Showing content with the highest reputation on 06/24/24 u svim oblastima
  1. koki
    Stari dobri zvucnici
    Zahvaljujem se svima konacno "trajno" resenje, U startu sam prihvatio savet clana Zen Mod i kupio od clana John C. buffer po izuzetnoj ceni mislim da je to vise "poklon" Sad Quad 405 radi bas kako sam zeleo. Gospodin Marko mi je prodao i pojacalo el 84 mozda cak i poklonio, Sa izlaznim trafoima kako kaze moze i 6v6 i 6l6, pa cu moliti Cika Brku za prepravku. Tj poslusacu ga za one ruske lampe. Jos jednom hvala svima a NAJVISE Marku.
    6 poena
  2. Evo i varijanta sa shift registrima ako se ne tera direkt sa bugarina Ova verzija daca ima onsemi 78xx 79xx regulatore.
  3. Mikorist
    Pass DIY headphone amp
    Samo da se javim da ovo i dalje svira. Nisam ga ugasio od onda.
  4. Bice uskoro tema sto se tice diy radova, i tu ce biti stavljeno stosta toga. Imam nekih raznih planova sto se tice diy komune, da se malo vise prosiri svest o tome (i kod nas i globalno) i da se ima zapravo gde glumiti ludog naucnika umesto radnih soba/kuhinjskih stolova Malo fali zeni da me izbaci naglavacke zbog hrpe komponenti i haosa na radnom stolu 😅
  5. ...prepakovan a42 u brezov sper.
  6. Da ne bude da sam ove godine zapostavio diya hobi..
  7. "What would you do if a never before released jazz funk album from 70s Yugoslavia had dropped suddenly into your arms? An album which sounds like a crate diggers holy grail!? Album full of heavy drum breaks, repetitive bass grooves, superb sax solos and world class jazz arrangements finely intertwined with Yugoslavian folk music elements?! – “PRESS IT!” ~ That’s what we said always striving to present the future of unheard sound of Yugoslavia! With the help from Mr. Cosmic himself (Željko Kerleta), Jovan Maljoković and his wife Nevenka and, of course, Radio Belgrade who provided the recordings buried deep in their library, here we present Jovan’s first vinyl release since 1989 and his album nr. zero. If this LP was released in 1976, sounding this clear and impressive as it sounds today, it would be up on the pedestal with cult Yugo jazz-funk releases such as Sećanja by Miša Blam (also released on Everland) – and believe me – it would burn a whole through your wallet....." "Jovan Maljoković Ensemble's latest album, "The Uplifting Abyss = Ponor Naviše," is a captivating musical journey that blends traditional Balkan melodies with modern jazz elements. Led by renowned Serbian saxophonist and composer Jovan Maljoković, the ensemble's impeccable musicianship shines through in each track. The album's title, which translates to "The Uplifting Abyss," perfectly captures the duality and depth of the music, as it simultaneously transports listeners to new heights while also exploring the depths of human emotion. With its evocative compositions and dynamic performances, "The Uplifting Abyss = Ponor Naviše" is a must-listen for any fan of world music or jazz." Bio sam danas u Zagrebu, pa sam otišao i do Croatia recordsa, bivšeg Jugotona, jer sam napikirao nekoliko naslova i dok sam ih tražio listajući albume, umjesto da jednostavno kažem teti što tamo radi po što sam došao, sam nabasao i na, za mene priprostog paorčića, nepoznato nešto. Nisam se ni potrudio izguglati nego sam i tu ploču stavio na hrpicu s drugima. Na koncu je ispalo da sam kupio album sa sjajnom background pričom jer je ovo album koji je izdan skoro pet desetljeća nakon što je snimljen, tj. ako se ne varam, 2022. Jovan Maljoković, saksofon, je sa svojim "ansamblom" snimio 1975./'76. upravo odličan funk/jazz album i nazvao ga "The Uplifting Abyss". Bih li volio još malo više hrabrosti u solo dijelovima i malo više igre u "razgovorima"? Pa bih, ali bi onda izašao iz žanra. Ali, to sam samo ja, a što ja znam o funku! Hoću reći, ovo jest vrijedno slušanja i drago mi je da sam nabasao na njega. Može i kao dobra kulisa u finoj gostionici, a može se i aktivno zadubiti u album. Produkcija je jako dobra, ako je nekome važno.
  8. Ovo mozda vise nije ni za ovu temo , nije vise ni DAC
  9. 1 poen
  10. 1 poen
  11. 1 poen
  12. Woland
    Peteris Vasks - Vientulais Engelis: Meditation for Violin and String Orchestra x 3
  13. Woland
    JazzBaltica 2023 Nils Peter Molvaer https://youtu.be/s2pWE9nOcJg?si=5pbrHQICOlGFOH-5
  • Trenutno na sajtu   0 članova, 0 Skrivenih, 1618 Gosta (Pogledaj celu listu)
