Showing content with the highest reputation on 02/25/17 u svim oblastima
  1. neskor
    Magnetofon vs Gramofon
    Daans sam naleteo na zanimljiv post coveka koji ima vrhunski R2R i vinil sistem. Evo sta on kaze: The short answer is that R2R is very significantly better than a high quality LP system, providing the source material is ok (s0me tapes haven't survived as well as others, for instance). 1) Speed stability - absolutely rock solid with tape - no wavering on piano notes etc.. Verdier is very good, but you can hear the (very subtle) knock from the knot in the linen thread on every platter rotation 2) Dynamic range - the Verdier with the battery PSU is pretty much inky black on the blank grooves in between tracks. No vinyl noise or mechanical noise. With tape, you can get a tiny bit of tape hiss, esp if the tape used is several generations down from the original; you can minimise this by using something like Dolby A or Dolby SR (I have 2 Dolby 363 machines with A and SR - I just haven't got round to plugging them in yet). However, the tape medium is able to capture and transmit a much greater dynamic range compared to the grooves of an LP. After all the mastering engineer has to apply compression and EQ to cut the lacquer. You can hear this difference very easily between a master tape and a good vinyl pressing. 3) Sound quality on tape is the same at the end as at the beginning - unlike records. Tape has a constants linear velocity of medium over the head (transducer). Records have a constant angular velocity, which means that the amount on information gets less and less with each rotation of the record; hence the inner grooves don't sound as good. 4) Microdynamics are much better on tape - subtleties of brush use on drums, additional bits (e.g. the crowd noise and applause on Sgt Pepper's). General dynamics are faster with tape i.e. drums, crescendos etc 5) Soundstage is uncompromised on tape (obviously this depends on the original recording). I have been listening to hi-fi for 35 years now, and the last two years of R2R have been a complete revelation. I have heard some very good vinyl replay systems in my life, but none of them approach a 15 IPS master tape.
  2. ninja
    Ja sam tako nesto slusao ovdje kod jednog poznanika i imao sam isti zakljucak. Problem je cijena traka kojih ima a i veliki nedostatak mase materijala koji bi slusao.
  3. Pokojni Vilko Sever ( ko se bavi motorima zna ko je on) mi je rekao ( ležali oko mjesec dana u bolnici - trauma) da su za saobraćajku potrebne dvije osobe ! . Ona koja ju je skrivila , i ona koja nije dovoljno pazila . To je bilo 82 lil 83 . On je pao na stazi u Sl Požegi na prvenstvu Yuge , a mene skršio taxista. Ja mu velim nisam kriv ! bio sam u svojoj traci , a on je preko nje skretao lijevo . Veli čovek : kaj nisi " abgasal" , kaj očekivaš od taxista u pol 2 u noći . Bio deda danas mojih godina . od tad nisam imao prometnu nesreću s motorom , a auti su druga priča jer u današnjem prometu nema pomoći
  4. kad pomenu Vilka ....... seca li se ko Imre Salme-a , iz Subotice ?
  5. sich
    Jos jedan Babelfish J
    Plocice i ostalo sto ide uz njih su narucene od Zen-a. Posle prebiranja po temama o trafoima odlucih da ga sam uradim.Jezgro 550W motano na 350W.Proban I nema zzzuuu.Dodao sam bakar preko namotaja i celik oko jezgra pa ce ga bucnem u lak.Zakacio 2X24V 2X100W za probu.Ispravljac napravljen I to probano.Na 230V dobijem 2X21.5V / 2X21V pri 4.3A po grani.Odlicno. Presao sam na probu hladjaka.Jedna cetvrtina (posto je hladnjak iz 4 dela 150X180X40)Liskun BD 249 i 135 sa otporom i zenericom,opet sijalica kao opterecenje.Pri 24.2V i 2.37A posle jedno 5 sati dobio 60C na tranzistoru i 55C na hladnjaku pri TAmb.~28C.Za sad sam napravio ovo jer zbog posla,u firmi,jedva dizem glavu.Sve je pravljeno sa 2 lenjira,ubodna testera,busilica i turpija.Bice jos slika a Zenu hvala na brzom odgovoru u vezi tranzistora.Znaci ostajem pri IRFP 150N.
  6. Eci
    Uslikao ga..
