Showing content with the highest reputation on 12/12/23 u svim oblastima
  1. zerowaf
    Opet Ezio Boso. Sad već imam 4 ploče, pa bi se moglo reći da mi se sviđa. Glazba koju je pisao ima prepoznatljiv potpis, pa će kao i uvijek nekima biti odlična, a nekima dosadna jer se potpis ponavlja. Ovo nije opis ovog albuma nego onoga što sam do sada čuo od njega. Meni odgovara atmosfera koju gradi raznim gudalima, pianom i orguljama. Inspiriran pjesmama E. Dickinson nastao je ovaj projekt koji nije nikad doveden do kraja onako kako ga je Ezio zamišljao.
  2. Vix
    Izvinite za off
  3. Izgleda da ne vole bas D-klasu reko mi Aca da stavim i L osim konda u skretnici Poceo kao rupa u sredini dok pucao skroz...
  4. vbraca
    Danas postavljeno. Cudesni Bozo...
  5. Proći će vreme, naći će u ruševinama te uređaje, kao što nalaze slike „sa torbicama", čudiće se na isti način... Otkud ta stranputica u razvoju koji su, taman, mislili da su shvatili...
  6. krca44
    Rupa na saksiji
    Evo da ti citiram kako je radio kutiju i skretnicu drugog reda : "Going into more detail on the Altec Valencia and the Altec Model 19, the Valencia was a pre-Theile/Small vented speaker with a very basic 12 dB/octave crossover at a nominal 800 Hz. No horn EQ. The Model 19 came out ten years later as the successor to the Valencia. The bass cabinet is a T/S vented bass alignment in a 9 cubic foot enclosure, and the crossover was moved up to 1200 Hz, with adjustable mid and HF equalization. The bass driver and HF horn were essentially the same as before, while the compression driver was improved with the Tangerine phase plug. Another difference between the Valencia and the Model 19 was the Valencia was designed at the end of the tube era, and transistors had completely replaced tube amps when the Model 19 was designed. The new speaker is intended for use with triode amplifiers with damping factors of about 4 (Zout = 2 ohms), a closed box is a better choice, giving an overall system Qts between 0.9 and 1.0, not that different than the classic acoustic suspension speakers of the Fifties ... a moderate bass lift. Crossovers are similar, and the horn is a much flatter modern design." "It is standard practice to sum all resistances appearing at the terminals of the bass speaker ... output Z of the amplifier + cable resistance + DCR of the series inductor(s) of the lowpass section of the crossover. As mentioned above, this raises the system Qts if the box size is the same, but can be offset if the box size is increased. The overall goal is to have the Altec/GPA 416 Alnico-magnet driver in a loosely filled closed box, with source Z's between 1 and 2 ohms, and also accounting for "room lift" in the below-60 Hz region. An alternate approach is to use a vented box with about twice the volume, preferably in an alignment with favorable group delay characteristics. Both LF and HF sections use a passive crossover in the 640 to 800 Hz range, powered by a single amplifier in the 10 to 60-watt range. The expected attenuation in the HF section will be about 10 to 12 dB, with a shelf equalizer if the Yuichi A290 or ES290 type horn is used. It is a simple 2-way system optimized for vacuum tube amplifiers with zero to moderate feedback. If response down to 20 Hz is desired, that can be provided with a separately powered pair of subwoofers. In that application, Class AB or Class D amplifiers are the best choice, since they have the most power, are the most efficient, and there is limited impression of tonality below 40 Hz." "I want to thank Joseph (Troy) Crowe for his extensive measurements on the Altec/GPA 416 Alnico in a 100L sealed box enclosure. I suspect the very low IM distortion is the result of the underhung voice coil, which is very rare in modern drivers. I am also gratified to see the cumulative-decay (waterfall) curves are as good as they are. 416 Measurements : https://josephcrowe.com/blogs/news/altec-416-8b-in-100l-sealed I also want to thank Gary Dahl for completing the Beyond the Ariel project with his sealed-box Great Plains Audio 416 Alnicos and the AH425 