Showing content with the highest reputation on 07/20/22 u svim oblastima
6 poena
Poređenje XA30.5 vs. XA30.8 a bogumi i XA60.8
LightMatic i 3 drugih je reagovao/la na aaa zmaju! za temu
Vladd zastranio, kači slike konda od 45€/kom4 poena -
LightMatic i 2 drugih je reagovao/la na Vix za temu
Ne moraju samo kablovi da budu skupi, mogu i kondenzatori Sad kad krenu otpornici...3 poena -
ZM, random zanimacije
LightMatic i jedan drugi je reagovao/la na Zen Mod za temu
sto rece jedan ''jbo sladoled ako nije kilo"2 poena -
Choked Singing Bush ..... special one for Purists and Masochists
vinko i jedan drugi je reagovao/la na Zen Mod za temu
https://www.diyaudio.com/community/threads/choked-singing-bush-special-one-for-purists-and-masochists.388480/ OK, this one long in making I mean - have pcb files and everything for some time, basic functions confirmed but - as is my nature - never working by plan Anyway - why Purists and Masochists? List of reasons: 1. you really need properly made high quality choke; 100mH, no more than 0R5 winding resistance, declared for 3A5dc (big Tokin) or 2A5dc (small Tokin) 2. PSU - bummer - heavy filtration; CLC, or C then cap multiplier followed with heacy C cell, or fat switcher ..... most likely also followed (by choice or necessity) with some sort of high-pass filter and followed with fat C cell 3. this time ( even if evidently intended as option) - no Schade Mos Puck; simply too high Rout of part itself (even if normally or even heavy Schaded), resulting in uberfunny transfer function and THD way too high; now - with all my crummy chokes (yes, Plethora of them but all crummy) that's the situation; there is a possibility that Schaded option is viable and worthy if adequate quality choke is used, but that I can't confirm, nor I intend to purchase it, in any way or arrangement 4. looking at all above - simply - cost; you gain something with lesser volts involved (vs. say "regular" Singing Bush) thus lesser heat and lesser Donut and lesser voltage caps and lesser Aluminum in sinks...... but then main choke, PSU choke, yadayada.... 5. yes, OPT is an option, for both shown iteration ( Big Tokin, small Tokin), don't have it, easy to try if you have one; same conditions as with choke - do not even try with cheaply made Iron there are few more reasons, worthy of this list, but I'm lazy to think now ..... Anyway, usual set of introductory eye-pleasing files:2 poena -
krca44 i jedan drugi je reagovao/la na NIXIE za temu
2 poena -
Vix i jedan drugi je reagovao/la na Pchelac za temu
2 poena -
Racunaj da je 90 preko vremeplova2 poena -
Ako ne čitaš ništa i ne družiš se ni to ne valja. Najbolje je ko je nepismen. Blažen je. Ignorance is bliss Mada nekima i ne preporučujem da čitaju recimo temu o NOS DAC ili audiosciencereview forum sa hvalospevima o Delta-Sigma uređajima . Nije za svakog sve da čita. Može lako da se odluta u ludaru koja god krajnost da je u pitanju... Ja recimo uopšte ne čitam teme o gramofonima. Odsekao sam se potpuno od toga jer loše utiče na moje mentalno zdravlje.2 poena -
LightMatic i jedan drugi je reagovao/la na vladd za temu
Zapravo dosta diyera ima samoodabrane što šefove što savetnike, odabrane na osećaj čitanja raznih foruma. Ali nije to bitno. Spomenute su firme kao ugledne, ja samo obrazlažem da imena brendova nisu garancija željenog, da bi diy bio uspešniji. Profi firme imaju nezgodne proizvode za amatere i diyere, pa kada se kaže trajnost kondenzatora i Cornell, onda se u sastavljanju tih elemenata pogledaju recimo HHT ili (AXLH) serija kod dotičnih, ali su neprijatne cene i rade se po narudžbini, ali je upravo to baš ono i to su ti proizvodi što Cornell čine Cornelom vrednog spominjanja i dokazanog kvaliteta i ekstremne upotrebljivosti, a ne neki "uobičajeni", da ne kažem dodatno, nebitni ili komercijalni, kond od par dolara. Koji se trpa u masprodukciju i nije skup za diy zabavu. https://eu.mouser.com/ProductDetail/Cornell-Dubilier-CDE/HHT472P016HL0?qs=gt1LBUVyoHmclTmXGnyeZA%3D%3D To je suština onoga što rekoh a ne da li diyer i kako, glumi slobodu izbora2 poena -
predmetno napajanje sam onomad dobio od naseg ortaka Davor-a koliko se secam koristeno je u tehnici mobilne primopredaje1 poen -
Čuvaj to za one ogromne Ruske lampe sa anodnim naponom 1500V. Zaboravih oznaku, ali izgledaju ko sijalica za svetionik. PS GM1001 poen
Onda rokajte preko technodis-a. Racunam, cifre sa mousera su cirka 7500din (zbog kolicine uracunah manju cifru za jfete, na 100 je dobar popust, oni po predracunu nisu al boze moj), bez pdv izadje to oko 11000, sa pdv 13000. Ako gledano tako, ukupno sam platio 5.5k vise nego cena sa mousera. Sto je jeftinije nego preko tih nabrojanih @Mikorist1 poen
Ček...kako to misliš da pričanje ne rastjeruje ribu?????1 poen
LightMatic je reagovao/la na zek za temu
1 poen -
Trenutno na sajtu 2 članova, 0 Skrivenih, 2193 Gosta (Pogledaj celu listu)