  7. Zflazar
    bilo par naslova još večeras uz drage goste, svega i svačeggga, završili sa Sister Morphine sa Sticky Fingers od Džegerbenda
  8. Zflazar
    ok, kad bude plime biće i rime, reče Perica u vicu, hoću da obznanim da će u skorijoj budućnosti u ZR biti uz IronPre koncept zvani kasetoven biti probana i c3M poštarska cev u triodnom spoju kao line preamp biasiran na oko 130-160 VRa i 12-18mA Ia na sledećim mukama: 1. AVC-cev-OPT 4:1, 3:1, 2:1, 1:1 2. cev-TVC sa gapom... kad bude, otwaram posebnu temu, sa pre svega slušnim impresijama cele priče...cilj je ovaj put zabava, jeli... ...referenca je za sad ZenMod kasetoven...
  9. Zen Mod
    pa , stvar poznata .... ali mozemo da je razmatramo samo na akademskom nivou prvenstveno zbog toga sto je izbor softwera daleko veci na vinilu ..... sa druge strane - onaj kome cenovni faktor za brand new tape , izdanja na tape itd nije od krucijalne vaznosti ....... taj ce da ima i tape sistem i nece visiti na forumima
  10. 2a3
    Lakse je decu napraviti
  11. grau.
    vi ko decu da pravite...
  12. Zen Mod
    Iskra OZ40 da li to to?
    ne . u kutijama od Garrard gramopojacala su bili samo ovi driveri sa trubicama postoje ti isti driveri bez trubice , u nekim drugim Iskra kutijama , ali mislim da je bilo jos razlike jer to ni izbliza nije bio extended range driver iteracija sa AlNiCo - postoje cak dve razlicite , sa dve velicine magneta , se razlikuju i po tome sto vesanje nije gumeno nego corrugated paper , izjedna sa cone manje basa , ali zato sve ostalo za koplje bolje
  13. Zen Mod
    FIM rallies u staroj Jugi
    !!!!!!!!!!! pa naravno! ja sam bio mali tada ......... za Imrea znam samo iz Auto Magazina , koji sam kupovao redovno cak sam negde dugo cuvao isecak o njemu , koliko sam bio fasciniran otvaraj temu ovde (druzenje/meets) a ja tacno moram zamoliti Miku da nam ustanovi Auto/Moto stavku
  14. 1 poen
  15. black coffe
    Bili smo u Luksemburgu na na FIM reliju zajedno ! on sa pony ekspresom ! , one godine kad smo morali čekat "papire" ? i nosili crne trake na lijevom rukavu ? . Čak imam i prijavnice i popis osoba koje su išle na put iz cijele Yuge i s kojim motorima i imena i prezimena , naravno "prateće " ekipe : ! , da sad ne norim , ako koga interesira priredba iz tih godina , onda nije bilo "stikova" , al zamolit ću kuma da mi to ponovo pošalje pa ću obijelodanit ! Ako naravno niko nema nikaj protif ? ! To je fotografija izvornog dokumenta di se vide ko me ko ?
  16. https://www.google.rs/url?sa=t&source=web&rct=j&url=http://www.lezaji.rs/download/fkl_tehnicki_katalog.pdf&ved=0ahUKEwjv4pSV9anSAhUGG5oKHQt-CMcQFghEMAY&usg=AFQjCNFdmMq2JHf-fnJ53-3s1Dy3jd4GOA
  17. Zen Mod
    Pomoc oko odabira zvucnika
    meni taj srednji deluje neubedljivo ........ u tom rangu velicine bassa mozda je bolje ici na 2Way , bez srednjeg ima tamo magnata i slicnih u Appolito konfiguraciji ...... (dva bassa za izmedju visoki) usput - sta god da kupujes , probaj prvo da cujes ..... a ne da ih prvi put vidis i cujes kad ih raspakujes kuci
  18. aaa zmaju!
    Znamo, procitali smo, sta si navalio.
  19. Woland
    @Beli narafski bitje loodo, jače od ovih najnovijih izbora a još ako uspem da završim.. ixxx gde će mi kraj biti.. msm i inače sam ja sebi kralj.. neće moći da se živi od mene
  20. Dacho
    Gramofonska tema
    Idler vrtilica samo takva....
