotografija tih sa alniko magnetima ako ima? Ako ima sa nalicija gde se vidi magnet?
  7. ZZZ
    HE Sajam Stockholm
    wow hvala na fotkama
  8. ZZZ
    Gramofonska tema
    Ako je impedansa 5000 oma prema 600 oma, onda je prenosni odnos kvadratni koren kolicnika sqrt(5000/600) = 2.88 ili 9.2db. To je step down odos i to je u startu oko -10db gubitaka koji se moraju nadoknaditi pojacajem cevi, nepotebno unosenje anomalija pri pojacanju, da bi se to posle samnjaivalo trafoom? To znaci da za recimo 10x totalno pojacanje preampa, cev mora biti 10 x 2.88=29 cca. pojacanje u kolu, i odgovarajucu nizi unutrasnji otpor za datu induktivnost primara. Za 8 oma izvod, step-down je sqrt(5000/8)=25 ili oko -30db smanjenja signala... Cak i ako se nadje odgovarajuca cev sto se unutrasnjih parametra tice, i ako ima pojacanje u kolu oko 50 X, i dalje ce bit samo totalno pojacanje 2 x.
  9. Bice, idler bi trebalo da je odvojen od motora i diska kada gramofon ne radi. A tu ulogu da odvoji idler, ima mehanicki deo on-off prekidaca. Mada mozda se moze odvojiti i u krajnjem polozaju regulatora brzine ispod onog vrha kupe osovine motora? To je ujedno i najveca mana PTP verzija... I ja mozgam kako to da resim.
  10. ZZZ
    Gramofonska tema
    Ja sam dobijao odlicne rezultate sa pogonom trafoa balansirano ALI bez mase. C.T. not connected :). Reko ajde bas da isprobam, Neumann style. Nekomplementarni Jfet bufferi 4 x po kanalu. Jedino sto jednostavno moraju biti upareni. Ono sa potom je ok ali kada su stvarno upareni mnogo bolje radi. Napajanje isto igra ulogu. Cap multiplier na izlazu napajanja mi je davao losije rezultate. Neki kao efekat kompresije. Umrtvljivao je. Prebacio sam taj segment ispred, a najbolje mij redio jednostavni pass tranzistor odmah na bufferima. Ranije sam radio i shunt kao poslednji segment PSa, ne secam se tacno kako je zvucao, mozda malo brute force? Primenio sam regulator koji se polako podize na vrednost napona napajanja. Tako da nema naglog udara ni velikog nekontrolisanog offseta na izlazu koji ce magnetiti trafoe. Napon se polako sekund dva dize, a merenjem na izlazima buffera nema nikakve razlike pa jezgro trafoa nije magneceno. Mogu da budu korisne informacije
  11. ZZZ
    Gramofonska tema
    Slusao Miyajima model Shilabe. I to bas sa Kuzma T modelom i onom masivnom ruckom (ne znam mdel). I sa originalnim diskom i sa diskom by Eci. Meni se jako svidelo kako to radi. Sa Ecijevim bajadera diskom nekako je bolje radilo. Karakteristicno i prirodno. Verovatno zbog toga sto Miyajima ima sistem namotaja koji se razlikuje od standardnih izvedbi? I ko na jos sta sve. Ipak je to jako veliko iskustvo...