Azurahorn. He's chosen the extremely rare Yamaha 6688 compression driver, while I will be following Joseph Crowe's guidance on the SB Audience CDN-65T driver, which has remarkable performance for a large format compression driver. I will be contacting Joseph Crowe for guidance on getting the last mile of this project done: an optimal crossover, most probably using an 1.8 kHz notch filter for the 416, and a 3D-printed or NC-milled adaptor between the 1.4" circular exit of the CDN-65T driver and the 2.0" square entrance of the Athos Audio Yuichi A290 wood horn. Alternatively, using Crowe's own ES-290 wood horn, but I already have both AH425's and A290's horns sitting in the basement, awaiting use. I don't think I need three sets of horns to play with, but who knows? The measurements referenced above show a crossover in the 640 to 800 Hz region is well-suited to the 416, especially with a moderate notch filter tuned to 1.8 kHz. I still favor large format compression drivers, since they allow a crossover well below 1.2 kHz, in the 500 to 800 Hz region. An octave makes a big difference in this frequency region. The SB Audience driver is unusual because it extends smoothly to 17 kHz, while most drivers with 3 to 4-inch diameter Ti or Al diaphragms usually have their first resonance around 13 kHz. I don't know what SB has done, but that is exceptional performance, approaching carbon fiber or beryllium diaphragms, at one-third to one-tenth the price. As for other questions, I have no recommendations for transistor amplifiers, either Class AB or Class D, or bipolar transistor vs GaN FET. From what I heard at the Seattle show, Class D using GaN FETs has come a long way, and has surpassed linear Class AB transistor, but still isn't quite in DHT triode territory yet. But is getting close."
  7. krca44
    Rupa na saksiji
    Vidi ovde : https://www.diyaudio.com/community/threads/beyond-the-ariel.100392/page-767 Par stranica pre toga Lynn objasnjava koncept - zatvorena kutija / kompresija + cd & Horna Smo probaj da gabaritno smanjis koncept. P.S. Izvini sad vidim da sam malo omasio al nema veze probao je on i RAAL kao visoki pa mozda odatle nesto uspes da izvuces.
  8. NIXIE
    Rupa na saksiji
    100Hz-10kHz. To tek kad odeš u penziju. Visoki iznad 10k su 10dB tiši od ostatka.
  9. Vix
    Rupa na saksiji
    Evo jos jedne rupice : audioXpress Editor AUDIOXPRESS.COM The 10HX230 10" coaxial professional driver from Faital Pro is another interesting example in the category, particularly well-received in professional audio applications. The Faital Pro 10" 10HX230 driver expands the...
  10. Aleks
    Rupa na saksiji
    Što veli gazda Wayne AudioRoundTable.com: Pi Speakers » HF Compression driver without horn flare? AUDIOROUNDTABLE.COM Audio advice and discussions with audiophiles and professionals. Free discussion forums, open to all and frequented by industry experts. Ask questions and get advice on stereos, speakers, hi-end amplifiers, pre-amps, home theater, tube hi-fi, turntables, vinyl, tweaks, music, films, video, DVDs and more. Probao bih ja bez, ako ne valja baš mnogo onda barem najosnovniji vaweguide
  11. Aleks
    Rupa na saksiji
    Ne vidim razlog da to ne svira dobro, horna je tu da uveća ionako visoku efikasnost kompresionog visokog te disperzuje zvuk, i to radi super za svoju namenu - razglasni sistem kome je to uloga, da bude što glasniji za što manje vati i da se širi što više u prostoriji gde se ljudi vesele. Uprošćeno rečeno Elem, u kućnim uslovima nema razloga da to ne sviri fino, za par slušaoca zavaljenih u fotelje. Viđao sam po YT te stvari, onako u internet prenešenom snimku, zvuči fino.
  12. Aleks
    Rupa na saksiji
    Staaaara priča, SWR300 ili Deltalite 2512 pa sa tom Beymom, ne bi trebalo da bude komplikovana skretnica, 1st order sečeš tipa na 2500 šta znam Ja bi odatle pošao, moglo bi da bude interesantno Inače, jeste rupa, Pi speakers koncept, bavio si se ti već time beše
  13. Ne treba mi gramofon da bi slušao ploče.
  • Trenutno na sajtu   2 članova, 0 Skrivenih, 1673 Gosta (Pogledaj celu listu)