  21. Woland
    Na Pasov M2 http://www.firstwatt.com/m2.html nameračio sam da ga uradim sam, ili sam do puštanja u rad, ili sam dok me ne zvekne struja eno je kutija kod Paje u Pešti, nabavio i jFete, ostatak je nabavljiv uz kmečanje Zenu
  22. Puno je kulturnije u Svedskoj, kriv je onaj ko je kriv ali obicno vozaci 4-tockasa su malo vise odgovorni. Ne mozes da zgazis buciklistu ili pjesaka samo zato sto je njegova greska. Ima i ovdje da je vozac duzan da prilagodi voznju uslovima puta i situacije i pravila su samo osnova. Ako je ogranicenje 70 km/h to znaci max 70 km/h a ne preporucena brzina ... U svakom slucaju, vozacka kultura je na puno vecem nivou od "Balkana" i okolice a kazne nisu bas toliko puno vece, ali su skole puno ozbiljnije i obimnije. Trebali bi ljudi da su svjesniji kolko su mali i nevidljivi iza kamiona i autobusa i koliko je veliki ugao u kome oni nista ne vide a mnogi "manji" se prikradu i stanu u taj ugao na raskrsnici da bi pre dosli .... Kao sto sam vec rekao, ja bih kao obavezno stavio bar djelomicno upoznavanje i djelimicna voznja svih vozila.
  23. vdzele
    Usudio bi se da malo prokomentarišem ovakva pitanja, koja su česta na ovakvim forumima. Ko ne voli filozofiranje nek ne čita. - Na ovakve specijalizovane forume dolaze ljudi koji vole nešto duže vremena. To nije trenutna potreba, to je hobi i pasija koja ih dugo zaokuplja. - Kako "vatra" traje godinama, ako ne i decenijama, za očekivati je da će ljudi u tom periodu otići "daleko" u pronalaženju opreme koja im najviše odgovara. Drugim rečima, uređaji koji su nižeg ranga su davno prevaziđeni. Ako neki novi član traži zvučnike cenovne klase od oko 150 eura, teško da će neki stari član znati šta bi valjalo kupiti trenutno jer se svi uglavnom bave nešto skupljom opremom. - Novi "članovi" obitavaju u najvećoj meri dok ne dobiju savet šta da kupe i više ih nema. Ja tu ništa ne zameram novim članovima, to je po meni normalno, svuda je tako. Ovo samo konstatujem kao česta pojava, svakodnevna. - Biću mala banalan, možda i malo preterano, ali ovakva pitanja su kao kad bi pitali profesionalnog reli vozača: da li da kupim Fiata ili Opela? Ljudi misle da ako on vozi dobra, brza, utegnuta kola da on zna i nešto o običnim putničkim. - Ko realno ima para da menja audio opremu više puta godišnje pa da izvlači neke zaključke ko šta i kako radi? Da ih uparuje i da istražuje sa čim se slaže, i to još u Srbiji. Pre neku godinu sam nabasao na jednog australijanca koji na svom blogu samo daje recenziju rada DAC-ova. Bukvalno ih je preko 100 rezencirao. Ja bi recimo verovao više takvom nego nekom ko je poslušao par komada. Ali koliko takvih ima i u svetu? - Ovo je sajt čiji fokus je prevashodno ručno rađena oprema, mada članovi znaju dosta i firmiranoj. Tako da je verovatnoća pronalaženja odgovora ovde nešto manja nego kod onih koji samo vrte firmirano. Mada sam mišljenja da je znanje o samoj audio tehnici daleko, daleko veća ovde nego kod brendomana. - Suparnički sajt Hi-Files bi trebao da ima poseban odeljak pod nazivom "Oprema za početnike". Tu bi trebalo par "nezavinih" moderatora da daju recenzije takve opreme koju dobijaju od dilera na test probe. Nešto poput onog što radi What Hi Fi. Nažalost takvi sajtovi su apsolutna manipulacija i ja njima ništa ne verujem. Oni koji su sa nekim većim integritetom, poput Stereophile, se već ne bave početničkom opremom. - Ja lično kad bi tražio savet za takve zvučnike, sem ovih sajtova, tražio bi savet i majstora koji se bave servisiranjem zvučnika. Posebno bi tražio one koji i prave i upgraduju zvučnike. Idealno bi bilo da je audiofil. Kroz njegove ruke su verovatno prolazili zvučnici i od 150 eura čisto zbog kvara. Recimo, pored mene radi kolega koji je prošle godine servisirao preko 500 TV aparata i monitora , pored njega sam saznao šta bi valjalo kupiti a šta ne.
  • Trenutno na sajtu   5 članova, 0 Skrivenih, 1362 Gosta (Pogledaj celu listu)