  12. ZZZ
    Gramofonska tema
    Evo posto sam ja prvi rekao da su mi ti gramofoni ruzni i da mislim da vizuelni dizajn nije najbolji, da pokusam da objasnim. Stvarno nisam imao nikakvu nameru, a mislim da nisam ni u postu nikoga prozivao. (Inace taj izraz me strasno nervira.) Prvo Igora znam samo iz kratkih vidjenja sa berze uglavnom. Mogu reci u tom smislu sve najbolje. Veoma prijatna i vaspitana osoba. Licno na mene je ostavio prvi utisak koji je jako dobar. A kada sam cuo da ima uspeha u inostranstvu, bilo mi je jako drago. Znam da se gramofonima bavi duze vreme. Video sam jos i ranije da ima dosta uradjenih komada. Posle toga je napravio nove serije gramfona. A to znaci da je vredan, pozrtvovan, uporan i posvecen. To su osobine koje ja cenim i postujem. Mogu jos dodati da svako iz nasih krajeva, a narocito mladja osoba, ko postigne odredjen uspeh u inostranstvu, ucini da se i ja nekako osetim ponosnim. To mi dodaje eneriju, pa i nadu da nije sve lose, da je i kod nas moguce realizovati i ostvariti nesto... Jako je veliki uspeh, mozda jos teze od dizajna, planiranja i izrade, komunikacija sa inostranim, da kazem klijentima, firmama i ljudima uopste. I to je jako komplikovano. Moze se nauciti naravno mnogo toga u tom smislu, ali potrebno je imati i pojavu i generalno dar za to uz neizostavno domace vaspitanje. Uopste me ne cudi sto Igor to uspesno postize... Ubedjen sam da ce i u buduce to samo biti bolje. Kada se tome pridoda i izuzetno komplikovana procedura bilo kakovog slanja potom tako kabastih stvari, taj blast postaje jako veliki i to je jos jedna uspesno preskocena prepreka koju jednostavno nije svako sposoban da prodje. Drugo, jesam komentarisao vizuelni dizajn. (Ne tehnicke stvari pa ni zvuk.) U principu ako za nesto nemam validne argumente o tome i ne pisem. Mogu to sada faktografski navoditi i ilustrovati fotografijama ali me stvarno mrzi da pisem... To nije licno misljenje izneseno na osnovu licnih preferncija i ukusa, vec argumentovano i cinjenicno tacno. U tome i je i osnovna razlika izmedju ukusa, koji ne mora biti obrazlozen niti potkrepljen bilo cime... Nisam komentarisao izradu, a trebalo je. Po mom misljenu izrada je odlicna. Ne pisem ovo zbog toga sto poznajem Leonarda licno i jako ga cenim, vec zaista vidim to cak i sa fotografija, a neke od primeraka sam video i uzivo. Nisam komentarisao ni cenu. Cak ne znam ni koja je. To stvarno nikada ne radim. Ali nekeko imam utisak da je cena manja nego sto bi trebalo da bude. O nasem tzv trzistu ne bih govorio stvarno. Ispostavilo se kao netacno da ne postoji nekakav popust za domace kupce. I zbog toga je dobro da je data tacna informacija o tome. Nisam komentarisao ni zvuk gramofona posto nisam imao prilike da poslusam. Verujem da je jako dobar. A i da jesam poslusao, to misljenje bi bilo jako povrsno, subjetivno, relativno i stvar ukusa.
  13. ZZZ
    Gramofonska tema
    E moj Miloše iz kruga dvojke...
  14. ZZZ
    Gramofonska tema
    Čiko jel su svi ti gramofoni tvoji?
  15. ZZZ
    Gramofonska tema
    To je bio prvi gramofon na kojem sam pustio plocu pre skoro 50 godina. Imali ga moji... Svaka cast za post, umalo mi ne udarise suze
  16. ZZZ
    Gramofonska tema
    Nisam rekako da bi tangencijale rucke trebalo da imaju offset ugao. Nemoj pogresno navoditi. Na osnovu informacije koju si ti izneo da su to polu-tangencijane rucice mislim da u tom slucaju ne bi bilo lose da imaju manji offset ugao koji se da izraziti na osnovu geometrije. Ne moraju da ga imaju ali su u tom slucaju znacajno veca izoblicenja, u odnosu na manju duzinu rucica. Najnepovoljniji slucaj kraca rucica bez offset ugla - najboji slucaj duga rucka sa offset uglom.
  17. ZZZ
    Gramofonska tema
    Naravno da se bavim strucnom kritikom dizajna. Drago mi je da si dipomirao na akademiji primenjenh umetnosti kao i to sto si ostao u struci. Dobices facijalni grc od tih namigivanja. Evo ovi novi su mu bolji
  18. ZZZ
    Gramofonska tema
    Igor je super momak, vredan pozrtvovan. Ima i uspeha u inostranstvu. Svaka mu cast. Ali meni su njegovi gramofoni jednostavno ruzni. Uvek napravi nesto nakaradno, nesto sto iskace iz opsteg vizuelnog konteksta. Uz duzno postovanje, to je osobina dizajnerskih priucenih i amatera. Ako vec neume to sam trebalo bi da angazuje nekog profesionalca za to. Iz aviona se vidi da su to oblici i vizuelna resenja po sistemu "A sto ne bi moglo". To je bilo u vecoj meri prisutno kod prepravljanih gramofona a postoji u znacajnoj i kod novih modela. Bez uvrede...
