mutayu
Poslednji trofej
mutayu je imao/la sadržaj sa najviše reakcija!
1 Pratilac
Informacije Profila
  • Pol:
    Muško
  • Lokacija:
    Dojno Polje
  • Zemlja:
    Serbia
Skorašnji posetioci profila
mutayu's Achievements
Dugo je sa nama
Dugo je sa nama (7/9)
808
Forumska reputacija
  1. U prozorcicu Edit za vrednosti kondenzatora treba postaviti i odgovarajuci series resistance za primenjeni kondenzator. Evo ga i proracun impedanse trafoa iz PSUD2 help-a : Edit Transformer Properties Enter the voltage for the secondary of the transformer. Note that this must be the off-load voltage, which is generally higher than the rated voltage of the transformer. For full wave rectifiers, use the voltage for one side only. For example, if the transformer off load voltage is 350-0-350V (700V end to end), the correct value to enter is 350. Enter the source impedance of the transformer. If you don't know this, you can click on the [...] buttons to invoke the off load voltage calculator, or source impedance calculator respectively. Source Impedance Calculator The source impedance of the transformer is required in order to simulate the transformer "sagging" under load. Supply voltage: (VP) The voltage primary supply into the transformer, normally 110/115/220/230/240 volts. Winding resistance: (RP) The measured resistance of the primary winding. Off-load voltage: (VS) The measured voltage on the secondary of the transformer before any load is applied. Winding resistance: (RS) The measured resistance of the secondary winding. Resistance for simulation: R.equiv = ((VS/VP) x RP) + RS
  2. Stara Ei Melodija je postala RH84. Doduse sa switcherskim napajanjem i regulatorima pa susti kao luda. RH.jpg.heic
  3. Krco, samolepljivi bitumen ce da ti se topi vremenom pa ce trafo da ti "potone" kroz njega.
  4. Za ovu robu treba pratiti i "Temu". Cene su obicno akcijske a shipping je free.
  5. mutayu
    DIY fluks pasta
    Lakiranje rastvorom kalafonijuma moze elegantno da se uradi airbrushem, najbolje vecim- suction feed tipom. Moze i da se upotrebi Izopropanol, bezbedniji je od nitro razredjivaca a dostupan je za kupovinu na litar u poslednje vreme.
  6. Javi kako se zavrsila ta akcija u Kljucu! Ovo u Sokolu je izgleda bila neka improvizacija. Nekada su imali odliicne farbare,tehnologiju i prajmere, antikorozivnu zastitu i zavrsne boje ali izgleda da nije ostalo nista od toga.
  7. Budi oprezan sa Gyurgyevcima! Moze da ti se desi da prestanes da pravis druge ili bolje zvucnike 😁
  8. Ja tek sad vidim sta je sve nestalo od slika a da ja to nemam sacuvano 😦 Prava mala katastrofa. Zene moracu da ti dosadjujem oko sema za Iskra lampase i Quad 405 mod...
  9. Sad cu da vidim...
  10. Kako rekoh u naslovu: -dva univerzalna daljinca sa prijemnim modulima, ja ih namenio za Sony PS1 cd player. -maleni DAC -opticki toslink kablic 1,5m Ostalo visak od raznih eksperimenata, ispravno, citavo, neupotrebljavano ili sasmim malo upotrebljavano. Prodajem da prodam, cena recimo 500 dinara za sve, moze i zamena za delove. Najbolje licno preuzimanje u bloku 70 ali mogu i da posaljem postom. Ako je nekome hitno i neophodno moze i kao poklon uz licno preuzimanje.
  11. Naidjoh na podatak da je "autoignition temperature" za Ikea particle boards oko 200 stepeni C.
  12. Ne znam da uradim u ovom trenutku ali mogu da ukazem da je relativno lak put konverzija JPG u GBR.
