Showing content with the highest reputation on 09/07/22 u svim oblastima
  1. NIXIE
    Mini pretpojačalo sa OP
    Sporo mi ovo nešto ide, ali staće sve u kutiče.
  2. Nikakvi. Sva oprema je trenutno van mog domašaja. Razdeljena po selu 😁.
  3. Steeplejack SET measurements starting here: https://www.diyaudio.com/community/threads/steeplejack-or-how-f8-met-mighty-babelfish-m25-schade.389982/post-7117121 all in all ........ pretty good approximation of Scryer measurements, shown (starting from post #5) here: https://www.diyaudio.com/community/threads/scryer-or-how-f8-met-mighty-sissysit.388550/post-7078135 even if I didn't stretch my self for uncomfortable task to compare Scryer and Steeplejack SET directly, gone by always giggly auditory memory, but more by general feel of ease, measure of feet tapping and Dia of headbanging circle, these two are close enough besides, pleasure being certainly enhanced with fact that I made another one, and didn't end in heap of Gray Smoke
  4. mjok, nemaju vukajlijci pojma Jutropad je ono sto prvo pada kad ustanes ujutru, a to sigurno nije ona aktivnost za koju muski trebaju papir kad si mali, Jutropadom resavas posekotine i ogrebotine na licu mesta igranja, tvoj licni jodni preparat
  5. I ja bi previo ovo pojačalo, al što bi kad je isto ko ovo što sad imam
  6. slusamo malo blues...
  7. shonne
    Serije koje gledate
    @Doktor, @Mikorist
  8. Hagerman Technology LLC: Cartridge Loading WWW.HAGTECH.COM na dnu stranice ima kalkulator
  9. Ako nisam krivo informiran load zvucnice kroz SUT se racuna ovako ovako: Rload = Ratio x Ratio x RDCprimar + RDCsekundar Negdje bi trebalo pisati koliki load trazi bas tvoja zvucnica. Pa onda izracunas sto zapravo imas i odredis koji otpornik ces staviti na sekundar SUT-a da korigiras load. Za fino podesavanje sam dobio savjet da nabavim linearni 100k stereo pot (ili dva mono) i slusajuci pronadjem sweet spot. Premjerim otpor na potu, nabavim najbolji moguci otpornik najslicnije vrijednosti (citaj: metal film za 2 centa komad ) i onda to zalemim. EDIT!!! Zaboravih, taj rezultat iz gornje formule dodaj na impedanciju svog phono preampa...znas ono - zbrajanje otpora u paraleli. Sad ces imati koje je stvarno opterecenje tvoje zvucnice, pa izracunaj koji otpornik treba dodati da dobijes zeljeni load. Nakon toga mozes i ovo fino stelanje na uho koje sam napisao. Ako nisam potpuno omasio fudbal onda: Voila! Imas pravilno opterecenu MC zvucnicu. Ako sam pak omasio fudbal sacekaj dok mi netko ne objasni da sam panglu, pa ces iz toga dobiti tocan podatak.
  10. E tako treba! Nece se nista prodati zbog dobrog grafikona. To je bilo sedamdesetih. Danas raja trazi veselo! Hoce prorocanstvo u granulama, da ako uzmu ovo pojacalo, zicu, lampu, kondenzator, promuckaju ga sa onim zvucnicima, osiguracem, osvjezivacem prostora i ako to naprave neka se paze da ih Charles Mingus ne bi aperkatom izuo iz cipela ako suskaju sa bombonima dok on svira. Ako gledaju film i imaju suraund sastavljen na ovaj nacin neka se prije gledanja Smauga namazu Coppertonom.... da ne izgore!
  11. Nema Eo bas sad zavrsio merenja Steeplejack SET, to mu dodje Poor Men's Scryer u je
  12. 1 poen
  13. Malo Deep House za promenu
  14. Doktor
    Patti LaBelle uživo ! Lady Marmalade ubiva na mrtvo.
  15. 0 poena
  • Trenutno na sajtu   2 članova, 0 Skrivenih, 1923 Gosta (Pogledaj celu listu)