  19. ZZZ
    Gramofonska tema
    Ma to radi bre kao sat...
  20. ZZZ
    Gramofonska tema
    Pa regulise se i brzina podizanjem ili spustanjem te cele plocice sa prstenom od filca. Jako tacno moze da se namesti, a vrlo brzo za desetak sekundi.
  21. ZZZ
    Gramofonska tema
    Ima ljudi po svetu kojima je lakse da kupe lampu koja im se dopada, od par hiljada eu nego nekima ovde kod nas da prdnu. A i ljudi koji kupe skupu i kvalitetniu lampu kupice lahko i gramofon? Magnetofon, vec malo teze. To cudo je ustvari veliko samo izgleda i deluje manje nego sto je u 3D...
  22. ZZZ
    Gramofonska tema
    jos gore... I u tom slucaju je potreban offset arm ali manji
  23. ZZZ
    Gramofonska tema
    Gramofon jako lepo izgleda i deluje na prvu loptu. Dobro dizajniran ali samo iz aspekta vizuelnog dizajna. Kompaktan. Ima i recimo, originalno resenje, zastitnik oko baze rucice. Vrlo lepo i korisno. Ispravno koriscenje jeftinh materijala u cilju postizanja efekta punih i debelih metalnih ploca. Dobra vizuelna upotreba drveta. Medjutim ima jedan jako veliki nedostatak koji se tice izgleda rucice. Rucia je bez offset ugla. Ravna je pri vrhu. Cak i ravne rucice koje imaju mogucnost da se glava iskosi i na taj nacin postizu ugao / to nj offset angle. Mora postojati savijen deo pri vrhu rucice. to je offset arm. Naravno to se izracunava i zavisi od duzine rucice i ostalih parametra. Nije nikakav rocket sciense. Primeri rucica koje imaju ispravan offset arm su Shick, emt927 itd. To je jako vazna stvar. Pogledati odeljak u knjizi radiotrone hand book o gramofonskim rucicama gde je racunskim i eksperimentalnim putem pokazano dosta toga u vezi sa rucicom... Ne vidim ulogu mikroprocesora sem da se pokvari i da u sadejstvu sa tasterima izaziva konstantne probleme... Jos jedan dizajn koji je dobar ali ce vrlo brzo biti zaboravljen.
  24. ZZZ
    Gramofonska tema
    to Doktor Da su zeleje realne ne bi bile zelje... Salim se ova prva 2 sa moje liste, jednostavno ne mogu da se nadju. Bio je jedan Neumann kod nas ali budalcine ga bacise na djubre pre 30-40 godina. Rekose - Kanta? Odmah sam isao u gvozdjaru da trazim neku sipku da kupim i to ne kruznog profila nego kvadratnog... Ima jedan komad na ebay se vrti ako je pored toga sto je mint i jako skup. Tako da svi samo lurkuju niko ni da pipne tastaturu... Ovi Seiko-Epson su vrhunski top idleri. Ne verujem da ih je uradjeno vise od 100kom? pitanje je da li je uopste trocifreni broj. I naravno bili su jezivo skupi a sada su jos skuplji i nenabavljivi. Pogleda jsamo kakva je lepa Tregakijeva rucka koja ide na seiko epsone - kao deciji automobilcic, gradjevinska masina, fantasticna mi je stvarno. O dizajnu i taskama oslonca da ne govorimo... Kao casovnik, cak mislim da je i unipivot sistem... ... Ja cu da se zadovoljim sa brojem 3 i emt 927 za start. Kad spomenu Sony, jbt video sam neki dan jedan soni (na fotkama) mislim da je studijski model DD, jednostavan, veoma solidan a nije premasivan... Odlican broj 3 sam imao i upgrejdovao, a secam se ulja u kadici odlicno je to radilo... broj 5 Kuzma, samo mi se svidja onaj neverovatan model sa T osnovom. Neverovatan dizajn, vrhunski za istoriju dizana, slusao vise primeraka svuda odlican. I mini
  25. ZZZ
    Gramofonska tema
    Evo i liste mojih favorite gramofona - definitivna lista 1. Neuman PA2 2. Seiko Epson sigma serija 3. Lenco double decker 4. EMT 927
  • Trenutno na sajtu   0 članova, 0 Skrivenih, 217 Gosta (Pogledaj celu listu)
    453.6k
